#26 | |
Member#: 71634
Vehicle:In hibernation... |
![]() BTW - this is what whiteline says about their ALK:
#27 |
Member#: 80649
South East
Vehicle:2000 2.5 Auto-X RSTi Sparkly |
![]() However the rules state you can use offset bushings so the whiteline KCA375 bushing can be used to gain caster if needed.
#28 |
Member#: 62539
Vehicle:2002 WRX Wagon |
![]() subydude:
What is your opinion on the q-rack for auto-x? Thanks, Tom |
#29 | |
Member#: 6119
BAIC
Vehicle:1999 GM6 RBP |
![]() Quote:
I still have my old fender braces in there, but need to find some time to yank them out. They aren't helping me win anything ![]() It's too bad the newer 2.5i's didn't come with stiffer braces. Although, I'll be honest, we come with these braces OEM, I don't see the reason we can't run stiffer ones. But SEB is filled with people with their own agendas right? I'll post up my car's specs in a little bit. It's not as powerful as your guys cars though, mainly cause this SM project is JUST getting started! |
#30 |
Member#: 32131
NWIC
Vehicle:2006 Nissan 350Z Was 01 2.5 RS |
![]() E. Suspension components are unrestricted as long as they use the
original attachment points. For the purposes of this rule, "suspension" is defined as any item that is designed to move when a wheel is deflected vertically. This includes shocks and struts, control arms, steering knuckles, uprights, etc., but not tie rods, steering racks, and subframes. In addition, shock absorber/strut upper mounts are to be considered suspension components. The ALK doesn't move iirc... |
#31 |
Member#: 104878
TXIC
Vehicle:02 wrxbastardchild aw, MPS 2.34 breaking in |
![]() No, the control arm rotates in the bushing not the actual bushing.
Thanks for the sticky Heres my list, I only do local events and its currently in the process of getting a 3076r with a speed density tune on the HKS Fcon. Ok, heres the parts /mods list. It weights 3046 with a full tank of 93 before the seat replacement. Engine ported vf34 Stock coated header grimmspeed uppipe APS dr 3.5 tbe Cusco exhaust hangers Perrin fuel rails (I hate these b/c I hate perrin but got them for 170 new) SRI intake with HKS super mega reloaded filter Samco inlet hose Custom blitz reversed i/c piping Custom reversed manifold by me (shaved all unused nubs) grimmspeed 8mm manifold spacers Beatrush crank pulley Beatrush motor mounts braille 15 lb battery Cusco oil can converted to coolant over flow AVO radiator Samco coolant hoses Samco flex hoses for coolant air sep Greddy coolant tank (modded) Zero sports rad caps ECU tuning by gabedude ARC oil pan Tomei upper and lower oil baffels Sard fpr Canton/Meca 1 micron fuel filter and -6 AN lines STi pink injectors Walbro 255 70mm billet throttlebody, ported to match manifold TGV deletes crawford o/a seperator Greddy type R bov Suspension/drivetrain/brakes JIC FLT A2 coils with 10k springs Cusco rear trailing arms Cusco rear lateral links Cusco front sway Cusco Ti front stb Cusco Carbon rear stb Cusco 1.5 front lsd Cusco verII 4 point brace Cobb rear sway with hard mounts Whiteline alk race (caster bushings ![]() Whiteline rear lock bolts Whiteline outrigger bush Whiteline f/r spherical endlinks (STi) Whiteline roll center kit (new version) 06 Sti front lower arms 06 STi R180 rear diff assy 06 STI front knuckles 6gunn speedo rings GruppeN trans mount Ver6 ra gears treated ACT street lite flywheel and clutch 04 STi front axles DSS 4 in alum ds ARP ss 12pt ds bolts and nuts removed front subframe removed rear diff lower cover 06 STi brembos Hawk HPS pads f/r Stoptech lines ATE blue fluid Exterior JDM bumper beam Enkei NT03 +M 18x9.5 +40 et wheels 10mm front spacers Rolled and pulled rear fender Yoko S-drive 255/35 Hate these but a good street tire InteriorSparco 215 suede wheel Splash boss hub Garage spec bent 3 1/2 in chrome shifter extender (love it!) Kartboy SS SPARCO evo2 seat and brackets ![]() ![]() Last edited by scby rex; 03-04-2010 at 09:35 PM. |
#32 | |
Member#: 211057
NWIC
Vehicle:2006 STI Matte Black |
![]() Quote:
#33 |
Member#: 100834
BAIC
Vehicle:2006 Subaru STI Steel Grey Metallic |
![]() To be honest, I put a set on my friends STI and didn't notice much of a difference at all lol.
#34 |
Member#: 80649
South East
![]() This is one of the things that was added this past winter. But judging from the rack in the Evo that's 13:1 and how everyone else raves about the q-rack I'm going to say it's probably one of the best mods you can do when going through quick transitions.
#35 |
Member#: 80649
South East
![]() Here's a good question. Can you run a VTA external wastegate, or does it need to be plumbed back into the DP?
#36 |
Member#: 211057
NWIC
#37 |
Member#: 80649
South East
#38 |
Member#: 100834
BAIC
![]() You can just run the dumptube behind the driver too. But there's a national soundlimit of 100@50ft. VTA wastegate will be over that limit. I routed mine back into the dp(but it was a blast driving around the week I had VTA LOL)
#39 |
Member#: 6119
BAIC
![]() Roll Center Correction Kits?
#40 |
Member#: 6119
BAIC
#41 | |
Member#: 6119
BAIC
![]() Quote:
#42 |
Member#: 115961
Vehicle:2005 Wide STi Wagon WR BLUE |
#43 | |
Member#: 56731
Vehicle:2004 STi, 00 Insight 10 Volvo C30R-d 11 F150 |
![]() Quote:
but it doesn't change suspension mounting points.... |
#44 |
Member#: 5218
Vehicle:96L Most Over- Developed Beater |
![]() Offset bushings change geometry too, but do not change the mounting points, and are allowed. I believe the RCCK fits the rule in the same manner. Might be best to get a clarification from Doug or Brian at the national office, just to be safe.
Jay |
#45 |
Member#: 100834
BAIC
#46 | |||
Member#: 92778
NESIC
Vehicle:2000 Impreza 2.5RS |
![]() Quote:
#47 |
Member#: 80649
South East
![]() I know that the Leiber Evo has them on and it passed impound for two years at nationals now. That should be more than enough of a thumbs up for the RCCK.
#48 |
Member#: 6119
BAIC
![]() Woah!
My car is 2700lbs with speakers, headunit, and a huge battery. (mostly due to the L roof/headliner and aluminum hood.) Personally I think I'm going to build it with 275s in mind. Eventually I'll try to get more lighter things like L-arms, lateral arms Aluminum, etc. I have a PC680 ready to be put in, just have been too lazy to figure out the right size J-hooks I need to mount it. Last edited by joltdudeuc; 03-12-2010 at 12:24 PM. |
#49 | ||
Member#: 211057
NWIC
![]() Quote:
http://forums.nasioc.com/forums/show...r#post16920041 Quote:
#50 | ||
Member#: 80649
South East
![]() Quote:
Mine being an RS to start with is at 2900 with the 6-speed, brembos, and sunroof. I was tempted for a while to loose the heavy stuff, but I'm in using 285's so no real reason ![]() Quote:
Will my trans swap put me automatically in Street Mod? | RebelINS | Autocross | 6 | 07-22-2013 05:24 PM |
I'm still legal for Street Mod right?(list inside) | Davenow | Motorsports | 4 | 05-24-2003 03:21 AM |
street mod tire question | Jaxx | Motorsports | 2 | 02-20-2003 07:59 PM |
Autocross class... Street Mod? | Motohead1 | South East Region Forum | 11 | 06-26-2001 10:11 AM |
Street Mod news | Eric | Technical Forum Archive | 5 | 05-31-2000 02:33 PM |
