Welcome to the North American Subaru Impreza Owners Club Wednesday July 18, 2018
Old 05-22-2008, 10:21 PM   #1
Mightyeldo44
Member#: 180453
2002 Wrx
Default Follow UP on v34 stock up pipe/misfires
My last thread got deleted so this is just an up-date. ok so what i belived to be a stock up pipe to the v34. turned out to be a stock (gutted) up pipe. So i took the turbo in anyway and its still good. But i alrady overnighted a new aftermarket up-pipe, so i installed it anyway. And guess what the car runs exactly the same. it runs perfect unless under full boost (wich i have set at 15 becuse at 19 i got boost spike) so it will get to around 4000rpm and start choking and sputtering till redline in 3rd 4th and 5th gears. then ocasionaly throw a flashing p0304 (misfire in #4) code.
I still have the coolant leak from some where.
The car still has the 93 octain tune, while im running 90octain with the timing set back 3 degres across the board.
but the car was running fast with this tune untill i put the 3 inch down pipe back on and got boost spike so i turned down the boost and now im getting this sputtering/choking/misfire under full boost. any ideas?
Mightyeldo44 is offline   Reply With Quote
Old 05-22-2008, 11:17 PM   #2
03WRX-WRB
Member#: 167879
2013 Xv Crosstrek
Tangerine orange pearl
your still running rich,
03WRX-WRB is offline   Reply With Quote
Old 05-23-2008, 02:45 PM   #3
Aprice40
Member#: 79811
I have a pretty similar setup. 02 bugeye with vf34 catless. I had similar problems with high boost, i was overboosting bad, and actually had fuel cuts because of over boost.
I just got it protuned, and the tuner noticed that i was actually running very lean with the Cobb ots vf34 map and that was causing a bunch of issues. not sure if you are having a similar problem but once i got tuned im running great, not nearly as lean, much safer map.
Aprice40 is offline   Reply With Quote
Old 05-23-2008, 11:43 PM   #4
Mightyeldo44
Member#: 180453
2002 Wrx
Yeah the sputtering feels exactly like the fuel cuts i was getting with boost spike. i dont think theres anywhere to get a pro tune within around 400 miles of here though.... so any other ideas? the car is on the turbo xs stage 4 base map i belive.
Old 05-24-2008, 09:00 AM   #5
sidewayz
Member#: 5810
2001 S366 2.5RS
thats a shock
sidewayz is offline   Reply With Quote
FS: 04 WRX Stock down pipe, stock up pipe, and stock springs LitosWhtWRX SCIC Private Classifieds 6 01-30-2008 03:02 PM
Messed up on modding stock injectors, want to buy one! josh04 Rocky Mountains Impreza Club Forum -- RMIC 0 07-14-2006 08:23 PM
Fuel gauge doesn't go all the way up on a fill up lupohki Service & Maintenance 4 05-09-2005 05:26 AM
What other Perfomance Muffler can bolt right on the Stock Mid pipe! SONofSAM Normally Aspirated Powertrain 1 04-15-2002 05:10 PM
Follow-up on M + S Tires on '02 WRX rssmith Brakes, Steering & Suspension 0 06-09-2001 01:26 PM
