Welcome to the North American Subaru Impreza Owners Club Sunday August 19, 2018
Old 07-25-2009, 08:59 AM   #1
Blackaxela
Member#: 145673
2002 Impreza WRX
Default Need a map for an 18g
ok so i spent alot of money lately and need a quick map to get me by for now until i can afford to properly tune it. heres the engine mod list....
02 wrx 2.0l with version 8 sti transmission, diff....
blouch TD05 18g 7cm (ceramic coated)
deatchwerks 750cc injectors
walbro 255lph fuel pump
perrin turbo inlet
perrin lightweight pully
perrin catless up-pipe
helix downpipe
cobb cat-back exhaust
aps tmic
grimspeed ebcs
crushed stock bpv
k&n drop in air filter
soon to have tgv deletes and 3mm phenolic spacers so may aswell include these
i have a tactrix 2.0 and have 93-94 octane fuel available to me
so does anyone have a map thats closer that i could use until i get a proper one?
Blackaxela is offline   Reply With Quote
Old 07-25-2009, 09:00 AM   #2
Blackaxela
Member#: 145673
2002 Impreza WRX
thanks in advance for anyone who can help
Old 09-24-2009, 02:38 PM   #3
motocooney
Member#: 176235
09 Mazdaspeed3
Bump. I need the same thing as this guy...please.
motocooney is offline   Reply With Quote
Old 09-25-2009, 01:32 AM   #4
jmbwrx2004
Member#: 176321
2011 wrx
CGM
you should contact clark turner here on nasioc he is great with maps for all types of setups
jmbwrx2004 is offline   Reply With Quote
Old 10-29-2009, 08:18 PM   #5
jarencibia
Member#: 187021
2004 WRX Sedan
This is a bit late but I have a safe base map that I came up with for a 2004/05 WRX.
FP TD05 18g
Turbo XS FMIC
Turbo XS UP,DP,High Flow cat,RFL Catback
roughly 750cc injectors, enter your own scale/latency
stock maf scaling
I tested it on my setup at full throttle, safe to 17 psi, overboost fuel cut at 17.4 psi
PM if needed
Use at your own risk.
jarencibia is offline   Reply With Quote
Old 02-22-2018, 11:14 AM   #6
Cberger783
Member#: 473633
Default I could use some help.im drivable but not optimal
O2 WRX ej20 avcs catless downpipe full exhaust 3 inch GrimmSpeed ebcs 850 injectors 18g Turbo Perrin turbo inlet aem wide band walbro 255 cold air intake
.can u help me?
FP TD05 18g
Turbo XS FMIC
stock maf scaling
PM if needed
Use at your own risk.[/quote]
Cberger783 is offline   Reply With Quote
Old 02-28-2018, 10:00 AM   #7
ShinjiML
Member#: 257231
2011 STI ShinjiTuned
.can u help me?
FP TD05 18g
Turbo XS FMIC
stock maf scaling
PM if needed
[/quote]Are you looking for a tune? If so, I can set you up. Please feel free to pm me.
ShinjiML is offline   Reply With Quote
Old 03-17-2018, 01:01 PM   #8
Integrated Tuning
Member#: 460041
Did you guys end up finding anyone to make you a map?
Integrated Tuning is offline   Reply With Quote
vf39 for an 18g on STi what do i need to get it right? taco_tom Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 09-01-2009 03:26 PM
I need a fuel map for an fp green open source blacknbluewrx Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 01-08-2009 02:38 AM
Need info/help with an 18g turbo gling Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 0 12-09-2007 02:41 PM
Need SD Map for 560 pinks 18G gaby UTEC 0 10-29-2006 11:21 AM
Utec Map for a 18g??? ImprezaWRX0386 Engine Management & Tuning 2 03-31-2004 08:39 PM
