Welcome to the North American Subaru Impreza Owners Club Wednesday November 22, 2017
Old 05-19-2017, 01:29 AM   #1
gmrebman
Member#: 431811
2005 wrx sti
grey
Default HELP!!!!!...question on what oil to use
Hello all. so I switched to Rotella t6 about a year after owning my 05 sti, because a lot of people responded saying that that is the best oil to use because of the engine running hotter, or maybe it was because of how that oil adheres to the internals of the motor.
anyways, I just finished watching a youtube video and someone with a 06 sti was using Rotella t6 and stopped because (I can't remember which he said) he said it stained the motor or scarred the motor. so is there a better oil I can use? my 05 sti has just bolt on's and a tune, tuned rich as requested to help the motor last as long as possible.
so yeah, is there a different 5w40 oil, or maybe just a completely different weight of oil that I should use. and then having used it for about a year, is there anything I can do to undo what has happened to the motor, if in fact anything has happened?
gmrebman is offline   Reply With Quote
Old 05-19-2017, 01:38 AM   #2
fuelMuncher
Member#: 301554
2002 WRX Wagon
PSM, 2007 OBP WRX Limited
Ams Oil
fuelMuncher is offline   Reply With Quote
Old 05-19-2017, 01:50 AM   #3
Miles901
Member#: 436453
I use redline 5w40, top quality oil IMO
Miles901 is offline   Reply With Quote
Old 05-19-2017, 01:50 AM   #4
oaklandish_WRX
Member#: 267339
2002 0[[XXXXoXXXX]]0
MBP LongRoof
RT6 is just fine. If you are worried, do a blackstone oil analysis with TBN. Read the stickies in the service/maint forum for oil selection. Youtube is for cat videos, not oil analysis.
oaklandish_WRX is online now   Reply With Quote
Old 05-19-2017, 08:21 AM   #5
Titter
Member#: 416107
2002 WRX Wagon
EJ207 Spec C 4EAT
seriously? another oil thread?
there should be some algorithm that if anyone makes a topic with the words "help" and "oil" in the same topic, it logs them out or bans them or something. this is getting rediculous.
there are literally thousands of threads on oil topics. go search. stop playing candy cruch while you poop and maybe read something.
Titter is offline   Reply With Quote
Old 05-19-2017, 09:09 AM   #6
bluesubie
Member#: 767
04 FXT
That video is nonsense. It is not the oil's fault. T6 is fine to use but it's certainly not the "best" oil. Here's a great comment on BITOG:
"I don't understand the fascination with T6. I think people see it's "add-pack" and get a chub, when that is only one small part of the much bigger picture. There's a lot that doesn't show up in a VOA test. EDGE 0W-40 seems like a no brainer".
https://bobistheoilguy.com/forums/ub...pics/4368349/1
Look for an oil that meets these specs:
ACEA A3/B4
API SERVICES SN / CF
BMW LL-01
MB-Approval 229.5
Porsche A40
And read this:
https://forums.nasioc.com/forums/sho....php?t=2714154
Old 05-19-2017, 04:17 PM   #7
RexBoostRally
Member#: 466935
"german" castrol edge 0w40.
RexBoostRally is offline   Reply With Quote
Old 05-19-2017, 05:34 PM   #8
g-heap
Member#: 403883
These "german castrols" seem widely available now, at least here in CA (at walmart). They are labelled "european formula" on the bottle, and priced similar to M1 and other synthetic motor oils.
g-heap is offline   Reply With Quote
Old 05-19-2017, 06:39 PM   #9
White_Wagon_
Member#: 457564
2006 Wrx Wagon
I second on this one!! I've used it for almost 2yrs.
White_Wagon_ is offline   Reply With Quote
Old 05-19-2017, 07:15 PM   #10
mrsaturn7085
Member#: 375462
2006 Impreza WRX STI
WR Blue
Motul X-clean 5w40 if you have a cat.
Motul X-cess 5w40 if you don't.
mrsaturn7085 is offline   Reply With Quote
Old 05-19-2017, 07:32 PM   #11
424wrx
Member#: 171948
08 wrx stg3 vf52
14 legacy, 11 fozzy
i recently changed from t6 to liquid moly 5w40. seems like a quality oil and is made in germany. anyone else use this before???
Old 05-19-2017, 11:57 PM   #12
EngineHacker
Member#: 462060
Pick one oil and stick with it. The dynamic range between the very best and the very worst isn't enough to justify wasting money or time. As others have said, RT6 is perfectly fine. There are many other alternatives, it honestly doesn't matter unless your car is tracked. If you want your internals to be clean, perform an oil flush every oil change using a detergent pour-in additive. Oddly enough, I don't use RT6 but it has nothing to do with its quality. For me, RT6 is actually too expensive relative to its quality. If you still can't make up your mind, read this to satisfy your oil porn needs.
https://forums.nasioc.com/forums/sho...2714154&page=8
EngineHacker is offline   Reply With Quote
