Welcome to the North American Subaru Impreza Owners Club Monday October 22, 2018
Old 06-19-2017, 02:22 PM   #1
TheColorCute
Member#: 265589
2004 Slow 6466 STi
Default 2004 STi | PTE 6466 | 93 octane | 28psi | 538whp/486wtq
Event: Dyno pull
Ambient Temp: ~80 F
Elevation: 95ft
Weather: Warm and muggy
Car: 2004 STi
Tuner: Nick @ VEMS
Dyno Info: DynoMite with Mustang dyno brakes (Eddy brakes)
Transmission: 6spd
Gear: 4th
Peak HP at RPM: 538whp @ 6,850
Peak Torque at RPM: 486tq @ 5,200
Baseline hp/tq for a stock on same dyno: Unknown
Target Boost: 28psi
Target AFR: 11.3
Fuel: 93 octane pump
Engine/Power Modifications:
Block:
IAG closed deck
Pinned mains
O-rings
IAG 14mm headstuds
Manley Turbo Tuff rods with ARP 625+ rod bolts
IAG Spec 99.75mm pistons with .210 wrist pins
ACL Race bearings
Manley billet crank
ARP Main bolts
Heads:
GSC 272 cams
GSC beehive springs and titanium retainers
Manley 32mm Extreme Duty exahust valves
Manley 36mm Extreme Duty Raceflo intake valves
Turbo/fueling/exhaust/drivetrain:
Precision 6466 with T4 Divided 1.15a/r
Twin TIAL 38mm external wastegates
Custom twin-scroll up pipe
Custom downpipe
Custom AOS
Custom FMIC
Invidial N1 Race midpipe and muffler
JDM EL headers
Bosch 2000cc injectors
DeatschWerks 300lph surge pump
Custom fuel rails
Twin Bosch 044 fuel pumps
Rotated intake manifold
KoyoRad radiator
Cobb Speed Density via Cobb AccessPort V3
Hallman Pro MBC
Fuelab FPR
KillerB oil pickup
KillerB oil baffle
TGV deletes
Aluminati motor/transmission/pitchstop mounts
Additional driveline and suspension modifications
Loaded the car up onto the dyno at VEMS a couple weeks ago. It put down 538whp/486tq @ 28psi on 93 pump gas, no methanol. This was done on a Dynomite dyno with Mustang dyno breaks (Eddy brakes.) We've just about hit the efficiency limit on what 93 octane can handle for boost, so we're going to have to pop in some methanol or race gas and see what it can do! The car revs to 8,200 RPMs on 93 octane, but we cut this dyno chart off earlier.
TheColorCute is offline   Reply With Quote
Old 06-19-2017, 02:44 PM   #2
Dave D.
Member#: 130990
06 Red Ltd.Wagon
20gxtr JJ tuned
That's pretty incredible running that much boost and at that temp. What kind of IAT's are you running? I'd just love to cool my intake temps down more -- tougher with a TMIC, I know, but still, it must be more than just a FMIC doing the job. Any extra secrets you'd care to share? Nice numbers!
Old 06-19-2017, 02:55 PM   #3
TheColorCute
Member#: 265589
2004 Slow 6466 STi
Thank you! IATs were in the 140s on back-to-back runs at redline. As far as secrets, airflow is obviously very important throughout the car. The shop should have a good dyno fan to provide enough airflow to the car under WOT. If a fan is only spinning at 30mph, and the car is running WOT at 100mph+ on the dyno, the IATs are going to spike because the car isn't seeing that 100mph worth of nice cool airflow that it would normally get on the actual road
Old 06-19-2017, 04:50 PM   #4
user1029
Member#: 57064
2008 STi IAG built
HTA86 E85 Kel272s Cos IM
Nice numbers, the turbo and motor are not even breaking a sweat
Time to crank it up to 40psi on E85
user1029 is offline   Reply With Quote
Old 06-19-2017, 05:00 PM   #5
TheColorCute
Member#: 265589
2004 Slow 6466 STi
Thank you! The motor and turbo definitely have tons more power in store!
I wish that we had E85 here. No E85 stations anywhere in VT . My best bet is C16. I'm planning to do a C16 run sometime soon, just for the fun of it haha. Then I'll run a 50/50 water/methanol mix as an everyday thing
Old 06-25-2017, 04:30 AM   #6
CEEBEE
Member#: 420458
07 WRX STI
Urban Grey
Sweet setup!Would be an animal on E85!
CEEBEE is offline   Reply With Quote
Old 06-25-2017, 07:25 AM   #7
Lance123
Member#: 301663
2004 JDM WRX Wagon
Originally Posted by TheColorCute View Post
Thank you! IATs were at about 1600, but my IAT sensor isn't in the most ideal place, so we kept things on the safer side and decided not to push the IATs up even further. As far as secrets, airflow is obviously very important throughout the car. The shop should have a good dyno fan to provide enough airflow to the car under WOT. If a fan is only spinning at 30mph, and the car is running WOT at 100mph+ on the dyno, the IATs are going to spike because the car isn't seeing that 100mph worth of nice cool airflow that it would normally get on the actual road
IAT at 1600deg?
Are you referring to IAT or EGT?
Lance123 is offline   Reply With Quote
Old 06-25-2017, 03:01 PM   #8
user1029
Member#: 57064
2008 STi IAG built
Originally Posted by Lance123 View Post
IAT at 1600deg?
Old 06-28-2017, 12:33 PM   #9
TheColorCute
Member#: 265589
2004 Slow 6466 STi
IAT at 1600deg?
Whoops, my bad. Good catch! It's been a long few days hahaha. EGTs were at ~1600, IATs were in the 140s on back-to-back runs at redline
Old 06-29-2017, 11:32 AM   #10
insaneimpreza
Member#: 83291
1998 RSTi
IAG Stg4 Extreme S366SXE
Its odd that with cams and that size turbo the power is rolling off so hard above 7k. I would guess the high IAT and pump gas are causing that but it seems like all the rev range is really pointless ATM.
Just for reference, and obviously different dyno/weather/elevation etc.. But this is a rod/piston only motor, stock cams, e85, 5857 turbo at 30psi that I tuned for a friend. I would look into getting some E98 shipped to you and mix your own E85 OR buy some race gas just to run it and see what you're leaving on the table!
This is a much smaller turbo with 2 psi more on better fuel, the drop in whp to 7500 RPM on pulls was far less drastic. (This is actually to 7k, not sure why the dyno tach wasn't cooperating but is what it is).
insaneimpreza is offline   Reply With Quote
Old 06-29-2017, 11:38 AM   #11
insaneimpreza
Member#: 83291
1998 RSTi
Just to be clear, Im not knocking your car or saying the car we built was better. Im just offering a comparison of a much milder build with smaller turbo making very similar power on better fuel. I have a very similar engine build to yours on my own car with the BW 366 turbo. My point is really that its well built but overbuilt for the end result. I really dont mean that to sound harsh eventho its probably going to come across that way.
Old 06-29-2017, 02:53 PM   #12
TheColorCute
Member#: 265589
2004 Slow 6466 STi
Nah I hear you, it's definitely getting choked due to pump gas. We're going to pop in some methanol or use some race gas and see what it can do. We brought it up to 8200 to see how it handled it, and 93 octane isn't really doing much up there. That being said, I rarely rev it out that high on that streets. I usually shift at 7000.
Nice numbers! I wish we had E85 around here
Old 06-30-2017, 08:56 PM   #13
SW00P_G
Member#: 5591
EJ257 Gt35r
I'm not going to get into a debate here. But why did you post a different dyno graph that shows a car making power from 4300rpm - 6700rpm and talk about this guys rev range being small?
Either way, good luck on the builds everyone. Be careful out there.
SW00P_G is offline   Reply With Quote
Old 07-01-2017, 01:53 AM   #14
binny
Member#: 198108
MY98 WRX
Hopefully he was just talking up E85?
binny is offline   Reply With Quote
Old 05-18-2018, 12:21 AM   #15
syounger
Member#: 420857
2015 sti
dark grey
I'm interested to see this build with the meth added! Beauty looking build, I hope I can run similar #s when I finally build my motor!!!
syounger is offline   Reply With Quote
Old 06-10-2018, 04:30 PM   #16
PDXREALTOR
Member#: 468393
2017 STI
I keep saying it... For those without E 85 torco is very viable option. I add 3oz per gallon and run 10/20 in 4th @ 28 psi 11.5 afr on an fp green htz
PDXREALTOR is offline   Reply With Quote
