Welcome to the North American Subaru Impreza Owners Club Thursday March 28, 2024
Old 12-20-2020, 08:39 PM   #1
Baru-barage469
Member#: 518883
Default grinding noise after wheels were changed
06 impreza wrx. , turbo , downpipe , 80k miles :
so at low speeds and turning i hear a bad grinding sound coming from what im 99% sure is my wheels as it just started happening when i put my winter steel rims on. I havd a feeling its a easy fix , i took the rear wheels off ( sounds like where the problem is) and tired spinning them and felt a little tough to spin. any input greatly appreciated
Last edited by Baru-barage469; 12-20-2020 at 08:47 PM. Reason: didnt include enough info
Baru-barage469 is offline   Reply With Quote
Old 12-20-2020, 09:39 PM   #2
snow_bound26
Member#: 395793
2005 92x Aero
Beige
Pull the calipers off and makes sure you don't have debris stuck between the rotors and pads. If not then what did you use to tighten the lug nuts and to what torque are they tightened? Over tightening the lug nuts can cause premature bearing wear.
snow_bound26 is offline   Reply With Quote
Old 12-21-2020, 09:49 AM   #3
rtv900
Member#: 428511
2016 STI
huh
How?
rtv900 is offline   Reply With Quote
Old 12-21-2020, 07:55 PM   #4
snow_bound26
Member#: 395793
2005 92x Aero
Beige
Originally Posted by rtv900 View Post
huh
How?
What I was taught by my grandfather who was a mechanic for nearly 45 years. I'm not referring to setting your torque wrench 5-10lb/ft higher than recommended. But a lot of people just slap them on with an impact and call it a day. I should have been more specific and said over tightened and unevenly tightened.
Old 12-21-2020, 08:40 PM   #5
Baru-barage469
Member#: 518883
well ya i set all the lugs finger tight so they were all even then used an impact gun in a criss cross pattern for about a second each time i pulled the trigger till the lugs didnt move any more (2x) for all the 5 lugs which never gave me any probldms before with my summer tires so i doubt thats the problem. could my offset somehow have something to do with it, the winter rims fit on fine.
Old 12-22-2020, 06:21 AM   #6
Zak6182
Member#: 481754
2017 STi Base
If its that bad it should be pretty easy to see metal to metal contact. Pull the wheels off and look on inside of rim and throughout wheel well. Using a light might make it easier to spot fresh metal being nice and shiny. And yes your offset can cause issues.
Also, I have put thousands of tires on in my life/career and used just an impact (after starting lug nuts by hand). I'm not saying there's not a torque rating and using an impact is the 100% correct way to do. I'm saying I have done it (just like you did) and never had an issue.
Zak6182 is offline   Reply With Quote
Old 12-22-2020, 12:35 PM   #7
Absoluteyeti
Member#: 519596
97 Impreza OBS
Red to be white
I don't think that's universally true anymore... Drums don't like overtightening, most discs (i've seen) are indifferent. Has to do with how and where the bearings are seated. Not advocating uggadugga spec however as it destroys studs.
Absoluteyeti is offline   Reply With Quote
Old 12-22-2020, 05:25 PM   #8
snow_bound26
Member#: 395793
2005 92x Aero
Beige
Maybe. I haven't seen anything contradictory to what I've learned. My take on it is manufacturers provide a torque spec for a reason. I agree there's room to spare on their rating most of the time but pressure is pressure. The more you apply, the more something will change its shape no matter how slightly. With bearings, it's not going to destroy them quickly but if a bearing usually lasts for X amount of miles at 77lb/ft then it's safe to conclude it will last Y miles at 100lb/ft and so on. What's really going to make the difference if unequal tightening. Using nothing to measure the pressure, one doesn't know if a lug is tightened to 60, 100 or 150lb/ft. And if one is substantially tighter than another it will change shape. Hence why wheels wobble when tightened unevenly. I'd guess that this would increase wear over equally over tightening all the lugs. Since the OP has been using an impact to tighten things and really doesn't have a way of measuring torque then it could wear the bearings out faster. Especially since each lug will be tightened to a different spec. Though I'd still say it's more likely debris in the rotor. Possibly stuck in the parking brake.
Old 01-15-2021, 01:58 AM   #9
Baru-barage469
Member#: 518883
so my car is still making a bad grinding sound at low speeds. the noise also gets alot worse when i turn left or right aswell. i have checked for debris and metal contact on all rims and nothing as i did a tire rotation and alignment just recently, so anything anyone has would help alot as this is an annoying noise that needs to cease
Old 01-15-2021, 07:15 AM   #10
Absoluteyeti
Member#: 519596
97 Impreza OBS
Red to be white
It could be bearings/differential roasting. It would be more coincidental if it started when you replaced your wheels unless the wears were extremely uneven.
Old 02-27-2021, 09:39 PM   #11
SubiSIR07
Member#: 461885
If it is getting louder while turning left or right I would guess it is a rock or debris stuck between your caliper and rotor or rotor and dust shield. This is a strange but common occurrence on Subaru's for some reason. I've had it happen on every single one I've owned.
SubiSIR07 is offline   Reply With Quote
Old 02-28-2021, 11:32 AM   #12
CaptainSlowbaru
Member#: 445600
2002 Outback Sport
Green
Make sure the backing plate isn't bent and contacting the rotor. Also, these backing plates tend to rust, expand and contact the rotor near the parking brake shoes. The best thing to do is remove the rotor and look for contact markings.
CaptainSlowbaru is offline   Reply With Quote
Old 03-05-2021, 12:29 AM   #13
sdigitty
Member#: 455570
2015 WRX
Did you have hub centric rings on the wheels you removed?
A long time ago I did a tire swap in the dark and totally failed to account for all hub centric rings on the wheels I removed.
I tighten the new wheel on and smashed the old ring... That gave some interesting noises the next day.
Lesson learned.
sdigitty is offline   Reply With Quote
