#51 |
Member#: 48401
SCIC
Vehicle:2015 EFR7163 STI Dark Grey Metallic |
![]() Awesome build, I'm coming close to my install/tune day. And I've been tossing the idea around of just dropping a turbo In while I'm at it. I'm just worried about the longevity of the motor. If this is something the 15 STI Can handle IM wondering if going the 2.5xtr will be okay as well?
I'm in ca so I have awesome 91 (sigh) but I'm going to be doing the Cobb flex fuel kit as well. Basically with same set up as the op car but with a tomei elh tomei inlet and tomei dp 3" all the way to the catback. So should I do it? @brentuning
#52 |
Member#: 418410
![]() Same question: If I am at stage 1 right now on my '15 STI and with a custom tune putting down 301 whp at 18psi using 91 grade fuel, what would it realistically cost me (parts and labor) to put down 400+ whp? And how reliable would my engine be for the next 8 years as a daily driver?
#53 | |
Member#: 363268
Vehicle:2015 WRX STi WRB |
![]() Quote:
It's a difficult question to answer. I've modified before and I can tell you it's better to over build and scale back during the tune, than to tune to the limits of your build. That's why I like this setup, can out put decent power without being at the limit of the parts. If you can't afford to replace a motor with 400+ hp, you can't afford 400+ hp. It's why my garage is full of parts and my engine is still stock. Last edited by carlos.danger; 02-24-2016 at 02:33 PM. |
#54 | |
Member#: 418410
![]() Quote:
#55 |
Member#: 363268
![]() Is this your first subaru?
If you were to build exactly the car in the op of this thread you are looking at about $5k including installation and tune. And no, there are no easy big engine swaps into these cars. Last edited by carlos.danger; 02-24-2016 at 03:16 PM. |
#56 |
Member#: 418410
![]() Yes, my first. $5k... That's doable. What's the reliability like?
#57 | |
Member#: 363268
![]() Quote:
This is an impossible question to answer. Once you start modifying you lose reliability. It's as easy as that. Reread the very first post in this thread. According to brentuning, they openly consider this setup and their tune a relatively.safe and comfortable setup for dd while adding power. These aren't camrys. And they aren't corvettes. They are sensitive to mods and you need to take this into consideration when you start down that hill. |
#58 |
Member#: 418410
![]() Right on, thanks for the information, I appreciate the feedback. Reliability vs. Performance, the tradeoff. Sort of like power vs. endurance in athletic training. Yin and Yang.
#59 | |
Member#: 508105
NWIC
Vehicle:Link flex tuned 02 WRX EJ205 20G-XTR JDM 6MT |
![]() Quote:
20 psi heavily indicates pump gas but 415/390 on a Dynocom on a 20G is very nice. ![]() Last edited by K3rm1tth3fr0g; 11-27-2021 at 12:47 AM. |
#60 | |
Member#: 130990
NWIC
Vehicle:06 Red Ltd.Wagon Dom 1.5xtr JJ tuned |
![]() Quote:
Edit: This same setup made about 340whp on the Mainline Dyno. Last edited by Dave D.; 11-27-2021 at 06:30 PM. |
#61 | |
Member#: 508105
NWIC
![]() Quote:
John and I are currently deciding if we are going to use the VP X85 for my flex fuel tune, or if a separate map should be created for the VP fuel which is technically "race gas". Otherwise we would use pump E for my flex tune, and I imagine E70 vs E85 won't make too much difference on my lil 205. E70 allows most setups to hit MBT anyway... |
