#26 |
Member#: 86356
Vehicle:2018 Aprilia Tuono v4 1100 |
![]() I just called them and got an answering machine
#27 |
Member#: 634
TXIC
Vehicle:2000 Impreza 2.5RS Becasue racecar |
![]() They are located in the CST. Best to call them cause they never replied to my e-mails. Talk to Bill if you call them and tell him Pat sent you.
#28 |
Member#: 86356
![]() I figured they were closed, i just wanted to see if the number was still working.
#29 |
Member#: 634
TXIC
![]() I wonder if I could use the title of highest mileage racing subaru in the US.
I am just about too hit 195K and on the original motor. |
#30 |
Member#: 2491
South East
Vehicle:2017 Camaro |
#31 | |
Member#: 5218
Vehicle:96L Most Over- Developed Beater |
![]() Quote:
![]() So much for the thought of the motor self-destructing as soon as you raise the revlimit without changing anything, eh? ![]() Jay |
#32 |
Member#: 2491
South East
![]() It's an interesting point you have there - We ran 7,400 limit with the Hydra, and when I switched to the I-speed flash for STX it was changed to 7,200. I put approx 30k street miles, hundreds and hundreds of autocross runs, and probably 2k miles of track days on my RS hitting that limiter all the time... The next owner did find a slightly leaking valve seal a while after he got the car, but other than that, it did fine. I think the bigger concern is oiling - but on an autocross course, with short bursts of revs that high I don't think it is that big of a deal.
#33 |
Member#: 2230
Vehicle:2000 2.5RS Silverthorn, PGT #671 |
#34 |
Member#: 86356
#35 |
Member#: 5218
![]() Getting back on topic..... Pat did a great job of getting into the trophies last year in Topeka, while Gil and his brother would've been there too had they not broken a strut. I'd like to think that if I woulda softened the car up and actually drove, I coulda been in the hunt. We definately showed the potential. Now that the 275-35-15 is here, some of the e30's will no doubt be going to them as well....maybe some of the e36 drivers too. What is it going to take to keep the momentum up for us?
We have enough tire for grip and we're similar in weight. Power wise (to the ground) we're down a good deal and transitioning prowess leaves a bit to be desired compared to the heavy hitters. We have a link ECU ready to install and tune to try and take advantage of timing control to maximize what we can put to the ground but I'd really like to get the car to handle better still. Jay Storm |
#36 | |
Subtly Outspoken
Moderator Member#: 238
Vehicle:OG05 STi 51E |
![]() Quote:
The Bimmers and the mini's are especially tough...there some others that are outdated and probably need to be moved to FSP... Bill |
#37 |
Member#: 16
BAIC
Vehicle:1968 Saab Sonett II V4 |
![]() I have sketched out ideas for what a Maserati Biturbo project could look like for DSP. Obviously, a very strange and specialized machine, but do-able for someone with Italian car background. A couple items to note:
-All Biturbos are on the same line. Find an early 2.5L Carb car and transplant the 2.8L fuel injected engine. 225hp with fairly mild boost stock. With race gas, water injection, and exhaust/manifold work, you would easily be above the output of most other DSP machines in both HP and TQ. Great for fast west coast events, perhaps total overkill for Topeka. -A race ready weight of 2400-2500 pounds would be doable. Early cars were in the 2600 range, and the heavier later cars were in the mid 2700 range. Minus AC, light exhaust, light battery, light seats etc. -the 275-15 Hoosier would fit easy -think of all the contigency you could earn???? On another Italian car note, now that Nationals is on low-grip asphalt, and generally tighter courses, I've wondered what Hoeschler's X1/9 could do again. Especially considering that since he raced, the 1300 and 1500 cars have been grouped together now. There is about 100-150 pounds that could be dropped with heavy bumpers and trim. Chris H. |
#38 |
Member#: 72994
Vehicle:2001 Racekor Emerald Green |
![]() Heres my DSP RS.
Megan track coilovers Perrin rear sway Super Pro Bushings throughout Sti Eng/trans mounts Equal length header Kartboy SS/bushings OBX front LSD Hydra EMS 275/40/17 kuhmos Needs alot more work and refinement to run with you guys. But I will be out at topeka this year....crosses fingers ![]() ![]() ![]() Josh |
#39 |
Member#: 634
TXIC
![]() Cool man, I hope you can make nationals this year.
#40 |
Member#: 72994
![]() hopefully the new motor is going in this week, then tuning and some local competition. We will see. Its been a long year with this car.
Josh |
#41 |
Member#: 16149
Vehicle:2001 impreza 2.5RS blue |
![]() hey Pat.
So what happened to the big spoiler? |
#42 |
Member#: 72994
![]() yea I would like some more info on the rear wing
Josh |
#43 |
Guest
Member#:
![]() Holy carp. Just when i get an ESP/STX/STU/SM turbo car I see the new tires.
ARG. |
#44 |
Member#: 634
TXIC
![]() Spoiler... I redid it a bit to make it adjustable. I need to get some adjustable spoiler struts and then I'll try it out again.
#45 | |
Member#: 815
Vehicle:2013 Boss 302 White 2008 S2000 CR ABP |
![]() Quote:
Everybody was shifting to 3rd before the fist turn. ![]() However, I think my co-driver and I in my RS were the only ones who didn't shift to 3rd at all. Suffice to say the little NA 2.5 makes an interesting scream above 8k RPM. ![]() Pat's RS is looking great on course. The combined effect of a lower car and a more reasonable ride height / suspension geometry makes all the differance. No bouncing, undulating, etc. Looks solid and planted. I'm jealous. - Steve Sulatycki Zzyzx Motorsports |
#46 |
Guest
Member#:
![]() 15"s for the WIN!
#47 |
Member#: 634
TXIC
![]() BTW, I tried my 15's on a WRX the other weekend and they didn't fit over the calipers. They were rubbing the shell. It they only had a few MM's
OH! action shot from the KC Midwest Divisional. ![]() |
#48 |
Guest
Member#:
![]() You'd need the 4 pots or the RS brakes on the WRX to fit the 15"s...which is why I am putting 4 pots on my WRX.
#49 | |
Member#: 5218
![]() I'm pretty sure I mentioned it over on USMB......
Hopefully we'll have both the DSP RS and FSP Brighton in Topeka this year.....probably a pipe dream, but it'd be kinda cool to bring both cars, if my co-driver can find a quicker co-driver for the RS. ![]() Jay Storm |
#50 |
Guest
Member#:
![]() That works. I'd say I'd like to be that codriver...but no way the budget would allow trip expenses right now.
Squirells check in.. but they don't check out. | Fish | Off-Topic | 13 | 08-19-2004 07:59 PM |
Check in times for Auto-X in DC sunday | KanosWRX | Mid Atlantic Impreza Club -- MAIC | 1 | 06-12-2004 06:06 PM |
TXIC members who went to WRC check in, cute girls in WRB Wagon we saw you, you better | shoracer | Texas Impreza Club Forum -- TXIC | 0 | 03-16-2004 01:38 AM |
Check in for trade in. | TFW | STi Forum Archive | 18 | 01-06-2003 10:48 PM |
Subie Gal checks in... er... yeah.. STILL in the UK! | Subie Gal | General Forum Archive | 28 | 05-09-2000 12:06 AM |
