Welcome to the North American Subaru Impreza Owners Club Tuesday October 23, 2018
Old 04-24-2016, 08:28 PM   #3401
Wills03rexwagon
Member#: 198008
2003 Impreza WRX wgn
Yeah they seep fuel on cold starts and them go away when its warmed up...thats thermal expansion for you
Wills03rexwagon is offline   Reply With Quote
Old 06-26-2017, 12:45 PM   #3402
Wungus
Member#: 469961
The inside of my wrx has a very strong smell of gas. I was wondering if it has anything to do with the bov because it sits right on top of the engine. I also have a turbo back exhaust system so could that be part of the issue? Are there any other factors that could lead to this like a fuel line leak and would i still be under that free fix from the dealer? I just bought this car and i need it to be inspected soon so a quick reply would be great. Thanks.
Wungus is offline   Reply With Quote
Old 06-26-2017, 03:20 PM   #3403
Superorb
Member#: 135252
2002 WRX Wagon
If you can smell raw fuel there is fuel leaking somewhere, just have to find it. BOV, exhaust, none of that has anything to do with the fuel system. Inspect all of the fuel lines and fittings that you can see. If you have an 02-07 pay special attention to the rubber hose between two metal lines at the front of the motor by the intake manifold.
Superorb is offline   Reply With Quote
Old 06-26-2017, 04:09 PM   #3404
Wungus
Member#: 469961
Thanks for the reply i will look into that. I do have another question because when coming to a stop the car likes to stall and i was wondering if giving the mass air flow sensor a clean would solve that problem or cleaning out the iac or the throttle body would help.
Old 06-26-2017, 04:15 PM   #3405
Superorb
Member#: 135252
2002 WRX Wagon
Certainly couldn't hurt things.
Old 06-26-2017, 06:06 PM   #3406
sajohnson
Member#: 6140
2002 WRX 5MT Sedan
WR Blue. Cobb Stage 2
It's unlikely that the fuel leak is a result of the problem that was/is the subject of the recall, because that leak happened in cold temps -- generally well below freezing.
I first noticed mine leaking when it was 7 degrees outside and very windy.
sajohnson is offline   Reply With Quote
Old 09-02-2017, 10:34 AM   #3407
waynlewis
Member#: 219948
07 Sti
I have an 07 sti w/194k and the raw gas smell has started getting stronger. I took the car to the dealership and they performed a smoke test. The tech noted that smoke was coming from someplace on top the fuel tank and recommended changing both roll over valves and vent valve. Does/did anyone have experience with this issue and fixed it themselves? Any tips and/or part numbers? Was it a hose or clamp failing?
Thanks in advance for any help.
waynlewis is offline   Reply With Quote
Old 01-24-2018, 09:09 AM   #3408
slickraft
Member#: 469298
Let's continue this 2002 thread into 2018!
Not that it gets that cold here in Phoenix but my 03 WRX has begun to have the raw gas smell problem after about 1 mile of driving on a cold (35F) morning. Problem goes away later in the day and I don't smell it at all driving home when it is 65-70F. Time to check some hoses and clamps.
Thanks to all who keep this site up and running. I've only had my bugeye a few months now and this place has helped immensely. Just about to turn 180K miles.
slickraft is offline   Reply With Quote
Old 01-24-2018, 11:07 AM   #3409
Superorb
Member#: 135252
2002 WRX Wagon
You won't be able to get to the problem clamps without removing the intake manifold which is a royal PITA on a car this old. Prepare to break plenty of hard lines, clips, etc.
On my wife's non-turbo Forester all clamps are fairly easy to get to.
Old 01-25-2018, 03:08 AM   #3410
sajohnson
Member#: 6140
2002 WRX 5MT Sedan
What Superorb said.
IIRC, SOA allowed ~6-1/2 hours for the job, and my understanding is that it usually took longer -- and that was for a factory trained Suby tech.
Not trying to discourage you, just giving you a heads-up.
If you rarely drive in the cold it may not be worth doing the repair -- at least not at this time.
Raw Fuel Smell Inside Cabin - WRX Kenneth2000 Warranty Issues & SOA Problems 13 12-21-2012 10:28 PM
Raw Fuel Smell/Leaking Fuel Line on WRX pumpkyn Rocky Mountains Impreza Club Forum -- RMIC 39 02-09-2009 11:50 PM
Raw Fuel Smell.... Rebellion South East Region Forum 7 01-25-2005 09:48 AM
Raw Fuel Smell Giljorak Rocky Mountains Impreza Club Forum -- RMIC 10 03-08-2002 07:03 AM
