Welcome to the North American Subaru Impreza Owners Club Monday January 21, 2019
Old 05-17-2010, 08:14 PM   #101
Robstunner
Member#: 134222
2015 WRX Limited
ISM
how did you get the reflector piece out (that holds the projector in)
Robstunner is offline   Reply With Quote
Old 05-17-2010, 08:57 PM   #102
Robstunner
Member#: 134222
2015 WRX Limited
ISM
i have the projector lens and lens holder out, but im afraid im going to break the holder trying to get the lens out;
Old 05-17-2010, 09:06 PM   #103
Robstunner
Member#: 134222
2015 WRX Limited
ISM
nvm got it all
Old 05-20-2010, 10:55 AM   #104
Robstunner
Member#: 134222
2015 WRX Limited
ISM
Old 05-20-2010, 10:59 AM   #105
CarbonXe
Member#: 211237
82 XJ 750
92 YJ 4.0
I saw the shot in the 08+ thread, it was a lot easier than you expected it to be, wasn't it?
CarbonXe is offline   Reply With Quote
Old 05-20-2010, 11:02 AM   #106
Robstunner
Member#: 134222
2015 WRX Limited
ISM
yea it was, i couldnt figure out how to take the high beam reflector piece out, so i had to work around it. backing out the adjuster all the way near the low beam, and high beam gave me enough room to unscrew the projector bowl, the lens holder, as well as giving me the ability to take out the lens holder and lens. Once i did the first one, the second one was done in like 30mins.
thx for the help, the difference is totally worth the $35 (hell, even if they were the performance ones for $65 id say its totally worth it)
Old 05-20-2010, 11:42 AM   #107
steverx05
Member#: 128269
Originally Posted by Robstunner View Post
The new lens output looks a MILLION times better than the stock one. Very nice...I might have to add this to my list of future projects.
steverx05 is offline   Reply With Quote
Old 05-20-2010, 11:43 AM   #108
Robstunner
Member#: 134222
2015 WRX Limited
ISM
thanks! for $35 it may be the best bang for the buck ive gotten!
(sorry for thread jacking OP)
Old 05-20-2010, 11:47 AM   #109
CarbonXe
Member#: 211237
82 XJ 750
92 YJ 4.0
Not thread jacking, it's still on topic :P.
Old 05-20-2010, 02:33 PM   #110
heresmymind
Member#: 169537
1999 Legacy GT
05 Wrx Swap
if you make a custom shield using allum flashing you can get a MUCH better cutoff with those clear lenses. This is the output of the same projector with custom shield. notice the cutoff is sharp the whole way, it doesnt bow towards the ends. GJ with retro though!
-B
heresmymind is offline   Reply With Quote
Old 05-20-2010, 02:39 PM   #111
Robstunner
Member#: 134222
2015 WRX Limited
ISM
Slick!
Old 05-20-2010, 02:46 PM   #112
CarbonXe
Member#: 211237
82 XJ 750
92 YJ 4.0
Damn that is nice as hell. I'm more than satisfied with my cutoff though. I just don't want to go through the hassle of ripping apart my headlights again.
Old 05-20-2010, 02:52 PM   #113
heresmymind
Member#: 169537
1999 Legacy GT
05 Wrx Swap
here is the cutoff of my old TSX retro
-B
Old 05-25-2010, 02:00 AM   #114
greddy90
Member#: 147065
The ballast the OP used, are they the OEM ballasts? If so, what years of sti used that specific ballasts?
greddy90 is offline   Reply With Quote
Old 05-25-2010, 08:19 AM   #115
CarbonXe
Member#: 211237
82 XJ 750
92 YJ 4.0
I don't know if the 06/07 STI used those ballasts, i can only confirm that the 08+ STI used them.
And yes, they're OEM.
Old 05-26-2010, 06:44 PM   #116
ugetworked311
Member#: 39792
nice write up!
ugetworked311 is offline   Reply With Quote
Old 11-29-2010, 12:00 PM   #117
mark729
Member#: 149138
11 WRX STi
Lightning Red
Use one of the new lenses to push all of the clips out, then push the rounded edge of the stock lens in, it will pop right out. So put the new lens inside the holder, so the flat surfaces are back to back.
Just got back from taking a ton of pictures, uploading now.
I wish you have pictures of this process.
mark729 is offline   Reply With Quote
Old 11-29-2010, 12:02 PM   #118
Robstunner
Member#: 134222
2015 WRX Limited
ISM
Ive done it, and in elgin if you need a hand
basically you just push the backside of the new lens up against the backside of the old lens taht being held in there. That pushes the clips out from holding the old lens in place. Then you can install the new lens. Its really simply once your actually looking at it.
Old 11-29-2010, 12:18 PM   #119
mark729
Member#: 149138
11 WRX STi
Lightning Red
Big Thanks neighbor
I also saw your post on IWST and was thinking about asking you to help me out when I swap the lens someday soon. haha
Old 01-25-2011, 04:01 PM   #120
durtydurt
Member#: 235745
2011 WRX 5dr
Does any wiring need to be modified for this or does the stock 09-11 WRX headlight harness plug right into the ballast as is?
durtydurt is offline   Reply With Quote
Old 01-25-2011, 11:55 PM   #121
SAMSNEED
Member#: 54600
2006 STI
CGM
Just got my lens today form Matt at The Retrofit Source, I just drove there and picked it up. The lens fit right in and was very easy to swap. By far the best $50 mod I've ever done. Here is my cut-off and color lmk if it is correct. My camera sucks.
SAMSNEED is offline   Reply With Quote
Old 01-26-2011, 05:10 AM   #122
Sideways
Member#: 6295
2016 WR Blue WRX #7
what this guy said.
Sideways is offline   Reply With Quote
Old 01-26-2011, 10:04 PM   #123
SAMSNEED
Member#: 54600
2006 STI
CGM
how do you make a custom flashing
-B
Old 01-26-2011, 11:32 PM   #124
draco159
Member#: 204121
2005 WRX Wagon
CGM
I believe you cut to fit, but I'm no expert by any means
draco159 is offline   Reply With Quote
Old 01-27-2011, 12:46 AM   #125
steverx05
Member#: 128269
Unless you work with projectors a lot and have the tools and a lot of time for trial and error testing, I wouldn't bother trying to make my own cutoff shield. Just do it right and start off with a nice HID projector from the start.
My WRX...Now With 100% More Car Frog DonkeyPunch Member's Car Gallery 60 10-13-2007 11:38 AM
2006 Aspen White STI pics.. now with 100% more Gram Lights SCRAPPYDO Member's Car Gallery 12 09-18-2007 07:23 PM
The Exeter Subaru meet june 18th- $25 06 STi raffle- now with 100% more autox Keith New England Impreza Club Forum -- NESIC 129 06-19-2006 03:13 PM
My SVX, now with 100% more STi! Bwana Member's Car Gallery 48 05-21-2005 12:27 AM
Impreza: Now with 100% more STi lip action Versus Member's Car Gallery 36 04-16-2005 09:58 PM
