Welcome to the North American Subaru Impreza Owners Club Monday October 15, 2018
Old 07-25-2005, 02:48 PM   #1
brandon_bxtr
Member#: 78255
2015 STi
Crystal White Pearl
Default Is anyone running a EBC with Cobb stage2.5???
I am getting ready to install a EBC on my '02 WRX. However, I am currently running Cobb's stage 2.5. I have heard that Cobb's maps are fairly mild on power and are rich on fuel. Due to this, I was thinking that running an extra 1-2 lbs. of boost would be fairly safe. I was just wondering if anyone was currently running a EBC with their stage 2.5 and what kind of results or recommendations you could give me. Thanks in advance.
brandon_bxtr is offline   Reply With Quote
Old 07-25-2005, 03:27 PM   #2
bren wrx
Member#: 59454
'10 E92 M3 M-DCT
brentuning.com/blog
protuner or blow your motor
bren wrx is offline   Reply With Quote
Old 07-25-2005, 03:34 PM   #3
brandon_bxtr
Member#: 78255
2015 STi
Crystal White Pearl
I appreciate the reply, but a more detailed explanation would be great.
Old 07-25-2005, 04:02 PM   #4
Funkmonster
Member#: 82114
2004 WRX
Try it and let us know
Seriously I agree with Bren. While it sounds like it might be a good idea in theory, generalizations like that don't usually hold true. Engine management is a little bit more complicated than that.
Funkmonster is offline   Reply With Quote
Old 07-25-2005, 04:15 PM   #5
Hayaboosted
Member#: 60042
2004 WRX STI
Rotated T67 ALLABOUTSPEED
Yeah I would only reccomend using a MBC or ABC if you dont reach target boost from say a mechanical problem such as a weak or broken wastegate spring. If your looking to add boost your better off finding someone with the protuner. Not only will you add boost, but power safely. Good luck!
Hayaboosted is offline   Reply With Quote
Old 07-25-2005, 05:30 PM   #6
flwrx
Member#: 35944
'03 EJ207/30R/G4+
MBP
I agree. Without datalogging with wideband and EGT's I wouldnt feel confident doing that. There are some people who arent overly rich on the basemaps. Besides, timing and fuel need to be optimized to make more power....its not all just adding more boost.
flwrx is offline   Reply With Quote
Old 07-26-2005, 10:04 AM   #7
brandon_bxtr
Member#: 78255
2015 STi
Crystal White Pearl
Thanks everyone, I appreciate the replies.
cobb stage2.5 v.17 swift2fly Engine Management & Tuning 2 04-17-2005 02:53 PM
ok to run helix top mount ic with cobb 2.5? anthonyrb98 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 03-09-2005 07:07 PM
running lean with cobb 2.5? cheese tits Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 03-01-2005 07:56 PM
Anyone running a EBC along with a reflashed ECU? MidRex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 03-23-2003 01:01 PM
Is anyone running an EBC with stock Gauge? Dew-Subaru Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 02-21-2003 12:35 AM
