Welcome to the North American Subaru Impreza Owners Club Sunday March 23, 2025
Old 01-13-2025, 08:17 PM   #1
Chev
Member#: 539462
Default Looking for V8 JDM ECU from a 207
Need one of these ecus came to see if anyone would have one for sale in a bit of a situation rn and rly need one
Part #s
-22611AH581
-22611AH591
Please shoot me a msg or something or reply to this thread, would need ASAP.
Thanks in advance!
Chev is offline   Reply With Quote
Old 01-14-2025, 01:06 PM   #2
D-Rodman
Member#: 110078
02 Bugeye JDM STi
OBP BLACK
You can use a ver 7, ver 8 or wrx/forester with avcs. They are available on eBay, just flash the correct map for your application.
D-Rodman is offline   Reply With Quote
Old 01-14-2025, 05:29 PM   #3
Chev
Member#: 539462
Well tbh I need the ones ending in AH581 or AH591 as they are 32bit and unlocked
Old 01-15-2025, 11:02 PM   #4
Hyper
Member#: 15822
1999 DIY 22b
74F
I would advise to do some research on this topic, as you clearly have wrong information
search for the big 207 thread, tons of good info there
Hyper is offline   Reply With Quote
Old 01-15-2025, 11:21 PM   #5
D-Rodman
Member#: 110078
02 Bugeye JDM STi
OBP BLACK
So you are planning on running your jdm ej207 ver 8 engine with a 32 bit ecu ? How are you going to do that ?
Your engine runs on a 16 bit ecu from the factory.
If you are swapping that ej207 to a 2002-2005 wrx your usdm ecu can start and run the ej207 with a proper map, granted avcs won’t be functional. If you want functional avcs you need a 16 bit jdm with avcs ecu. Said ecu can come from a jdm STi, also from a wrx or forester, including vehicles with automatic transmission. I’ve completed those type swaps many times.
Here are two of those swaps, engine coming out of my bugeye was a ver 7, engine inside the van is the ver 9 I installed when the ver 7 burnt a valve.
Saabaru is no longer in my possession as I sold it to a friend but still running on a jdm ej205 with avcs.
