Welcome to the North American Subaru Impreza Owners Club Friday April 20, 2018
Old 02-04-2017, 09:06 AM   #1
Imprezaspeed07
Member#: 154863
2007 Impreza WRX
World Rally Blue
Default New clutch help what to get?
Hey everyone I'm currently having my engine rebuilt because of a ringland failure in my 07 wrx. I have about 53k miles on the car and I want to capitalize on the engine being our and replace the clutch.
What clutch should I get my mechanic recommended this one
https://www.rallysportdirect.com/fit...isc-clutch-kit
I am only stage 2 right now and the only future upgrade I want is a new bigger turbo. I do track the car as is road race not drag. So I want something reliable but I don't want a crazy heavy clutch because this is a dd. Is this a good route to go or should I just go with stock or maybe something else.
Imprezaspeed07 is offline   Reply With Quote
Old 02-04-2017, 08:09 PM   #2
Imprezaspeed07
Member#: 154863
2007 Impreza WRX
World Rally Blue
Bump please
Old 02-05-2017, 03:37 PM   #3
drewvdw
Member#: 255776
2010 LR WRX
MPS powered.
What is your horsepower and torque goal? That's really what will determine what you need.
drewvdw is offline   Reply With Quote
Old 02-05-2017, 11:05 PM   #4
Imprezaspeed07
Member#: 154863
2007 Impreza WRX
World Rally Blue
Max torque is probably 350 to the wheels tops
Old 02-05-2017, 11:34 PM   #5
drewvdw
Member#: 255776
2010 LR WRX
MPS powered.
That one would probably be fine. Personally, I would like a bit more space for safety, but that's just me. Something rated around 450ft/lbs.
Old 02-06-2017, 06:22 AM   #6
Imprezaspeed07
Member#: 154863
2007 Impreza WRX
World Rally Blue
So you wouldn't go with the stock clutch?
Old 02-06-2017, 10:55 AM   #7
drewvdw
Member#: 255776
2010 LR WRX
MPS powered.
No
345
Old 02-07-2017, 07:20 AM   #8
kenliu84
Member#: 107618
2006 OBP WRX Wagon
PrecisionTuned/TiCSuspen.
I'd recommend new OEM throwout and pilot bearings instead of using the ones that come with the kit.
kenliu84 is offline   Reply With Quote
Old 02-07-2017, 10:08 AM   #9
Samurai Jack
Member#: 21145
2002 Enemy of Aku
The one recommended is definitely NOT the stock clutch. That will be plenty of clutch for you, based on what you said
Samurai Jack is online now   Reply With Quote
Old 02-07-2017, 11:06 AM   #10
ogintheback
Member#: 99163
I have a South Bend that has worked well for me.
http://www.southbendclutch.com/listings.cfm
ogintheback is offline   Reply With Quote
Old 02-08-2017, 07:35 PM   #11
Imprezaspeed07
Member#: 154863
2007 Impreza WRX
World Rally Blue
Why is this?
Old 02-08-2017, 10:45 PM   #12
drewvdw
Member#: 255776
2010 LR WRX
MPS powered.
They're known issues. It's generally accepted that the OEM ones will last the longest.
Old 02-09-2017, 09:33 AM   #13
kenliu84
Member#: 107618
2006 OBP WRX Wagon
Yeah, what drewvdw said. I didn't know this when I put in my aftermarket clutch kit, and not long afterwards the TOB started rattling.
Old 02-11-2017, 09:45 PM   #14
spoolinsti05
Member#: 108051
2005 TickingTimeBomb
Jr tuned TT Sleeved
Oem.. Exedy or south bend for over 400wtq
spoolinsti05 is offline   Reply With Quote
Old 02-11-2017, 10:12 PM   #15
06WRseXy
Member#: 372094
I have the ACT clutch but for my '13 wrx. After spinning the stock clutch after going protune I needed a stronger one. After my research I went with the full face because it is also my dd. It's been about 10k miles now and I'm happy with my choice. It is heavier then the stock one but more responsive. Stop and go can be a leg workout but it has always held the power. I would also suggest going with a new OEM ToB. I used the ACT one in the kit and it needed to be replaced, no issues with the ToB since it was swapped out
06WRseXy is offline   Reply With Quote
Old 04-19-2017, 10:58 PM   #16
Speed Assault
Member#: 289598
2008 impreza wrx
Southbend Definitely
I was in same position a few times, I tried other brands of clutches that are most talked about, Exedy, ACt OEM, they did not perform to my liking and were Very stiff pedal which lead to my pedal assembly firewall competently failing and costing me 1 month downtime while SOA repaired at $5000.
So after more research I pulled the trigger on Southbend Clutch.
Has more hold than stock OEM clutch but same pedal pressure and they are from our OWN Home USA country, So most of my money is staying here.
Buy SouthBend
Buy Products that Support Your Local Community or State, country.
We all will benefit from this.
Speed Assault is offline   Reply With Quote
Old 05-16-2017, 10:29 PM   #17
06WRseXy
Member#: 372094
Time for an update, 3k more miles and the bs that storm Stella dropped on us (3.5 feet where I live) with driving thru it. Yes it sucked.. A lot.. Clutched slipped the other day in 3rd under full boost...
Old 05-17-2017, 12:36 AM   #18
CarmelValleyWRX
Member#: 453872
2005 wrx wagon
48w
clutch on my 05 wrx slipped at stage2. put an EXEDY OEM clutch in. now at about 250+ WHP no slipping peak torque is around 4krpm. i went with the stock one because i dont want to blow my 5spd. although i do launch every now and again i slip the clutch and let it cool before doing it again.
it seems like if you get a gnarly grippy clutch and you dont slip it enough you could easily snap some teeth on 1st and 2nd.
CarmelValleyWRX is offline   Reply With Quote
Old 05-20-2017, 06:03 PM   #19
BlackFighter
Member#: 193940
2004 WRX STI Black
RalliSpec Shortblock
If i were you i would get the clutch masters FX300. It is the most amazing clutch i have driven. It holds 408 whp and the peddle feel is like a VW. Very easy to press.
I have used EXEDY, and ACT, and i will never go back. JR and the guys at PRIME suggested it and instilled it, big thanks to them.
https://www.maperformance.com/produc...3KgaApYQ8P8HAQ
BlackFighter is offline   Reply With Quote
Old 05-20-2017, 11:07 PM   #20
Rev.G-
Member#: 464890
Default Self-serving
We have a variety of part numbers to handle all of your power goals at Competition Clutch.
We build them here in lovely Conyers Georgia.
We have stock, stage 1-6 kits , multi plate organic and ceramic 240mm kits for the STI, to full race 7.25" twins and triples.
Rev.G- is offline   Reply With Quote
Old 06-18-2017, 07:21 PM   #21
Imprezaspeed07
Member#: 154863
2007 Impreza WRX
World Rally Blue
After having rattles on the first 3 throwout bearings my builder is finally just going to put an OEM one in. Every single one would rattle when they were first installed.
Old 06-19-2017, 07:38 AM   #22
kenliu84
Member#: 107618
2006 OBP WRX Wagon
Yeah, I wasn't kidding. The time and labor just to get to a small part like a TOB is not worth using the aftermarket one. I learned my mistake and just wanted to let our community know.
Old 12-23-2017, 08:37 AM   #23
Imprezaspeed07
Member#: 154863
2007 Impreza WRX
World Rally Blue
After a new throw out bearing. And a new pilot bearing the issue is still there. Does anyone have any ideas??
