Welcome to the North American Subaru Impreza Owners Club Sunday March 23, 2025
Old 12-03-2022, 11:22 PM   #1576
K3rm1tth3fr0g
Member#: 508105
Link G4X flex tuned
02' EJ205 20G 6MT wagon
Originally Posted by Defiant Autospeed View Post
I see these posts on a weekly basis. We all do. It always makes me feel really aprehensive (sp?) when I read it. So I just wanted to put this out there for those that are asking this question.
Are you relatively new to the Subaru thing? Have you ever owned a TRUELY high performance import before? Have you ever owned any HIGH powered car before? Do you have fairly deep pockets?
So if my answer is yes and I want the 400whp and most dynos and money is not an issue, but I want it to be reliable? I’m fine with an engine swap if it means better reliability or easier power. Whatever it takes to get me there. Where would I go for that info? Another requirement is that it has to be 2006/2007.
Post a thread with goals, budget, and use case.
Also talk to a tuner.
K3rm1tth3fr0g is offline   Reply With Quote
Old 12-10-2022, 02:09 PM   #1577
MattRD
Member#: 532439
Originally Posted by djmatlow View Post
So what would be a good hp number for a good track car/ canyon carver?? Is 300whp with a killer suspension set up a good idea?
Guess it depends on what kind of track car youre looking at building/what you consider to be fun.
MattRD is offline   Reply With Quote
Old 04-28-2023, 10:45 PM   #1578
edacsac
Member#: 438973
Are upgrades of any value if you don't have the STI?
I have a 2016 WRX w/ 62K miles that I would like to get a little more intimate with. I haven't driven it as much the past couple of years, and would like to upgrade it - not just for power, but also to keep 'er nice for a long while. I could go all out financially, but I would rather do what makes sense for the long run.
Nice OP also, even if it's 16 years old.
edacsac is offline   Reply With Quote
Old 07-18-2023, 01:24 AM   #1579
Godtier69
Member#: 533710
Great post very well said
Godtier69 is offline   Reply With Quote
Old 08-10-2023, 10:54 PM   #1580
Ben-Jammin411
Member#: 523953
It's great that so many people are so enthusiastic about, modifying their Subarus. That said whether my 2011 WRX or the various other performance vehicles, I've owned, the path that has always been the most fun was some additional power but more importantly a setup that lets me use what's there.
Ben-Jammin411 is offline   Reply With Quote
Old 11-20-2023, 03:23 PM   #1581
merlin6014
Member#: 527564
1998 WRX Type R VLim
WRC Blue
Interesting
merlin6014 is offline   Reply With Quote
Old 01-19-2024, 12:49 AM   #1582
ericsson
Member#: 208672
2013 WRX STI Limited
Obsidian Black
400 whp is slow. May "feel" fast to people who drive under 30 mph tho.
ericsson is offline   Reply With Quote
Old 03-06-2024, 05:38 AM   #1583
restone
Member#: 537279
I really appreciate you sharing your detailed insights on building the ultimate street setup for an STI. Your breakdown of the different components and their impact on performance is very informative, especially for those considering modifications.
restone is offline   Reply With Quote
Old 04-09-2024, 02:11 PM   #1584
Federighi
Member#: 537629
Hey! My message in this thread was deleted for some unknown reason. I found this thread to be very detailed and informative. Is there a reason my voice is not allowed here?
Post #1583 from a brand new member is allowed to stay. Why was my post removed?
Federighi is offline   Reply With Quote
Old 05-15-2024, 02:17 AM   #1585
kgalbreaith
Member#: 525985
Thank you for this actual thought out post, helps a lot.
kgalbreaith is offline   Reply With Quote
Old 05-21-2024, 06:07 AM   #1586
george41
Member#: 538070
Default Ej207 about 400hp
Hello everybody. I m from Europe. I saw a conversation about 400 horsepower, so I'm asking you to help me in anyway you can. I have a racing subaru impreza for hillclimb races (EJ207 engine). Now the engine should have around 370hp. I have the following parts: a larger tmic (should hold around 500hp), apexi avcr boost controller, bigger radiator, stronger air and water pipes, other ecutek folder, a bigger air filter, racing exhaust manifolds, home made exhaust from inox (diameter 83mm ), bigger fuel pump (340l/min), turbo ihi vf35 and the original injectors, which should have been slightly modified, exedy racing clutch, dogbox gearbox 5 gears gr.N, lsd rear differencial Kaaz and more and more. I want to have a little bit more power. I am looking for turbo Kinugawa Td05-20g and bigger injector 750cc or 1050cc from Deatschwerks. Does anyone help me with some informations is this a good idea to have about 400hp?
Best regards, Gregor
george41 is offline   Reply With Quote
Old 05-25-2024, 03:29 PM   #1587
dingobite
Member#: 82391
08 OBP Sti
Sorry im not much help just wanted to say stay away from the kinugawa turbos their just to much miss on what their advertised. It did not take me five minutes find something about pre-hawk transmission cannot handle the torque from a 20g turbo their may be other things to research what works.
Scoobynet.com
https://www.scoobynet.com/general-te...l#post12115794
Im making 400hp its the highest the 2.5xtr has put out four different tunes now.
dingobite is offline   Reply With Quote
Old 05-27-2024, 09:59 AM   #1588
george41
Member#: 538070
Hello,
Thanks for answer. I have racing gearbox, which is strong enough gor 600hp and 700Nm od torque (In paid 7000€ for gearbox). I have also racing lsd rear and front diferencials, racing clutch, racing rear and front sway bar from Whiteline, rear and front strut tower from Whiteline, rear and front control arms Whiteline, front brace Whiteline, adjustable end links Whiteline, suspension AST 5300 serier 3 way. About suspension and drivetrain I am not scarry. I'm just worried about the engine. Original parts (pistons, connecting rods, bearings, screws,...) are strong enough for 400hp with bigger turbo and fuel injectors?
Old 07-03-2024, 06:03 AM   #1589
Leily Kingsley
Member#: 538128
Default hi guys
Achieving 400whp on a 2.5i is ambitious and requires significant modifications. An STi turbo alone won't be enough to reach that power level. You'll need a comprehensive upgrade including a larger turbocharger, upgraded fuel system (injectors and pump), high-flow intake and exhaust, a front-mount intercooler, and possibly an upgraded engine internals to handle the increased power. A custom ECU tune is essential to optimize these modifications. It's also wise to consider transmission and drivetrain upgrades to handle the extra power. Consulting with a reputable performance shop for a tailored plan and professional installation would be the best approach.
Leily Kingsley is offline   Reply With Quote
Old 07-09-2024, 09:08 AM   #1590
george41
Member#: 538070
Hello, I have 2.0 engine and following parts: racing gearbox, racing differentials, racing clutch, all suspension from Whiteline (rear and front sway bar, strut tower, control arms, control arms, stabilizer), bigger intercooler, bigger radiator, stronger hoses and more and more. I just need od someone maybe know which turbo is good enough to have a Little bit more power for oem 2.0 engine block. Now I have 370hp, inwant to have about 400 if its possible. Also about other camshafts than oem, if someone know something, od I changed them, maybe I improve on the engine?
Beat regards, Gregor
Old 08-19-2024, 11:12 AM   #1591
jegfaller
Member#: 536306
thx for all info
jegfaller is offline   Reply With Quote
Old 10-31-2024, 06:16 PM   #1592
Chev
Member#: 539462
wtf are you slow or something? The OTS tune is to get you to the tuner XD
Chev is offline   Reply With Quote
Old 11-09-2024, 02:45 AM   #1593
rhamses alapisco
Member#: 534888
Default Looking to get 400 whp
I bought my subaru last year from this dude who lost the receipts to the engine build but he claims that the car has built iag block from 2019. The car currently makes 350 wheel on a conservative tune and has all the supporting mods to make more. I'm trying to push for 400 whp or something close to that but the only thing holding me back is that I do not know which exact block is in my car but I do know it is built. Should the 400 whp be safe to go for?
rhamses alapisco is offline   Reply With Quote
Old 11-20-2024, 01:36 AM   #1594
SmoggedSTI
Member#: 539604
Default Yes!
Incredible post. Absolutely correct
SmoggedSTI is offline   Reply With Quote
Public service Announcement for all you white guys. obyone Off-Topic 12 06-24-2009 10:20 AM
the following Public Service Announcement is brought to you by P.A.C.T Amazake New England Impreza Club Forum -- NESIC 16 11-27-2003 09:43 PM
A public service announcement Midwayman Mid West Subaru Owners Club Forum -- MWSOC 15 02-25-2001 06:34 AM
SVX Public Service Announcement CRZ_MSL SVX Forum Archive 2 11-22-2000 11:24 AM
Public service announcement (AKA: Tony eats crow) Tony General Forum Archive 3 10-18-2000 06:12 AM
