Welcome to the North American Subaru Impreza Owners Club Saturday January 19, 2019
Old 06-08-2017, 12:03 PM   #76
TJ_Madden
Member#: 456296
2017 WRX
Ice Silver
I have Cobb Big SF, I had brand new spark plugs with my knock issues.
TJ_Madden is offline   Reply With Quote
Old 06-08-2017, 12:15 PM   #77
Eatsleepturbo
Member#: 468983
well, as I said before, I will get the valves cleaned next week and if the problem is not solved I will drive the 1.5 hours i need to drive to get some 94 and see if there is any differences... I will keep you updated guys
Eatsleepturbo is offline   Reply With Quote
Old 06-08-2017, 02:16 PM   #78
fredrik94087
Member#: 337075
2015 WRX Stg3 SOLD
A 32oz of Torco will be enough...you don't have to drive 1.5 hours. Just order it online.
It does work and it is different than what you will find at your neighborhood auto parts store. And, it won't harm your cats nor O2 sensors.
fredrik94087 is offline   Reply With Quote
Old 06-08-2017, 04:16 PM   #79
Eatsleepturbo
Member#: 468983
well I have read that it has some side effects. It leaves a deposits on the sparks plugs. Some red stuff.
You might be righ and trying this once shouln't be a problem, but I have a few other things to do around so, 1.5h isn't the end of the word...
The problem is that if it works (94), I dont know what i can do since the guy in the topic has the same problem; with a pro-tune...
Old 06-08-2017, 05:01 PM   #80
TJ_Madden
Member#: 456296
2017 WRX
Ice Silver
Yup, my tuner also recommended torco. I have 93 Shell VPower where I live so 4oz of torco per a full tank of gas does the trick.
Old 06-15-2017, 09:23 AM   #81
Eatsleepturbo
Member#: 468983
So, as promisses I got my valves cleaned. As I got the car back, I did a quick ride and the DAM came back to 1... I tought that the problem was solved. But as you probably thought, the next day, when I was driving back from work, it quickly crashed to 0.250. I guess it did not solved the problem... I will get that tank of 94 soon. If it makes any differences, I will contact a protunner...
Old 06-19-2017, 08:39 AM   #82
Eatsleepturbo
Member#: 468983
So quick update guys, on Friday I drove to get a tank of 94. When I arrived at the station I had a bit less than ¼ of the tank left. I filled up with 94 and drove back home. After about 5 km my DAM was back to 1. I drove for about 50 km then I stopped. It was still at 1 but it moved a bit during the ride. Then for the rest of the weak end I did about 200 km, my DAM did not move! And it was a hot weak end! About 35 degree and a lot of humidity. I guess I need to find a tuner so I get a protune that can run on 91 Québec gaz. I don’t want to drive 1 hour every time I need to get some gaz ! lol
I guess CharlieRotten has a similar problem…
edit : my friend has the same problem with a few other mods. He is at the tunner to day. Its a good shop and they can't tune the car with the gaz he has. They will empty the tank and retry with some 94.... it dosent make any sense !
Old 07-25-2017, 06:12 PM   #83
freakshow999
Member#: 471651
2015 Forester XT
Quartz Blue Pearl
My Stage 2 Protune is/was having very similar problems. My Stage 1 was rock solid same tuner.
I'd following @spitman1 's approach to MAF tuning. I've been reading a lot the past couple of days regarding the FA20DIT tuning strategies as. Watching my gauges on my AP it really looked like a load related AF issue.
I had been doing a lot of data logging but was doing my calculating all wrong.
I ended up on an opensource tuning forum and they were discussing/diagnosing/developing tuning strategies regarding weird knock issues certain load ranges usually at cruising speed and under low calculated load. This includes accelerator position switches in MAF correction say between 15% and 20% throttle. Where the AF correction was out of whack at 15% but 0.00 at 20%.
It all starts with getting your MAF Scaling within 2-4% across the entire voltage range.
freakshow999 is offline   Reply With Quote
Old 09-01-2017, 12:45 AM   #84
CharlieRotten
Member#: 449073
2017 WRX
Here's a little update for those who may be still having issues.
Since my last post, I have been driving the car at 3500 ish rpm most of the time. My MPG's have dropped significantly but, my DAM has stayed around 1 or .816+ most of the time. I still get fbk and fkl showing as much as -4.8 but mostly stay around -2.81.
My biggest curiosity at this point is why some people with the exact same mods as me do not have any issue at all, and others have similar issues.
It also boggles my mind how the guy who tuned my car insists that its heat related and that a FMIC, header, and e85 is going to fix it when the issue happens whether my intake temps are 150f or 60f.
I did show a massive DAM drop trying to climb up a very large mountain road last week and it didnt seem like my rpm really mattered much during that drive.
So that points me toward calculated load readings.
Anyone know of a tuner in Colorado with more FA20 tuning knowledge than my last tuner that would be feeling charitable? lol
CharlieRotten is offline   Reply With Quote
Old 11-03-2017, 10:53 AM   #85
TJ_Madden
Member#: 456296
2017 WRX
Ice Silver
Hey Charlie,
Bren Tuning & I may have had a break through with the issues we have been having. My car through a CEL P0332 for a knock sensor 2 low input. This was their first time really diagnosing this code on the 2015+ WRX. Bren said they have a handful of cars with knock issues like ours they really couldn't resolve. However, now we are thinking The faulty knock 2 sensor could be the culprit. Since the change my car is running perfectly without octane booster.
Old 11-21-2017, 11:48 PM   #86
sisenor
Member#: 86929
2016 WRX Ltd.
WR Blue
Hey Charlie,
Any update on this? Did you replace your sensor??
sisenor is offline   Reply With Quote
Old 11-22-2017, 01:12 AM   #87
TJ_Madden
Member#: 456296
2017 WRX
Ice Silver
Yes replaced knock 2 sensor, 500 miles later knock 1 sensor failed and threw a CEL. Today Bren replaced knock sensor 1 and retuned my car. Since my last protune i added the ACT SB5-HDSS clutch kit but resurfaced my OEM flywheel. I also added the Boomba BPV. To my surprise I had huge gains. I went from 301 whp to 320whp. My torque also increased from 307 to 340.
Btw this car is only 1 yr old with 18,000 miles.
Old 11-22-2017, 10:42 PM   #88
TJ_Madden
Member#: 456296
2017 WRX
Ice Silver
Default FA20DIT DAM, FBK, and FKL issues
Here is the video from my retune
Old 12-19-2017, 04:52 PM   #89
CharlieRotten
Member#: 449073
2017 WRX
Hey Charlie,
So you had the CEL the whole time? I haven't ever had a CEL other than for the cat right after the tune but my tuner turned that off. (high flow cat)
Since I've been driving the car at 3500 rpm I have had much less FBK FKL and DAM drops. It does still happen but not as often. Im getting 20mpg now tho haha so that kind of sucks but oh well. Maybe I'll Hit up Bren Tuning and see what they say. I always wonder if being in Colorado with the elevation has anything to do with it but I haven't really found anyone out here with anywhere near the same issue.
Old 12-19-2017, 10:01 PM   #90
TJ_Madden
Member#: 456296
2017 WRX
Ice Silver
No my CEL came later. First was knock sensor 2 and then 500 miles after replacing knock sensor 2 I got the CEL for knock sensor 1. I would recommend replacing them as a pair if one fails or if you have knock issues your tuner cant seem to iron out and really doesn’t know why. Bren also mentioned they have had a handful of FA20s with similar knock issues that they could never figure out. The knock sensors could be the culprit.
Old 07-17-2018, 01:07 PM   #91
Subie_Sweets
Member#: 488449
Hows the car running now?
Subie_Sweets is offline   Reply With Quote
Old 07-24-2018, 11:49 PM   #92
TJ_Madden
Member#: 456296
2017 WRX
Ice Silver
Car is good! No CELs since. Only issue since was a leaking egr gasket because I had it unplugged. So I deleted it and added an IAG AOS at the same time.
Old 07-25-2018, 03:03 PM   #93
bcterp
Member#: 409569
2018 WRX
A little off topic but how long did you have the egr unplugged before it started leaking? Also was there any need to retune when going from unplugged egr to deleted? I’d assume not.
bcterp is offline   Reply With Quote
Old 07-25-2018, 09:21 PM   #94
TJ_Madden
Member#: 456296
2017 WRX
Ice Silver
I was unplugged for about 1 year, and no I have not had to retune.
Old 09-17-2018, 05:29 PM   #95
Jmcole0372
Member#: 491574
Default Any more updates here?
I’m just starting to tune and would love to know what’s coming. Best gas I have is 91 oct. will be doing etune as I live in the middle of nowhere.
Jmcole0372 is offline   Reply With Quote
Old 10-15-2018, 05:09 PM   #96
ragnar007
Member#: 492740
2018 WRX
Did you call Harvey and ask him about it?
ragnar007 is offline   Reply With Quote
