Welcome to the North American Subaru Impreza Owners Club Tuesday October 16, 2018
Old 12-06-2003, 12:33 AM   #1
[MRT.SUX]
Member#: 49574
Default Turbonetics T58 on 2 litre
hi guys, has anyone here fitted a Turbonetics T58 on a 2 litre?
I wanna know if its too big for it, what rpm's does it come on boost etc etc and any other comments and info would be great
[MRT.SUX] is offline   Reply With Quote
Old 12-06-2003, 01:38 AM   #2
STEALTH-WRX
Member#: 7822
Multi layer snot green
well there are so many factors that will determine when "boost will come on". Now are we talking about a bone stock 2.0 liter or a built one.
STEALTH-WRX is offline   Reply With Quote
Old 12-06-2003, 01:54 AM   #3
[MRT.SUX]
Member#: 49574
nah not stock. Its got 3 inch exhaust, front mount intercooler, 500hp fuel pump and injectors, pod filter, external wastegate.
stock internals though, so probably keep it at max 18psi
So is it too big for a 2 litre???
Old 12-06-2003, 01:55 AM   #4
STEALTH-WRX
Member#: 7822
well, when i mean stock, i was refering to the internals. what are the specs on the turbo. a/r? trim?
Old 12-06-2003, 02:06 AM   #5
[MRT.SUX]
Member#: 49574
i'm not 100% sure, i think it was .70 comp and 1.14 exh
I'll double check with the shop but they are not open until monday
Old 12-06-2003, 02:08 AM   #6
STEALTH-WRX
Member#: 7822
thats a huge turbine side. that will be laggy on a stock 2.0. what kind of power are you looking for (to the wheels). what are you planning on doing with the car; street, drag, road racing?
Old 12-06-2003, 02:11 AM   #7
STEALTH-WRX
Member#: 7822
this will spool faster and flow more
http://shop.store.yahoo.com/cheaptur...t3w82artu.html
Old 12-06-2003, 02:12 AM   #8
STEALTH-WRX
Member#: 7822
Old 12-06-2003, 02:24 AM   #9
[MRT.SUX]
Member#: 49574
uh oh. How laggy are we talking here??
If it hits 18psi at 4,500-5,000 rpm then thats acceptable to me, i'd be happy with that
It will be a daily driver but will be doing alot of drags with it
aiming at around 350 horses at the wheels.
I know the turbo will be more than capable of doing that without nos as well, i'm more worried about day to day drivablity on the street
if the lag is gonna be that bad, i'll do a 2.2 rebuild in a few months
Old 12-06-2003, 02:28 AM   #10
STEALTH-WRX
Member#: 7822
are you familiar with my build? i get 18 psi at 4400 rpm and 30 psi at 4900 rpm. I dont think you will get boost that early.
Old 12-06-2003, 02:37 AM   #11
totoherbs
Member#: 7321
.... 122 IggPoints
Work... ahhh... so tired.
Get a 2.2 block before you rebuild a 2.0 to 2.2, a us sti block might be the cheepest and a lot easyer....
I wouldnt use a tubo that large on a stock block with the stock redline, maybe an block with a 8-9k redline.
totoherbs is offline   Reply With Quote
Old 12-06-2003, 02:43 AM   #12
[MRT.SUX]
Member#: 49574
no i'm new to this forum
may i ask what turbo you have??
18 psi by 4400rpm is excellent, I'd be happy with that
Old 12-06-2003, 02:47 AM   #13
totoherbs
Member#: 7321
.... 122 IggPoints
He is running a big 2.5 Liter... If you search under his name you will come up with his info.
Old 12-06-2003, 02:49 AM   #14
STEALTH-WRX
Member#: 7822
here is what i have. you may want to read in detail.
http://forums.nasioc.com/forums/show...hreadid=426987
Old 12-06-2003, 02:52 AM   #15
[MRT.SUX]
Member#: 49574
LMFAO no wonder it spools so early
Old 12-06-2003, 02:57 AM   #16
[MRT.SUX]
Member#: 49574
That is one crazy car my man
Alright then, how about a turbonetics T04E on my 2 litre??
Old 12-06-2003, 03:00 AM   #17
STEALTH-WRX
Member#: 7822
I would go with a garrett gt series turbo or a t3/to4e turbo. maybe a 50 trim stage 5.
Oh yeah, how come MRT sucks? just curious.
Old 12-06-2003, 03:08 AM   #18
Redline8k
Member#: 2968
Beat it to fit,
Paint it to match!
I have a JDM Ra-c motor and Im thinking about a 50-1, 52-1, or a 60-1 not sure I have to little more research but something like that. 305-375 hp on pump fuel and 450 or so on c-16
let me know what you guys think
-nick
Redline8k is offline   Reply With Quote
Old 12-06-2003, 03:11 AM   #19
totoherbs
Member#: 7321
.... 122 IggPoints
-nick
http://forums.nasioc.com/forums/show...hreadid=439666
Clarks seems to be liking his... good luck.
Old 12-06-2003, 03:12 AM   #20
STEALTH-WRX
Member#: 7822
if you have the money, go with the gt series from garrett. I would not go with anything else. My next turbo will be a gt series. maybe ill sell my turbo soon.
Old 12-06-2003, 03:15 AM   #21
[MRT.SUX]
Member#: 49574
GT series are very expensive here in Australia. Often double or almost double the price of old the T series. Unfortunately outta my price range
Old 12-06-2003, 03:17 AM   #22
STEALTH-WRX
Member#: 7822
thats because they are much better, last longer, flow more, and have incredable spool.
Old 12-06-2003, 04:17 AM   #23
0db
Member#: 33879
2003 WRX Sporkwagon
the T-series turbos (not T3 or T04) are intended for LARGE engines. A small-block V8 takes some time to spool a straight T-series turbo.
You might get away with running a T58 COMPRESSOR on a smaller (T3-series) turbine... but you better be shooting for a LOT more than 350hp before you put a straight T58 on ANYTHING.
0db is offline   Reply With Quote
Old 12-06-2003, 10:07 AM   #24
Rickyh
Member#: 40453
where are you going to get an up and down pipe to fit those turbos? I imagine that you are going to fabricate them
Rickyh is offline   Reply With Quote
Old 12-06-2003, 11:57 AM   #25
Pavlo
Member#: 23015
95-> GC8
Black, blue and blue
Surge will be an issue on a T58, although the flow of the turbo isn't actually that massive.
You will be surge limited to about 1 bar at 3500, and about 1.5bar at 5000rpm on a 2.0l engine.
Spool up will depend heavily on the turbine side, the compressor isn't that big of a wheel (in terms of innertia).
Paul
Pavlo is offline   Reply With Quote
Anyone using Perrin EBCS w/ UTEC on WRX stock 2 litre? overdose Engine Management & Tuning 3 04-22-2005 12:33 PM
Tommy Kaira 2.2-litre STI illustration shirokuma Interior & Exterior Modification 27 05-21-2002 04:44 AM
2.2 litre Wagon ScoobySnackZ General Community 4 05-10-2002 11:49 AM
2.2 litre turbo kits car_freak85 Normally Aspirated with bolt-on Forced Induction Powertrain 18 05-05-2002 06:11 PM
Tommy Kaira 2.2-litre B4 TT test drive shirokuma Legacy Forum 8 03-13-2002 08:53 PM
