#1 |
Member#: 144421
SCIC
Vehicle:2012 STi ltd DGM |
![]() Ok 1st off I tend to ramble alot and my thoughts might be a bit scatterd so I appologive before hand.
So I just got my 2nd Subaru, a 2012 sti ltd with the nav pkg. I love the stock H/U as it does EVERYTHING. Bluetooth, HD radio, Ipod, Aux-in, XM, everything that I would ever need in one nice little pkg. However, the stock speakers need to go so that I can obtain musical euphoria. Before I got rid of my old wrx I took out all of my stereo equipment. 2 sets of JL Audio XR-650csi 1 set of JL Audio XR-650cxi 2 JL Audio 12w6v2-d4's 2 Alpine PDX 4.100 2 Alpine PDX 1.600 Eclipse AVN5510 That set up that I was running was overkill, but awesome. What I'm looking to do with the new car is Run 3 way components in the front, either leave the rears stock or put in the xr-650cxi's, and run 1 of the 12w6v2's. For the 3 ways up front I'm considering the Focal 165-VR3's. I don't have alot of experience with them, but I hear great things about the Focal component setups. As for making this work I need a sound processor. I've ruled out using a LOC and more specifically something like the Audiocontrol LC6 or LC8. I'm basing that decision off of the stock H/U DSP. With the upgraded speakers and amplifiers all the crap that was covered up by the inability of the stock speakers to reproduced is going to come out and sound like complete crap. Along with that would be Bass control. Most oem h/u dsp will muddle out bass for the most part as volume goes up. With all this being said I need to cancle out the stock unit dsp and get that flat eq and the only way I'm going to get that is with a aftermarket sound processor. The one's that I've looked into so far are the JL Audio Clean Sweep, JBL MS-8, and the Alpine PXE-H660. Alpine also has something new that I think is supposed to replace the PXE-H660, but from what I can tell it is not on sale yet. I have NO experience with sound processors at all and actually have never seen how they are set up. Also since I'm going to run 3-way components up front I think it just made things even trickier. Ok on with the questions. 1: Now I'm guessing that my '12 is like most others and does not come stock with amps therefore making everything out of the H/U speaker level signals. Where are people taping into these lines? Are they splicing them right at the radio harness or what? 2: What would you recomend for sound processor considering my overall goals? 3: Do sound processors remove the need for the crossover provided with the speaker sets? I noticed that some of them ( JBL MS-8 ) say that they have built in crossover point/slopes. 4: If the above is "yes" would I be better off mix matching components than just buying a complete set and what would your speaker recomendations be? 5: Do sound processors remove the ability to control volume from the H/U? I can deal with having to open the glove box to deal wit the EQ but having a remote volume knob seperate from the H/U is NOT an option I'm willing to consider. Lastly I'm not really on a budget but not looking for stuff that is stupid expensive. I will post my build in here once I start it. Thanks for your opinions guys! Last edited by Lateralis; 01-27-2012 at 04:45 PM. Reason: Thread direction changed. |
#2 |
Member#: 191557
TXIC
Vehicle:2004 WRX Wagon WRB not so minty fresh |
![]() keeping the OE HU is not an issue...
Alpine currently offers nothing... the H660 does the integration part... but offers limited processsing.. The Jbl MS8 or the audison bit-one are the only "integration" processors readily available... well the mini-dsp is an option..... right now... getting 3-way front, rear fill AND 5.1 or more processing.... yeah... I dream of the PXA-H900 etc every day when I try to re-evaluate my system.... In my opinion, if the newest Alpine PXA-H800 actually materializes.. awesome... there needs to be a TRUE 3-way front, 2-way rear fill, + sub , + Center channel... 5.1+ ALL channels active.. So basically a TEN(10) channel rca processor. Mini DSP is the only current option... u-build it... Rob |
#3 |
Member#: 306708
Vehicle:2012 WRX Hatch SWP TP Stage 2 |
![]() People have reported huge gains in sound quality when using this http://www.crutchfield.com/p_161LC6I...er-reviews-tab and aftermarket amp for the speakers.
I know its not an EQ flattening processor, but its the route I am going to go...its cheaper and seems to have very positive reviews. |
#4 |
Member#: 144421
SCIC
![]() Ok, well been doing a lot of research on other forums and have decided on the direction of my project.
Here goes: JBL MS-8 sound processor Alpine PDX 4.100 Alpine PDX F6 Alpine PDX M6 HAT Legatia L641-3 Pro Component Speaker Set JL XR-650cxi "rear fill" 1 JL 12 w6v2 d4 Still have a bit of a shopping list since I'm not reusing a lot of my old equipment. Being this will be my 1st actual SQ style build I can't wait to start putting this all together! Now on to the 1st hurdle. The radio harness... oh yes... I'm going to be getting a break out harness from ae64. Anyways here are some pics that I took while I was in it. Side note: Fujitsu Ten is the same company that makes Eclipse. This is probably why I really like the H/U other than the fact the DSP sucks. (Click small images to see larger versions) ![]() ![]() ![]() ![]() ![]() Factory 10-pin harness: ![]() Factory 6-pin harness: ![]() Factory 28-pin harness: ![]() ![]() ![]() Last edited by Lateralis; 02-24-2012 at 11:02 AM. Reason: Updated Rear Pin pics and the 28 pin connector |
#5 |
Member#: 69694
SCIC
Vehicle:2014 EuroPinto 5MT |
![]() That's the Toyota influence within Subaru. Subaru always used to use either Clarion (which is a Nissan keiretsu company), Kenwood or Panasonic. Toyota's main stereo manufacturer is Fujitsu Ten. As far as stock headunits go, Fujitsus have always been the best I've had.
#6 | |
Member#: 306725
Vehicle:2012 WRX Base Hatch Plasma Blue |
![]() Quote:
#7 |
Member#: 144421
SCIC
![]() Is it the Nav or the base unit? I'm not sure what the base unit is since I haven't seen it.
#8 | |
Member#: 69694
SCIC
![]() Quote:
![]() Subaru headunit nomenclature If your stock headunit model number starts with the following, then it's made by: P - Panasonic PE - Pioneer CX - Clarion GX - Kenwood FT - Fujitsu Ten (Eclipse) The 2012 Impreza navigation headunit is the first I've ever seen for Subaru made by Fujitsu Ten. The 2012 Legacy premium non-nav color LCD screen is made by Pioneer. This has to be the Toyota influence as almost all of their headunits are made by Fujitsu or Pioneer. Last edited by Eyeflyistheeye; 02-23-2012 at 08:56 PM. |
#9 | |
Member#: 477265
Vehicle:1973 TOYOTA GT86 WHITE |
![]() Quote:
it seems that it is not true for the toyota gt86 6 pin connector 1 2 6 5 4 3 10 pin connector 1 2 3 4 10 9 8 7 6 5 connectors 16 and 28 pins it's good |
#10 |
Member#: 407133
![]() I really appreciate the post I have two pictures don't work when you have time no rush can you repost the pictures in the middle of trying to figure out my Harman/Kardon HU. To upgrade it.
#11 |
Member#: 241673
TXIC
Vehicle:2011 WRX Spark Silver |
![]() Sounds like an awesome setup!!! Where are you thinking for the 3-way locations??
#12 | |
Member#: 144421
SCIC
![]() Quote:
Now with the Mid-bass and Mid-range I haven't really decided yet. My 1st idea is putting the mid-bass in the stock speaker location. Than putting the mid-range below the leather arm rest thingy on the door. Pic for reference lol. ![]() I'm thinking this mostly because 1) doing a kick panel to me is out of the question. 2) I think the ms-8 will be able to properly set the stage even though the MR and MB are not located next to each other with its time delay. Doing this would keep the install fairly simply as I would only really need to make a grill for the MR's. I still need to do some more research though to see if this would be a problem having the MR so far back. My other idea is to mold in a pod just forward of the armrest. The L4 isn't a very big speaker, but really the deciding factor is going to be when I actually get the speakers in my hands so I can physically see what I have to work with. I also don't want to make it seem like what I am putting in there is a foreign object either if you know what I mean. More to come as things come in. Thoughts and opinions welcome! |
#13 |
Member#: 241673
TXIC
![]() Super cool! Always nice to see someone with the balls to take on a three way install!!!Well I am all about letting people do their own thing and trying not to "jade" them with my opinion, but I will say that the difference in path-lenght is most important at 400hz so whatever plays music in your system within an octive of 400hz should have careful consideration on how far away you can get them from you. The farther the better. Your ears hear differently at different frequencies so like tweeters for example, your ears hear more through intesity rather than timing cues so it is easier to manipulate with aiming and processing.with the mids maybe in the dash pointing up or kicks that kept the factory shape would be a couple of places I would start looking at. Don't trust the processor to be able to fix everything with delay. Delay is sweet for sure but it comes at a price in response, and the more you help the ms8 with location the more it will be able to do for you in return. IMO of course. Good luck!!
#14 | |
Member#: 25837
South East
Vehicle:1996 SVX L AWD Laguna Blue Pearl |
![]() Thanks for posting the pics!
I also just received the Subaru wiring diagrams from another 2012 owner. The HU has a diagnostics screen that mentions the rear camera input. Quote:
Last edited by SVXdc; 08-31-2015 at 06:35 AM. Reason: Added info about accessing diagnostics menus; power antenna and amp remote pins; and new combined breakout harness available |
#15 |
Member#: 426455
![]() [quote=SVXdc;36208128]Thanks for posting the pics!
Iam looking for months for how to get the multi function display to work with reverse camera. i have a subaru xv 2014. here in Australia, all the xv models comes with FT nav units with the reverse camera working. i have removed the mfd and looked for any pre-wired 8 pin harness. there seems to be none. i think they dont pre-wire for the models in oz. my plan is to install a non-rooted android tablet as my only multimedia device in the car. my reverse camera is now on the FT Nav HU. I understood the reverse signal 12V is sent to the HU on pin 2 of 28 pin harness and the thru the HU +/-6v on the pin 7/15 of the 16 pin harness to power the camera. The video signal from the camera is on pins 8/16 on the same 16 pin harness. With this understanding will it be easy to bridge the harness and send the video signal to the MFD for the reverse image. sorry for the long message. any advice would be of great help. thanks. |
#16 | |
Member#: 447433
![]() [quote=chandru;44416655]
#17 |
Member#: 472152
Vehicle:2013 STI Limited Crystal Black Silica |
![]() Trying to get in contact with SVXDC to finally get a rear view camera setup in my 2013 STI Limited sedan but can't send a message from a new account. SVXDC, please message me. Thanks in advance and for providing all of this info.
#18 |
Member#: 226331
South East
Vehicle:2012 WRX Hatch Poor Man's Panamera |
#19 | |
Member#: 477265
![]() Quote:
it seems that it is not true for the toyota gt86 6 pin connector 1.......2 6 5 4 3 10 pin connector 1 2 .......3 4 10 9 8 7 6 5 connectors 16 and 28 pins it's good |
#20 |
Member#: 306725
![]() Base unit.
#21 | |
Member#: 25837
South East
![]() Updated my previous post with pin-outs and more info.
Pictures of different HUs in 2012 models (from cars101.com site): Quote:
#22 |
Member#: 144421
SCIC
![]() ^^^ Good stuff. I'll let you guys know what I find out about the NC pins when I start messing with it. Should be getting the MS-8 in next week with some other goodies. Excited for my 1st 3-way system!
#23 |
Member#: 144421
SCIC
![]() Now Regarding the "Diagnostic Mode". The way you listed SVXdc didn't work quite like that. Here's what I found.
1) You need to put the key ind and turn to the "ACC 2" position. There's 3 positions on the tumbler for acc. 1 does nothing that I noticed. 2 turns on the radio and the clock. 3 turns everything on. 2) Let the H/U go through its normal start up cycle. If you have the map selected hit agree and ok until the nav is up and running. 3) Press the Audio, PTT, and Map button at the same time and HOLD IT. PTT = Push To Talk so its that one in between the Audio and Map Button. It will probably go to the stupid voice recognition and ask for a command. If you did it correctly it will pop up the diagnostic screen in a second or 2. If not release the buttons. Let the H/U cancel the operation and try again. 4) To exit the Diagnostic Menu just turn the car off. When you start it back up it will take a couple of seconds to boot so don't wig out if it doesn't kick on right away. The Following pics are of everything that I could do while in there which honestly wasn't much. My Start up screen: ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() As you can see I found no speaker test. Only thing it really lets you check is button functions of the H/U and SWCs, Touch screen, color, GPS, and allows you to update the software from there when need be. Interesting thing though is the Rr_CAM. So this means the H/U does check/have the ability to operate with a rear camera. Now we just got to figure out how! |
#24 |
Member#: 144421
SCIC
![]() Update:
So I got some new goodies in. Got the MS-8, PDX-M12, and the metra harnesses (Thanks David!). Decided to just use both of the PDX4.100's I have instead of getting the new PDX-F6. I'm going to use 1 4ch for the mid-ranges and tweets, than bridge the other 4ch for the mid-basses. I figured why bother amping rear fill so I'm just going to run them off of the MS-8 itself. You're supposed to get like 50W's out of it which should be more than enough. I'm still waiting on my HAT speakers to come in and the rest of my wiring, so the weekend will be figuring out what I'm going to do for a sub box and amp rack. Contemplating using both W6's I have since the M12 is more than enough to run both. L->R :M12, 1.600, 1.600, 4.100, 4.100, MS-8 ![]() JL 12W6V2's ![]() JL XR 650CXi's - Had these for like 4 years. Awesome little guys. ![]() More to follow as I attack the trunk.. lol ![]() |
#25 |
Member#: 303205
SCIC
![]() I have the same factory nav headunit. does it have a sub preout built in? I don't see a way to control the 'subwoofer' anywhere in the sound options.
looking for input on rims | Sir-Knight | Member's Car Gallery | 31 | 12-07-2006 11:19 PM |
Looking for input on Civic track car? | zoomfactor | Motorsports | 21 | 08-28-2006 11:54 AM |
Looking for input on DVD player | jester5 | Car Audio, Video & Security | 2 | 12-23-2004 11:04 PM |
