Welcome to the North American Subaru Impreza Owners Club Saturday July 2, 2022
Old 05-19-2022, 12:06 PM   #951
4S-TURBO
Member#: 67807
.... adjust your
pants everyone
And literally nobody will buy one in Canada. Which is why they have to make it cheap as ****.
Old 05-19-2022, 02:48 PM   #952
heavyD
Member#: 194216
2022 Fast POS
Pretty much. I don't think this car will sell well up here at this pricing as it's considerably more than the 370Z that nobody up here bought. You will see 3+ M2's for every 370Z up here. Canadians don't like to pay $$$ for non-luxury brands.
heavyD is offline   Reply With Quote
Old 05-19-2022, 04:52 PM   #953
Skunkers
Member#: 115480
2014 Mazda3 sGT
Soul Red
Originally Posted by godfather2112 View Post
Regardless of AMS or not, I’m just curious if a heat exchanger upgrade is required no matter the manufacture. On the M2C, a heat exchanger upgrade is highly recommended for a stage 1 flash regardless of company. Can you get away without doing it? Sure but I wouldn’t chance it. Depending on location, that heat exchanger it could cost a hefty penny.
My understanding is one of the changes for the Z vs the Q60 is improved cooling. The cooling system was redesigned and has bigger heat exchangers vs the Q50 Red Sport even, so probably not an issue.
Skunkers is offline   Reply With Quote
Old 05-19-2022, 05:11 PM   #954
4S-TURBO
Member#: 67807
.... adjust your
pants everyone
Not to mention a 4-500 lb weight difference between those two cars.
Old 05-20-2022, 01:14 PM   #955
jimmi
Member#: 172959
'16 Ford GT350, '08
EvoX GSR,01 EclipseGT SDS
I wonder how much it is to add the LSD aftermarket? I added one to a Mitsu DSM for $700 (sure it would be more now) plus labor. If you can swap it for a reasonable price then the base plus the upgrade could make sense as long as the cooling and other drivetrain mechanicals are there.
jimmi is offline   Reply With Quote
Old 05-20-2022, 06:12 PM   #956
godfather2112
Papi Chulo
Member#: 53794
... 2017 BMW M2
2017 F-150
I wouldn’t be surprised if a quality lsd went for $2000-$2500, not installed.
godfather2112 is offline   Reply With Quote
Old 05-20-2022, 06:18 PM   #957
Kostamojen
Member#: 2272
2019 Macan 4cyl
1993 Impreza FWD WRX swap
I think aftermarket diffs for that housing are roughly the same as Subarus, so probably around $1500. Budget for $2500 total. More if you have custom work done to said diff.
Old 05-20-2022, 06:56 PM   #958
4S-TURBO
Member#: 67807
.... adjust your
pants everyone
The Nismo diff cooler is like 2300.
Old 05-20-2022, 08:40 PM   #959
rmbrady
Member#: 6228
2017 SS
There's a ton of options available here, but it looks like you could get one for $1500 ish on the low end.
https://www.z1motorsports.com/z1-pro...0aAkWwEALw_wcB
Sent from my SM-S906U using Tapatalk
rmbrady is offline   Reply With Quote
Old 05-23-2022, 05:57 PM   #960
Kostamojen
Member#: 2272
2019 Macan 4cyl
Interesting discussion about the Z... Apparently the new car might have some issues with being driven hard.
Old 05-23-2022, 06:57 PM   #961
bemani
Member#: 5673
05 LGT, 02 WRX
Hellcat CTR LC500
http://youtu.be/XH4E1SEaWV4
Wonder if the LFB going limp thing can be disabled with full TC off.
bemani is offline   Reply With Quote
Old 05-24-2022, 12:46 AM   #962
Pre
Member#: 139693
Dura ngo 95
horrorshow
What did Jason say exactly? That deal is an hour.
Old 05-24-2022, 01:13 AM   #963
Kostamojen
Member#: 2272
2019 Macan 4cyl
It's a podcast, just listen to it when driving or something.
Old 05-24-2022, 07:41 AM   #964
jimmi
Member#: 172959
'16 Ford GT350, '08
Not sure you all listened to the whole thing. The engine has cooling issues when they tested the preproduction car in the Infinity. He repeated several times the engine in the 400z had NO issues despite them beating on it hard for 3 or so days.
Old 05-24-2022, 07:54 AM   #965
SVX WRX
Member#: 26358
2018 RS 400
a common upgrade to the Infiniti's 3.0T is a heat exchanger to prevent heat soak.
i never had that problem in mine, but i have a Red Sport that has a secondary water pump and an oil cooler. i also don't redline it every time my foot touches the pedal.
SVX WRX is offline   Reply With Quote
Old 05-24-2022, 08:59 AM   #966
Sid03SVT
Member#: 183032
RWD Camry
Pull me over red
The "issues" discussed were more about invasive safeguards, even with nannies "turned off" while doing "professional driver, closed course" stuff (drifting, rolling burnouts, banging gears, etc.). But the real world implications were discussed, as the vehicle does not react in a manner that would be expected
-kills power mid-slide because you touched the limiter, resulting in an unexpected directional change and/or looping the car due to the short wheelbase
-will not allow a brake stand style burnout
-ECU pulling power when trying to shift quickly (without flat-foot shift mode turned on) in an attempt to save the clutch
-touching the limiter cuts power significantly as apposed to modern stuff that lets you bounce off of it.
-ECU won't allow the engine to rev up quickly in neutral when stopped
There is more, just listen to it.
Sid03SVT is offline   Reply With Quote
Old 05-24-2022, 10:34 AM   #967
DougNuts
Member#: 192568
2015 Outback 3.6R
'18 F150, '21 RAV4 XSE
Sounds like Nissan knows their base.
DougNuts is offline   Reply With Quote
Old 05-24-2022, 10:34 AM   #968
heavyD
Member#: 194216
2022 Fast POS
Yeah it looks like Nissan neutered the car to an extent to ensure the engine lasts through the warranty period. He even states that it's not build like a BMW or Porsche to be able to withstand a beating.
Old 05-24-2022, 10:42 AM   #969
godfather2112
Papi Chulo
Member#: 53794
... 2017 BMW M2
2017 F-150
I listened to first 3/4 of it so far. Not the most glowing review
Old 05-24-2022, 10:45 AM   #970
heavyD
Member#: 194216
2022 Fast POS
Well he's being fair in that he says Nissan didn't have a lot of money to put this together so I think their engineers did the best they could with a limited budget. Hopefully the ECU could be cracked so the nannies could be disabled although that may reduce the life expectancy of the drivetrain. There's a reason this car costs less than the Supra and it's because you get what you pay for.
Old 05-24-2022, 11:54 AM   #971
godfather2112
Papi Chulo
Member#: 53794
... 2017 BMW M2
2017 F-150
That’s kind of disappointing and a ****ty way to send out the last gas powered Z car. I know times are different but it’s still not a cheap vehicle. Guess we will have to wait for more reviews, sales and how quickly they end up on used lots.
Old 05-27-2022, 06:02 PM   #972
chanomatik
Member#: 159474
2017 Impreza Sport
Lithium Red - OLDKID
Old 05-31-2022, 03:59 PM   #973
arghx7
Member#: 232940
you gotta love reviewers trying to abuse press cars beyond what a normal customer would do during the warranty period
arghx7 is offline   Reply With Quote
Old 05-31-2022, 04:28 PM   #974
heavyD
Member#: 194216
2022 Fast POS
What? That's kind of the point of performance car reviews. Most normal customers don't do 0-60 mph, skidpad, slalom, track testing, etc.
Old 05-31-2022, 04:29 PM   #975
Pre
Member#: 139693
Dura ngo 95
horrorshow
Same. I waited until it was chores time at the house and stuck around until it turned into old Z 2000GT nerd fest. Pretty damning. If the base had a LSD or you could add it as an option for a couple k to the base I think it would be a solid value. Most people are posers and would never push the car into the limp issues and safety nanny interference they spoke of. But for the people that actually drive the car as it was supposed to be designed for, yeah a big let down and no way in hell would I buy the performance trim over the Supra.
I am very surprised that Jason went into as much detail as he did. That’s not common as they fear the press people at X and Y mfr’s. The Twins are a much better value and spend a few k more for the Supra. You’ve got better low and high options.
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
Powered by Searchlight © 2022 Axivo Inc.
