01-07-2018, 07:19 PM | #1 |
Member#: 428540
STi Not hitting target boost
Hey guys, i'm having troubles with my tuned 2012 sti car not hitting target boost, i checked the vacuum lines and everything seems kosher, also disconnected the battery terminal and pumped the brakes, then tried again right after that, with the same effect. I understand this means its not a tuning related issue, but a mechanical one, so i logged on Romraider and i noticed the wastegate duty cycle going to 0 after the car hits 11 or so psi. My question is the waste gate the issue?
https://docs.google.com/spreadsheets...it?usp=sharing
01-07-2018, 11:04 PM | #2 |
Member#: 6176
Vehicle:15 WRX, 04 wrb STi 85 wrb BRAT |
Not a tuner or expert, but I would say because it's detecting knock feedback for though the entire run, it may also be limiting boost to prevent more knock. I've read 0 to -2 on occasion is nothing to worry about constant or over 2 should be checked out.
But because it's detecting knock does not mean you have knock. Loose or rattling engine components (heat shield, a/c lines...) could fool the knock sensor. |
01-08-2018, 02:21 AM | #3 | |
Member#: 428540
01-08-2018, 09:55 AM | #4 |
Member#: 231700
Vehicle:2004 WRX Wagon WRB |
The WGDC is only going to 0 after you let off the throttle. If you weren't having any issues previously with the tune, then the current issue is likely mechanical as you suspect.
01-08-2018, 11:30 AM | #5 | |
Member#: 428540
Ahh I see, any idea what mechanical issue might be the culprit? I've checked the post turbo lines and the 3 port ebcs connections and all seems in order |
01-08-2018, 01:47 PM | #6 |
Member#: 231700
What is your target boost and what mods do you have?
01-08-2018, 01:57 PM | #7 |
Member#: 428540
01-09-2018, 11:46 AM | #8 |
Member#: 231700
Can you log the relative target boost instead of absolute? That way it would show exactly what boost the ECU is calling for.
01-09-2018, 12:51 PM | #9 |
Member#: 428540
