Welcome to the North American Subaru Impreza Owners Club Thursday March 28, 2024
Old 03-20-2008, 04:08 PM   #26
fliz
Member#: 30342
Talking
Originally Posted by jasonallenross View Post
Oh yeah, and don't cheap out and try and blow gas out of the filter.
I just run the tank dry before I change the filter.
That way you suck up all the crap in the tank and deposit in the old filter, too. It's a win-win.
fliz is offline   Reply With Quote
Old 03-20-2008, 04:08 PM   #27
gusto
Member#: 58323
Originally Posted by MrMcCrackin View Post
gas in the eyes wasnt a fun event at all
which is why you ALWAYS point the lines towards the windshield IMMEDIATELY!
the cowl makes a great catch basin.
gusto is offline   Reply With Quote
Old 03-20-2008, 04:10 PM   #28
MrMcCrackin
Member#: 89202
I'm # 1 when it
comes to # 2
what about the filter sock on the freakin fuel pump?
MrMcCrackin is offline   Reply With Quote
Old 03-20-2008, 04:13 PM   #29
Mike Wevrick
RIP 1/19/64 - 7/23/11
Member#: 24654
1957 Taggart Comet
atlasshruggedpart1.com
Originally Posted by Wagon Joe View Post
A little squirt of WD-40, and a small set of vice grips, cushioned by a rag works well for me. Squeeze the vice grips down (not too tight) and rotate back and forth to break the hose loose. Then just yank 'em off with your hands.
This is the way to go. Let the WD40 soak in a bit first.
Mike Wevrick is offline   Reply With Quote
Old 03-20-2008, 04:13 PM   #30
Grap
Member#: 6590
or the pump burning up?
Grap is offline   Reply With Quote
Old 03-20-2008, 04:13 PM   #31
fliz
Member#: 30342
That gets rinsed every time you fill up...don't worry about it.
Old 03-20-2008, 04:14 PM   #32
jasonallenross
Member#: 125978
2002 WRX Wagon
I get a gallon or two of paint thinner and mix it in, myself. Better get some so I can mix it in on the next tank.
Sometimes a gallon or two of diesel can free stuff up, too. It's an oil so it seeps into the fuel line junctions and makes them easy to free up.
jasonallenross is offline   Reply With Quote
Old 03-20-2008, 04:16 PM   #33
DiscoGsus
Member#: 47646
0511 RallyBaja
DGM Sedan
Or the fact that you are replacing the fuel filter because its NOT working anymore...
DiscoGsus is offline   Reply With Quote
Old 03-20-2008, 04:16 PM   #34
MrMcCrackin
Member#: 89202
I'm # 1 when it
comes to # 2
so in other words - your not really suckin anything up into the fuel filter and cleanin the tank out
premature pump failure
Old 03-20-2008, 04:20 PM   #35
Thunder Lungs
Member#: 33677
1980 2 feet
caucasian
I used the pointy end of a large zip-tie, smeared some petroleum jelly on it and worked it up under the line. Just do that all the way around then it'll just slide right off. Use a twisted up paper towell to wipe any excess out of the line before you put the new filter on.
Thunder Lungs is offline   Reply With Quote
Old 03-20-2008, 04:24 PM   #36
DrDRum
Member#: 41589
Suff erer Club
Founder (RGSSC)
Smack at it with your coch
DRum
DrDRum is offline   Reply With Quote
Old 03-20-2008, 04:24 PM   #37
teh Phil
Member#: 24888
2016 Outback Limited
make sure you wear safety glasses - the first time i did this, i forgot the system was under pressure
....Unless you take the filler cap off to de-pressurize the system.
I second the vice grips + rag approach.
teh Phil is offline   Reply With Quote
Old 03-20-2008, 04:25 PM   #38
poison
Member#: 37678
Originally Posted by Stanley View Post
Dude. It's a bitch. I paid the guy at the corner gas station $20 to do mine and was happy to do so!
I'm going this route. Screw the damn things, ****!
poison is offline   Reply With Quote
Old 03-20-2008, 04:26 PM   #39
MrMcCrackin
Member#: 89202
I'm # 1 when it
comes to # 2
yep - i forgot step 1 and step 2
step 1 - disconnect the negative battery terminal
step 2 - remove gas cap
i did use a pair of plyers to twist the lines so i could pull them off by hand
Old 03-20-2008, 04:30 PM   #40
Wagon Of Fury
Member#: 47982
Wagon Of Fury is offline   Reply With Quote
Old 03-20-2008, 04:39 PM   #41
Manarius
Member#: 106258
2005 Subaru Outback
1. Disconnect fuel pump fuse.
2. Crank car for a few seconds
3. Use padded pliers to take the tubes off.
4. Replace filter.
Not that hard
Manarius is offline   Reply With Quote
Old 03-20-2008, 04:43 PM   #42
STR8OUT
Member#: 15533
2010 Dodge Ram Hemi
boat, dirt bikes, bobcat
I remember doing this when I installed my Supra pump...
I didnt depressurize the system and it sprayed fuel everywhere, I was like "please god dont let me DIAF " while laying in my trunk
STR8OUT is offline   Reply With Quote
Old 03-20-2008, 04:43 PM   #43
under pressure
Member#: 92776
2004 VF48 Wagon
6 gear speeding
you hump thos fuel lines into submission!!! that\'s how it works!!! GET SOME!!
but seriously, sometimes it\'s not easy.
under pressure is offline   Reply With Quote
Old 03-20-2008, 05:07 PM   #44
rogue
Member#: 7977
100% Abuse
Originally Posted by Fish View Post
heat it up with a lighter..
the rubber will soften and be easier to remove..
rogue is offline   Reply With Quote
Old 03-20-2008, 05:17 PM   #45
02blueru
Member#: 80012
04 BMW M3
Ducati 620 Dark / 08' 848
Ha, my hands are all beat to **** after removing the fuel lines from the fuel pump twice last night (forgot to reconnect the electrical plug on the pump after completely putting the car back together ) I was furious
The fuel filter hoses were not easy either.
02blueru is offline   Reply With Quote
Old 03-20-2008, 05:46 PM   #46
flystiguy14
Member#: 74416
91 SS leggy
pearl white
It's actually really simple when you have the technique down. What you do is you get a small flatblade screwdriver and pry the edge of the hose up a little bit and spray some wd40 or brake cleaner in the hose and they come straight off.
flystiguy14 is offline   Reply With Quote
Old 03-20-2008, 05:47 PM   #47
rogue
Member#: 7977
100% Abuse
you're all doing it wrong
I pulled the lines off my fuel pump on my 96 Outback with 160k for the first time last week.
WD-40 or PB Blaster, spray, wait, then some judicious pliers. Bingo!
Old 03-20-2008, 06:08 PM   #48
Jard
Member#: 34935
Dad- Core
OG
Originally Posted by kaisersouse View Post
rofl at 150k mine came off easy because i didn't treat them like they were made of glass and were attached to a ferarri
I like this reply.
Jard is offline   Reply With Quote
Old 03-20-2008, 06:14 PM   #49
EZ Rider
Member#: 38224
I miss
my Subie.
Can the mods please move this to OT?
EZ Rider is offline   Reply With Quote
Old 03-20-2008, 06:18 PM   #50
two88
Member#: 167776
You can buy a set of reverse pliers. When you squeeze the handle they spread whatever you have gripped. Makes short work of suby fuel line removal.
two88 is offline   Reply With Quote
How the heck do you get an ebay TMIC to fit? Mr Nice Guy Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 17 07-14-2007 10:19 AM
How to change an fuel filter on an '02 wrx wagon d4ygl0 Service & Maintenance 19 12-28-2005 02:31 PM
How in the Heck do you get the perrin BOV hose on? waitandbleed92 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 02-16-2004 07:53 PM
How often do you get bad gas (not that kind) jmaiken Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 10-19-2003 04:16 AM
Once struts are off how the hell do you get them back on? spshultz Brakes, Steering & Suspension 10 07-03-2002 12:39 AM
