Welcome to the North American Subaru Impreza Owners Club Saturday January 19, 2019
Old 08-30-2009, 12:03 PM   #1
taco_tom
Member#: 125498
2004 WRX STi
Java Black
Default vf39 for an 18g on STi what do i need to get it right?
So I have a friend who is selling his 03 wrx with an 18g barely used. I have 103k on my sti now and was want to start moving into modes over $200. Anyway if I swap him what will I need to get started for example will my injectors work or will I need bigger ones. I know I will need gaskets of course but what else will be needed for the install and get me going until I can get it tuned in month?
Thanks
Tom
taco_tom is offline   Reply With Quote
Old 08-31-2009, 11:35 AM   #2
mls1
Member#: 167607
2008 WRX
I am from LJ TX. Went to Brazoswood High back in the 80s. Man I had some fun down there.
To push that 18G you need 650s at least and a FP. I would replace my gaskets also.
mls1 is offline   Reply With Quote
Old 08-31-2009, 01:55 PM   #3
eb_rat_7
Member#: 106910
2016 GTI
C6 ZO6 track toy
Thanks
Tom
get it tuned when you install it. running a 18g on the stock map is not a great idea. while you have the turbo out, i would reccomend doing a turbo inlet pipe as its the easiest time to do it. other than injectors, gaskets, coolant (to top it off), fuel pump, and a tune, you should be all set. mods like a turboback, EBCS, and a drop in filter all are nice.
eb_rat_7 is offline   Reply With Quote
Old 09-01-2009, 02:49 PM   #4
taco_tom
Member#: 125498
2004 WRX STi
Java Black
Thanks for the info, I do have the regular mods already like tbe & intake w/ inlet, wanting to go a bit bigger now. I will save 1st cuz have just enough for the turbo & gaskets right now.
Old 09-01-2009, 03:29 PM   #5
[email protected]
Member#: 222355
You can get away with just installing the turbo with a tune. If you want to get the most out of the turbo you have to do fuel pump and injectors.
You can install any turbo and tune it to the limits of your injectors but you will not reach the limits of the turbo. Your limit will be the fuel system.
TMS@DefiantAutospeed is offline   Reply With Quote
Old 09-01-2009, 04:26 PM   #6
All4bSpinnin
Member#: 99102
09 135i 6MT FBO
Twin Turbo!
good info defiant... thats pretty much it... you can only make as much power as your/tune injector will let you... other than that its boom boom
All4bSpinnin is offline   Reply With Quote
Got an Evo III, what do I need to install it? SomeoneWhoIsntMe Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 10-12-2009 08:42 PM
250 WHP/250+ WTQ on TD04. What do I need to do to get there from where I'm at? DriftIt Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 34 09-02-2009 01:27 PM
What do I need to get 18x9 wheels to fit on an 05 wagon? ever12 Newbies & FAQs 18 04-15-2009 09:14 AM
Is this a BOV?! If it is, what do I need to get rid of it? j2los Newbies & FAQs 41 10-27-2006 03:53 AM
What do i need to get an ej20k into the 11's ? TurboCharged97L Proven Power Bragging 14 07-11-2006 10:57 PM
