Welcome to the North American Subaru Impreza Owners Club Friday October 19, 2018
Old 01-08-2004, 12:56 PM   #201
DetroitWRX
Member#: 18777
2002 WRX Wagon
Sedona Red Pearl
I put mine in but couldn't find the printout with the number I have. Are people putting them under Impreza or WRX? I used WRX but if we all agree to one then they will be together and have a greater number.
Rob
DetroitWRX is offline   Reply With Quote
Old 01-08-2004, 02:40 PM   #202
Jon [in CT]
Member#: 2992
02 WRX Sedan
For those who have this problem but can't get it fixed free by the dealer, you might wish to consider the pre-TSB solution, which is to simply tighten one of the fuel return line hose clamps. sube151 describes (with pictures) how he cured his problem in this thread from Jan, 2002 (two years ago):
http://forums.nasioc.com/forums/show...hreadid=138069
Jon [in CT] is offline   Reply With Quote
Old 01-08-2004, 03:22 PM   #203
BIGSKYWRX
Member#: 7958
09 GH B+
I put mine under WRX and IIRC something along the line of fuel- lines,connectors,etc
Jon- tightening one may possibly cure the problem and worth a shot, but your dealing w/ tandem lines w/ clamps at each end- thus four to potentailly tighten. Unfortunately you can't get at these damn clamps and even when you can (after removing the turbo inlet pipe and unfortunately unless you take off the intake manifold the oem has to be hacked to get it out and aftermarket one used ie silicone) two are upside down (from the assembly no doubt) and still very difficult to tighten.
The other thing I noticed w/ the TSB is they are actually changing the configuration of the lines w/ longers sections of soft fuel line (vs hard lines). I don't know if this was simply more readily available or somehow contributes to the fix?
I still feel this is a potential safety issue. Even if you happened to know about the TSB and could get it fixed, there are a lot of folks oblivious to this potential problem- ie someone from the warmer climes who would may never get the fuel smell, but decides to visit Grandma up "north" and at the wrong time has fuel dribbling out onto a hot engine or other potential igniton.
Big Sky
Old 01-08-2004, 05:20 PM   #204
no_rex_yet
Member#: 7351
04 330cic
Woohoo, I just got a call from the NHTSA stating they have recently opened an investigation on the issue based on the complaints and Subaru's TSB! I missed his call, so I'll be talking to them tommorow.
Everyone keep posting to the NHSTA site!
no_rex_yet is offline   Reply With Quote
Old 01-08-2004, 06:43 PM   #205
banman
Member#: 12408
2006 Legacy GT
Does NHTSA care about non-US vehicles? Is there a similar website for Canadians?
banman is offline   Reply With Quote
Old 01-08-2004, 06:57 PM   #206
DetroitWRX
Member#: 18777
2002 WRX Wagon
Sedona Red Pearl
They care about every car on public roadways.
Jon in CT thanks for that post with the pictures I didn't find it in my serch of this issue. I bumped it up some everyone can see it.
Rob
Old 01-08-2004, 07:35 PM   #207
Captain Ned
Member#: 36144
2010 Legacy2.5GT Ltd
Graphite Gray Metallic
ODI #10052686
Captain Ned is offline   Reply With Quote
Old 01-08-2004, 07:36 PM   #208
fliz
Member#: 30342
Just happened to me today.
known causes/triggers
Car sat for two days in <15 degree weather
location of smell's origin (if known)
Under the hood. I had the fan on when I started the vehicle, and immediately noticed the smell. Popped the hood and I could smell the fuel, but was in a hurry so I couldn't look too closely.
date of manufacture
07/02...Engine Number 629781
any mods to your car
Catless UP, Samco IC hoses
fliz is online now   Reply With Quote
Old 01-08-2004, 09:46 PM   #209
BIGSKYWRX
Member#: 7958
09 GH B+
Looks like the ball is starting to roll guys-good job!
If your getting the fuel small be sure to take five minutes and fill out the requested info here:
http://www-odi.nhtsa.dot.gov/ivoq/
Big Sky
Old 01-08-2004, 10:35 PM   #210
banman
Member#: 12408
2006 Legacy GT
I tried to fill it in but got a database error - might have to do with the non-US address.
Old 01-08-2004, 10:44 PM   #211
BIGSKYWRX
Member#: 7958
09 GH B+
I got that to, then went to the nonsecure one and it worked fine- don't know why it didn't work?
Old 01-08-2004, 11:50 PM   #212
banman
Member#: 12408
2006 Legacy GT
I was using the non-secure one as well . . . I couldn't even get through on the secure option.
Old 01-09-2004, 08:53 AM   #213
no_rex_yet
Member#: 7351
04 330cic
Well, last night I tried tightening that one clamp as seen here, http://forums.nasioc.com/forums/sho...threadid=138069, and it worked like a charm!
My dealer wanted me to wait 30 friggin days for the TSB parts to come in, but NASIOC saves the day! Now, with people posting how the TSB didn't work, I'm not even sure I want the dealer monkeying under my hood.
Has anyone who performed the "clamp" fix had the problem recur?
Old 01-09-2004, 10:38 AM   #214
xstar
Member#: 10821
2008 WRB STi
This happened to me today.
Where: Massachusetts
Temp: < 0F all night and I started the car around 2F
Fuel smell the entire trip to work.
Called dealership and they said it was normal.
I scheduled an appointment anyway.
Currently in the middle of filing a complaint with NHTSA.
thanks everyone.
xstar is offline   Reply With Quote
Old 01-09-2004, 11:23 AM   #215
tnbd
Member#: 5993
no_rex_yet - The clamp on my WRX was tightened in march when I first experienced the fuel leak. In November the leak was back when the temps hit -10F. The dealership replaced bits per the TSB and it was covered under the extened warranty. Since then, we have had weather down around -5F since and the leak has not recurred.
tnbd is offline   Reply With Quote
Old 01-09-2004, 11:33 AM   #216
no_rex_yet
Member#: 7351
04 330cic
Thanks, looks like I'll have the dealer perform the fix when the parts come in. Keeping my fingers crossed until then.
Old 01-10-2004, 09:25 PM   #217
REXY WAGON
Member#: 11618
2013 Focus ST
Addd me to that list as well , Car sat outside for about 75 mins in 17-20 deg f today we got a very strong fuel smell for about 10 min. But tomorrow i'll tighten up clamps and file a complaint,40,500 MILES Thanks everyone safe driving Colm
REXY WAGON is offline   Reply With Quote
Old 01-11-2004, 01:07 AM   #218
2k2
Member#: 12368
2008 Infiniti G35X
2011 BMW X5 Diesel
Add me to the list.
Car sat for 2 weeks in a parking lot then onto a lift for 2 days to fix it after a wreck. Drove it for the first time today in about 10 deg F or so.
didnt notice a smell at first, sears noted to me that when they were aligning it they had a STRONG smell of gas fromt he vents and almost wouldnt do the alignment.
I smelled gas the second I moved my A/C vents to outside. Did not drive the car much at all today.
Tommorow morning I will be looking for the clamp and try to tighten it down.
build date is sometime in 01 will check tommorow
odometer 37005
Full turboback exhaust and Turboxs Type H BOV
2k2 is offline   Reply With Quote
Old 01-11-2004, 04:09 PM   #219
TimStevens
Member#: 4817
Noticed this today as I was heading out for a drive Only noticed it at stoplights and as I was pulling away.
Car sat for two days in sub-zero temperatures.
date of manufacture
01/01, IIRC
No mods
TimStevens is offline   Reply With Quote
Old 01-11-2004, 04:14 PM   #220
BIGSKYWRX
Member#: 7958
09 GH B+
Posting here is helpful.
Posting here will likely get this resolved for everyone:
Big Sky
Old 01-11-2004, 04:31 PM   #221
TimStevens
Member#: 4817
Already done.
Old 01-11-2004, 07:09 PM   #222
steveo
Member#: 52365
2002 wrx
blue
Angry fuel smell
WRX at dealer for 2nd time for fuel smell, took pics on way to dealer and pic in service bay of fuel stain on block under manifold.
filed complaint with nhtsa also. glad to hear something is under investigation.. hope with tsb and pics and cold weather this week they will actually try to fix it!
steveo is offline   Reply With Quote
Old 01-11-2004, 08:35 PM   #223
UKscooby
Member#: 33287
RIP Nik
I will always miss you
Add me to the list.
2002 WRX Wagon, 37500 miles.
I thought this was from cars i was following, but then i had it when i was warming it up outside the house for a few minutes, and i could hardly breath when i got inside.
Will be speaking to my dealer in the morning.
Ive also noticed that since ive had this smell im getting a hollow ticking/knocking sound in tune with engine speed when its under hard load, from around 2500 to 4500 rpm. Im worried that this may be detonation caused by fuel starvation.
It was bad enough for my wife to even notice it.
James.
UKscooby is offline   Reply With Quote
Old 01-12-2004, 12:30 PM   #224
steveo
Member#: 52365
2002 wrx
blue
Smile NHTSA Investigating Problem
Hey
Got a call this morning from NHTSA, said matter is under investigation, due to the nature of the smell/leak and potential danger. And they have had a flood of calls and emails on this matter, so if anyone else has not reported the problem to them, please do!
Maybe subaru will actually have to do a recall this defect.
Old 01-12-2004, 01:03 PM   #225
Scottie
Member#: 2080
06 Impreza Wagon
Red
I've submitted my complaint to the NHTSA.
Dealer would not fix for free despite TSB 09-36-03.
Besides being a safety issue, I would think that this would be an evaporative emissions issue as well. It's required that the Check engine light come on if our gas cap isn't screwed on tight enough. A fuel leak direct in to atmosphere circumvents all such provisions.
Anyone know where and how to file a complaint with the EPA?
P.S. My dealer wanted $375 to fix the problem. I refused. I'm going to see what I can do myself.
Scottie is offline   Reply With Quote
Raw Fuel Smell Inside Cabin - WRX Kenneth2000 Warranty Issues & SOA Problems 13 12-21-2012 10:28 PM
Raw Fuel Smell/Leaking Fuel Line on WRX pumpkyn Rocky Mountains Impreza Club Forum -- RMIC 39 02-09-2009 11:50 PM
Raw Fuel Smell.... Rebellion South East Region Forum 7 01-25-2005 09:48 AM
Raw Fuel Smell Giljorak Rocky Mountains Impreza Club Forum -- RMIC 10 03-08-2002 07:03 AM
