#1 | |||
Member#: 90982
Vehicle:2003 WRX w/ V7 EJ207 Sonic Yellow |
![]() I recently completed my version 7 EJ207 swap into my 03 WRX and it fired up with a noise that was similar to a engine knocking noise. However when the engine was warmed to temperature, the noise disappeared.
I've been looking up through a lot of threads and most of the answers leaned toward piston slap while a handful claimed it was rod knock. I'm quite stumped about this problem and really paranoid if the engine I've purchased was bad from the start. I tuned the engine immediately via open source to eliminate the possibility of pinging/detonation due to crappy California 91 gas. The engine runs very strong but the cold knock doesn't seem to go away. Any help would be great.
#2 |
Member#: 279525
Vehicle:06 Fxt |
![]() You just said the noise goes away after it warms up. So essentially you have no issue.
#3 |
Member#: 90982
#4 |
Member#: 279525
Vehicle:06 Fxt |
![]() Well,
For the most part yea; it is normal. Ive had a built motor that was pretty noisy, particularly when cold. But remember it was a built motor. My stock ej251 on my 04 legacy wagon is also loud and has piston slap when cold. My oil levels are above the "F" mark btw too. So not a low oil scenario in my case. |
#5 | |
Member#: 90982
![]() Quote:
#6 |
Member#: 176408
SCIC
Vehicle:2005 EJ207 STy White |
![]() I'm in the same boat, my V7 swap is noticeably loud during cold starts but it quiets down at operating temperature.
It's a slapping/knocking sound only audible on reversing and taking off in first during cold engine conditions. The car has been looked at by numerous Ej207 guru's and Subaru Mechanics, they've said everything is A-OK, which puts me at peace. |
#7 | |
Member#: 90982
![]() Quote:
#8 | |
Member#: 176408
SCIC
![]() Quote:
Few late night canyon carving sessions and daily WOT pulls on the freeway onramps, hasn't gone boom yet. If the noise is present at operating temperatures I'll start worrying haha. |
#9 | |
Member#: 90982
![]() Quote:
Did you get yours tuned at Churchs? |
#10 |
Member#: 90539
South East
Vehicle:My BOV goes COVFEFE! |
![]() Forged piston cold slap, normal. Even my 97 ej20k with cast pistons did it, worse in cold weather, but ran silky smooth and never skipped a beat. I believe the flat engine design makes it easier to hear as well.
It could also be the timing belt tensioner, did you replace it with new? |
#11 |
Member#: 90539
South East
![]() Tensioner noise. Imagine how many subaru owners have gotten screwed out of money or even sold their cars because they were told it was a "spun bearing".
#12 |
Member#: 90982
![]() video uploaded
#13 | |
Member#: 176408
SCIC
![]() Quote:
I went with another big name shop in socal, good tuner - terrible customer service. From what everyone tells me Church is fantastic with a 207, if I had the choice to do it over again I'd go with him. That's exactly how my car sounds. |
#14 | |
Member#: 90982
![]() Quote:
#15 |
Member#: 453872
Vehicle:2005 wrx wagon 48w |
![]() my car does that too (exactly the same sound when blip the throttle) but its an EJ205 stock motor. it did not always do it. it slowly got louder. i replaced all my pulleys because i thought it was timing belt related. it still runs ok but it makes noise when hot too now. i dont trust my det cans now because the mechanical noise is so loud i cant hear anything.
#16 | |
Member#: 21145
NESIC
Vehicle:2002 Enemy of Aku |
![]() Quote:
There have been a number of posts re: people having what they thought was rod knock only to discover later that it was a bad tensioner. ... and no, I'd say it is not normal. I don't have cold piston slap on mine. I think many people just call it piston slap because the v7s have forged pistons so they call it normal, because they are comparing it to a built motor w/aftermarket forged pistons. Easy answer so they don't have t look into it. You should check the tensioner to be sure before it's too late. |
#17 | |
Member#: 90982
![]() Quote:
The tensioner noise sounds like it's constant |
#18 |
Member#: 180033
Vehicle:2005 WRX PSM |
![]() My IAG stage 1+ block does the same thing on cold start especially in the winter.
Just piston slap from having forged pistons until they expand when they warm up. |
#19 |
Member#: 21145
NESIC
![]() You can't compare a "built" motor to an OEM motor. "Built" motors do normally have some piston slap. How much is dependent on which brand pistons you use and the piston material and how the builder set the PTW clearances.
#20 |
Member#: 21145
NESIC
![]() It may only be the tensioner. It may be showing up when it's cold, but could continue to deteriorate. Worth checking the tensioner than just ignoring it and wish you did. All I am saying is it is worth checking now just to rule it our, or in
#21 |
Member#: 90982
![]() Well, I ordered the Gates blue kit and gonna change everything when it comes in. It may or may not fix the issue but I think it's a good idea to change it.
#22 |
Member#: 90982
![]() Have you replaced your belts/tensioner yet?
#23 |
Member#: 176408
SCIC
![]() No, the timing components are brand new. Tensioner was bled properly, I’m swaying towards piston slap. My friends gf has a V7 swapped bugeye and it makes the same sound as well. I’m going to drive it until something breaks ![]() |
#24 | |
Member#: 90982
![]() Quote:
#25 |
Member#: 110078
Vehicle:02 Bugeye JDM STi OBP BLACK |
![]() My v7 ej207 piston slaps at cold start but quiets down fairly quick, under a minute. Keep in mind when buying a used motor you are trusting the vendor is representing the mileage accurately. A higher miles motor will have more wear and looser tolerances.
