Welcome to the North American Subaru Impreza Owners Club Sunday March 23, 2025
Old 02-02-2025, 07:25 PM   #1
BatsArtHaus
Member#: 540193
Default EZ30R Swap
Love being called a Noob but got to start somewhere.
I've read a lot and search through but can't find an answer to my particular set of questions. Happy to be told where to go (literally and metaphorically)
I guess the worst news is that this is a legacy based question but around an engine you all love.
I have 2 BH5s, one with a 2.5 auto drive train, decent body work but needs a new undercarriage thanks the UK's terrible weather and salty roads. And one with a 2.0 5MT with an equally pants underside but with brand new front and rear subframes.
I also have an EZ30R engine (low mileage) and pretty much the entire loom (lights and some final ancillaries missing). I have the ECU, keys, ignition and cluster. BCM and TCM. The engine came from a 2005 BP Auto, very early version of the EZ30R.
And I know what I am suggesting is a lot of work. I'm also not a mechanical novice and have a wide selection of "friends" to help out.
But, I'm going to take one of the BHs and turn it into a two seater pick up and swap in the EZ30r engine. Short term keeping the 5MT.
I've been chatting to AGT in Australia and they have a solution to remove the cluster (making a MT swap a bit easier) and get rid of the immobilizer but it's a pricey option once the freight is included.
The intention is to have a road legal vehicle so that means no standalone so I'm thinking that I could strip the BH, send off the loom and install the adapted loom with the new engine, turn the key and drive away. It's that simple, right?
BatsArtHaus is offline   Reply With Quote
Old 02-02-2025, 09:37 PM   #2
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper BK, 5MT
There's a few to chew on here, but this gives you some idea of a nicely done build.
https://forums.nasioc.com/forums/sho....php?t=2945078
Old 02-04-2025, 03:43 PM   #3
BatsArtHaus
Member#: 540193
It's a nice swap.
If anyone has done EZ30r into non canbus gen3 chassis, I'd be keen to read about it.
Old 02-04-2025, 04:09 PM   #4
Jedi03
Member#: 491095
2009 STi Blue
a clean method i have seen is take literally everything out of the donor car and put it into the other one. it sounds like you want to keep the manual trans which is relatively easy to keep, just look at how to bypass the neutral safety for the auto
Jedi03 is offline   Reply With Quote
Old 02-04-2025, 06:04 PM   #5
bo2o
Member#: 167238
Swapping the whole donor car setup sounds like a good idea. Just bypass the neutral safety switch for the manual trans, and you should be good to go.
bo2o is offline   Reply With Quote
