#26 |
Member#: 428464
NWIC
Vehicle:2002 WRX World Rally Blue |
![]() Thank you very much for the post. I just needed quick info on how much of which ID I needed to order to replace my ****ty hoses and the table made it super easy and the pictures will help out if I get confused along the way. Seriously, nicely done, thank you.
#27 |
Member#: 372048
Vehicle:2003 WRX Silver |
![]() Awesome DIY write up!
#28 |
Member#: 385256
NESIC
Vehicle:'18 Giulia QV '21 Giulia Q4 |
![]() Hypothetically, if you didn't have a check valve in your brake booster hose, what would happen? No brakes, vacuum leak, both?
#29 | |
Member#: 180570
South East
![]() Quote:
<looks at date> Man it's dead in here lately. |
#30 |
Member#: 418261
![]() Resurrecting a dead thread. But would these hose measurements work for a hawkeye as well?
#31 |
Member#: 444931
Vehicle:2002 WRX Wagon Silver |
![]() Are these cars picky about the vacuum hose diameter?
Does it have to be exact or just close? |
#32 |
Member#: 418261
![]() I just did these hose installs today. Boy, the joy of working for hours hunched over your engine. The sizes were fine for my 2007. I did feel that the new hoses for the top radiator reservoir, and just about all the hoses, were a bit smaller in diameter compared to what was removed. They fit, just the inside diameter has been made smaller.
I found the rats nest to be different in the 2007, but everything else was as expexted. I installed an Iag Aos today as well, which eliminated some of the hoses. |
#33 |
Member#: 429658
Vehicle:2005 Saab 9-2x Aero |
![]() Just finished this up last week via the mishimoto hose kit and some bulk 4/6mm Turbosmart Hoses. Not the easiest fix, bu (had to cut most of the smaller hoses off), but after I accidentally broke one petrified/formerly rubber vacuum line, I found myself replacing them all. Fit on the 92x Aero was fine.
#34 |
Member#: 343685
BAIC
![]() What's the restrictor pill P/N and size?
#35 |
Member#: 417401
SCIC
Vehicle:2003 wrx PSM |
![]() Reppin the 03 bugeye. i just wanted to say thanks! i needed a pic to find where the proper placement of some hosing went after installing a turbo inlet... The specifics with the letters on the pics relay helped. Found them through google.
Anyways, much appreciated! Subaru love |
#36 |
Member#: 86201
Vehicle:2002 Impreza WRX WRB |
![]() This is amazing, I needed this so badly. Thank you!
#37 |
Member#: 112218
Vehicle:1999 Impreza 2.5RS Rally Blue Pearl! |
![]() Great thread!! Saving for future reference
#38 |
Member#: 448735
![]() This is a life saver. I told a friendly staff earlier I was concerned I wouldn't remember where all the hoses went. I took the car apart in November after i bought it and haven't really touched it since.
#39 |
Member#: 386095
![]() A very thoroughly narrated and well illustrated thread. Thanks for this great write up!!
#40 |
Member#: 60324
Vehicle:1998 RS |
![]() you got the coolant overflow hose at 19", can you say where it terminates inside the overflow? does it go all the way to the bottom of the overflow tank?
#41 |
Member#: 79004
TXIC
Vehicle:2005 Impreza WRX STi Crystal Grey |
![]() Thanks for the excellent write-up. I appreciate the time and effort involved in documenting this so thoroughly.
For other readers that are looking for an alternate source of silicone hose, I located a reputable manufacturer, Flex Technologies siliconehose.com that had slightly better pricing. I bought some additional sizes for other projects so that worked out better for me. |
#42 | |
Member#: 159619
![]() Quote:
Did you with 10mm and 13mm? Someone mentioned a tight fit and I wanna order the correct stuff. Also, is there an Auto Parts Store that you guys are aware of that stocks the silicone hoses? |
#43 |
Member#: 461982
International
Vehicle:2002 WRX Cup Edition |
![]() Hello. I am in the process of doing this as well. I am replacing all the rubber hoses with silicon hoses. This thread has been very helpful. The only thing I would like to point out is that my tuner warned me against using non reinforced silicon hoses for the cooling system, and it would also be preferable to use reinforced hoses for the vacuum system in my opinion. Better safe than sorry.
#44 |
Member#: 435576
Vehicle:2005 Wrx Wagon Crystal Grey Metallic |
![]() How do you get the check valve into the new hose? My brake booster hose is cracked.
#45 |
Member#: 417793
![]() Great write-up , thanks
#46 |
Member#: 435576
#47 |
Member#: 403134
#48 |
Member#: 224738
SCIC
Vehicle:2007 WRX |
![]() Issue resolved
#49 |
Member#: 468311
Vehicle:2003 WRX wagon World Rally Blue! |
![]() Wow brilliant and functional writeup. Thank you. No wonder I felt like I had rabies, they call it it the rats nest! This area is my nemisis!
#50 |
Member#: 444130
Vehicle:2002 Impreza WRX Midnight Black Pearl |
![]() OP how have the hoses held up since you have installed them? Anyone else who has run this kit have any issues? I haven’t heard of them before and as others mentioned earlier, the silicone isn’t reinforced like other companies (Samco, Mishimoto, etc..) which is somewhat of a concern. I’m looking to replace all my hoses and I really wanted to get the Samco Ancillary hose kit to match my Samco intercooler hose kit, but it seems like it’s just about impossible to get these days, not to mention near $300 + shipping if I were to special order it and it isn’t even as complete as the HSPI Motorsports kit, although they are very well known and race proven. I’m almost tempted to order all oem hoses, but they aren’t exactly cheap. Any input would be nice!
