Welcome to the North American Subaru Impreza Owners Club Thursday March 27, 2025
Old 01-19-2025, 07:27 PM   #1
DonkeyyKongg
Member#: 383466
2004 STI
wrb
Default Delete abs harness?
I’m doing a brake booster/abs delete with new brake lines. How would one go about removing the abs harness without upsetting the car?
Car is a RWD track car, so no dccd and vehicle speed sensor to worry about. Speed sensor code has been deleted from tuner.
DonkeyyKongg is offline   Reply With Quote
Old 02-07-2025, 05:59 PM   #2
TurboRev
Member#: 463945
Just unplug the ABS module and pull the wiring to each wheel sensor. Be careful not to mess with other harness connections. Since you already deleted speed sensor codes, just clear any ABS-related errors with your tuner
TurboRev is offline   Reply With Quote
Old 02-08-2025, 10:26 AM   #3
DonkeyyKongg
Member#: 383466
2004 STI
wrb
I’ve decided to plug the abs module into the wiring harness and pull it into the cabin. I took my dash off so I spool it up and tuck it somewhere hidden without looking like a rats nest.
