Welcome to the North American Subaru Impreza Owners Club Sunday March 23, 2025
Go Back   NASIOC > NASIOC General > Motorsports > Autocross
Old 04-07-2018, 08:09 AM   #576
jahjahsqc
Member#: 454825
2011 Impreza STI
My favorite mod on my ASP car so far has been my Sparco Sprint.
I know I'm going to transition into SM eventually, but for the next year or two I like having limitations.
jahjahsqc is offline   Reply With Quote
Old 04-09-2018, 07:48 AM   #577
gti_speed
Member#: 483443
2016 WRX STI
Ice Silver
ASP Lite car is more than fast enough to win 9/10 local events in SM lol. (luckily subydude is not in my region...)
gti_speed is offline   Reply With Quote
Old 04-09-2018, 12:35 PM   #578
Thorium06
Member#: 254372
Besides one outlier, our local STU class tends to raw time our local ASP car and SM car lol
Thorium06 is offline   Reply With Quote
Old 05-10-2018, 09:49 AM   #579
gti_speed
Member#: 483443
2016 WRX STI
Ice Silver
Had some skinny tire-d Subaru weather bring my co-driver and I a 1-2 finish in a 5 driver ASP class at the PittRace Slick Track Solo Nationals Match Tour a few weekends ago. We were really hoping to see how the car compared to the Hockenbury 1M that trophied at Nationals last year but they had major power delivery issues and were wayyyyy off pace. Lowered the rear just a hair which combined with running the cdiff in the right position seems to have brought some more speed. Hopefully can make it out to another National Tour before the big dance in September!
Old 05-10-2018, 12:01 PM   #580
S1MPSONS
Member#: 90357
2006 Corey's EVO
& 1993 Mazda RX7
295/15s going on my buddy’s FD3S ASP RX7. It’ll be game over once that car is dialed in. Maybe the boost buggies will still have a shot at pros.
-Hamfist Racing.
S1MPSONS is offline   Reply With Quote
Old 05-10-2018, 12:37 PM   #581
gti_speed
Member#: 483443
2016 WRX STI
Ice Silver
Hot! Got pics?
#MakeStreetPreparedGreatAgain
Old 05-10-2018, 12:57 PM   #582
S1MPSONS
Member#: 90357
2006 Corey's EVO
& 1993 Mazda RX7
Originally Posted by gti_speed View Post
Hot! Got pics?
http://hamfistracing.blogspot.com/2009/10/car-5-1993-mazda-rx7-r1.html
Old 05-11-2018, 08:54 AM   #583
gti_speed
Member#: 483443
2016 WRX STI
Ice Silver
Ok that's pretty freaking cool, I've always loved the FD.
Old 06-04-2018, 12:27 PM   #584
gti_speed
Member#: 483443
2016 WRX STI
Ice Silver
Well got 295/30/18's A7's to fit on the front of my VA with 9.5" et42 wheels with no fender roll. Tire was just barely kissing the spring so an Et40 or ET39 would probably be ideal. I was running a reverse stagger setup with a 275/35/18 in the rear on the same wheels and the front end grip was a huge step up from when I had the 275's up there. I think this should work until I can figure out how to squeeze 295's in the back (only so I can figure out how to fit a 315 up front). I think the staggered fitment is pretty ideal since the rear just doesn't pick up heat like the front does (we were only spraying the fronts on an 80 deg day).
Old 06-04-2018, 12:35 PM   #585
makofoto
Member#: 25243
2006 Legacy Outback
Racing Subies with huge wide tires just off set them out, PAST the fenders, with Very Stiff Springs, to keep them fenders off the rubber.
makofoto is offline   Reply With Quote
Old 06-04-2018, 12:45 PM   #586
subydude
Member#: 80649
2000 2.5 Auto-X RSTi
Sparkly
If you're overheating the fronts and not getting heat in the rears there's something else going on. My car weighs less than yours (min weight is 2,970 so it's roughly 3,000) and puts heat in 335 square just fine.
Also, there's a lot of tricks in SM that allow for clearance, but even so on a GC you have to move the tire out eventually. I use 18x12 +20's which, in comparison to the stock setup is about 4" of poke.
And while most of us have stiff(er) springs, it's not to keep the tire off the fender. It's to make sure we're not rolling too much. You cut the fenders for clearance, not reduce grip by running stupid stiff springs.
subydude is offline   Reply With Quote
Old 06-04-2018, 01:16 PM   #587
JourdanWithaU
Member#: 146287
2011 Impreza WRX 5D
Satin White Pearl
Agreed. Should have no problem getting heat into the rears. I've even been able to burn my rears over my fronts.
JourdanWithaU is offline   Reply With Quote
Old 06-04-2018, 01:57 PM   #588
makofoto
Member#: 25243
2006 Legacy Outback
Stompy ... I think I remember seeing it run even wider tires?
Old 06-04-2018, 02:00 PM   #589
makofoto
Member#: 25243
2006 Legacy Outback
Old 06-04-2018, 02:31 PM   #590
subydude
Member#: 80649
Sparkly
I think Stompy topped out at 315 since it was before the 335's were available. But even so I'm not sure the 335's would have physically fit and been able to turn in SP anyway due to inbound items that can't be fixed until SM.
There is a point where the car is too wide.
Old 06-05-2018, 10:31 AM   #591
gti_speed
Member#: 483443
2016 WRX STI
Ice Silver
I should mention that rears are generating sufficient heat. Just not enough to warrant spraying like the front.
My car usually comes in around 3150 on SCCA scales so I don't think the weight discrepancy would be generating that much more additional heat. Are you ballasting up to ~3000? If so are you able to distribute weight better? I did drop the rear of the car some in comparison to the front to try to help balance it out more. My spring rates are equal front to rear (650's) and I have a slightly bigger front bar than stock. I have a slightly bigger rear to experiment with too but I don't think that would help distribute weight any better. I've been thinking about trying a higher front spring rate and maybe going back to the stock front bar too.
Old 06-05-2018, 12:11 PM   #592
subydude
Member#: 80649
Sparkly
When you get it right you'll spray the fronts one run before you start spraying the rears too.
I do use ballast so there's an extra 250 lbs on the back of the car, but it's still like 56-57% front right now.
That's likely way to soft for rear spring rates since you've got the multilink rear suspension. On hoosiers I'd expect a bit more front spring rate and then try a stock front bar.
Balance the car with camber. Lowering it doesn't do nearly as much. Not saying it does nothing, but the right camber setting is way more useful than ride height
The Competition (strictly by the numbers) R Diamond STi Forum Archive 9 05-22-2003 04:16 PM
The Competition is Worried..G Stock is worried Scooby South Motorsports 10 02-23-2001 04:41 PM
Weapon R Intakes vs. the competition Matthew Nelson Technical Forum Archive 28 09-07-2000 01:32 PM
Weapon R Intakes vs. the competition Matthew Nelson General Forum Archive 3 08-31-2000 12:19 AM
0-50 vs the competition bryanw General Forum Archive 11 08-11-2000 08:15 PM
