Welcome to the North American Subaru Impreza Owners Club Saturday September 19, 2020
Old 12-14-2009, 12:59 PM   #1
Mrs.COS
Member#: 30206
centralohiosubarus.com
Default how much Electric do you use? Spawned from the Green Thread
I got to thinking about electric use and was examining our useage. Got me wondering what others are using...
Seems our highest useage is in February. and our lowest is in May according to our 36 month output..
Our house is all electric, including new heat (2 years ago), newer windows..(within the last 10 years) and our house is a split level ~1400sqft.
February-2800khw
May -899khw
According to AEP-
$3.74 is average daily cost for current electric useage
What are you running? how big is your house?
Mrs.COS is offline   Reply With Quote
Old 12-14-2009, 01:10 PM   #2
Matt K
Member#: 45204
16 you don't
respond to danger
~2300 sqft or so, gas heat and hot water. 3 ~28 year old guys living there (including me). Forced hot water baseboard heat.
sep:827kwh ~$140
oct:1448kwh ~$245
nov:1157kwh ~$196
in other words, we burn a lot of power and pay a ****-ton for it. We're working on figuring out the biggest culprits and reducing them.
Electric heat/hot water would be KILLING us.
Matt K is offline   Reply With Quote
Old 12-14-2009, 01:11 PM   #3
NJSwamplands
Member#: 97227
how much electric?
NJSwamplands is offline   Reply With Quote
Old 12-14-2009, 01:12 PM   #4
Tgui
Member#: 44771
Why don't people post their kwh/sqft ratio!?
Tgui is offline   Reply With Quote
Old 12-14-2009, 01:13 PM   #5
express_wagon
Member#: 68346
2019 GLI
2004 Tacoma
From my billing history
Transaction Date Transaction Description Transaction Amount
11/30/2009 Billing Journal $71.08
10/29/2009 Billing Journal $77.12
9/29/2009 Billing Journal $86.35
8/28/2009 Billing Journal $92.04
7/30/2009 Billing Journal $67.90
1,500sq-ft
3 people living in 2 bedroom house
No AC, electric dryer, 1 bigger TV, 2 fridges, gas everything else.
express_wagon is offline   Reply With Quote
Old 12-14-2009, 01:14 PM   #6
Brad Pittiful
Member#: 34931
. Super bowl LII
Champions!
i use the exact amount i need to run all my stuff
Brad Pittiful is offline   Reply With Quote
Old 12-14-2009, 01:14 PM   #7
Mrs.COS
Member#: 30206
I did post my SqFtage..
Old 12-14-2009, 01:15 PM   #8
sasiki
Member#: 219917
2002 WRB Molested by
Drunkmann Tuning
Last month we used 550kwh.
This month - will be around 1500kwh.
Next month - should be around 900kwh.
During the summer, it's around 750kwh. We use a window AC in the room we are always in and leave the central on 81 or so.
Electricity runs about 12 cents per kwh.
We had a new electric furnace installed last winter that really sucks. The air coming out isn't hot enough to do much good so it runs all the time. We are not going to use it any more so next month's usage should be around the 900kwh mark.
Our house is about 1600sq/ft. The windows are old school 4 inch slat roll out ones. The exterior is old school 8 inch think block and I doubt there is any insulation within the walls. It's a company house in which we pay nothing except utilities to live in. I can't complain..
sasiki is offline   Reply With Quote
Old 12-14-2009, 01:17 PM   #9
Mrs.COS
Member#: 30206
is it a heat pump? Because, heat pumps dont put out "Hot" air.. they put out ambient air, which to me, never feels like our house is warm enough, even when the thermostat says 68.. I just put on more clothing and blankets to warm up..
Old 12-14-2009, 01:19 PM   #10
sasiki
Member#: 219917
Drunkmann Tuning
It's not even a heat pump. It's heat strips. The coils heat up and air blows across them. We had a gas furnace last year. At least with it, we could turn it on to get the chill out. This new central heat is useless. When it is on, I can watch the power meter nearly spin off the spindle.
Old 12-14-2009, 01:20 PM   #11
Tgui
Member#: 44771
How many people on this forum do you think can even do basic math?
Old 12-14-2009, 01:21 PM   #12
Qcanfixit
Member#: 135762
2059 Venturi Skimobi
transparent aluminium
Originally Posted by NJSwamplands View Post
how much electric?
how can she slapping?
Qcanfixit is offline   Reply With Quote
Old 12-14-2009, 01:21 PM   #13
[email protected]
Member#: 67
1999 Outlasting
the competition.
found last months here
gas 6 therms
electricity 345KWh
this bill was 51.00 bucks
wife and i with two dogs. 1950's house @1400sqft with gas heat, stove and a tankless water heater. Electric hot tub out back. not bad
Old 12-14-2009, 01:22 PM   #14
2k2
Member#: 12368
2008 Infiniti G35X
2011 BMW X5 Diesel
OCT: 3980kwh... although we also had construction going on in the house and lots of power tools plugged in. I am also not sure if they make up their difference between the estimated month before and the actual by adding on the October so it might be less. Nobody lived here last year so their estimated values for each month are very low... like $20 a month for a 2000 sq ft house with 3 people living in it. Not to mention I have pretty much had some type of construction going on for the past 3 months.
Good thing I only pay 5.5cents per kwh
2k2 is offline   Reply With Quote
Old 12-14-2009, 01:24 PM   #15
Mrs.COS
Member#: 30206
5.....
Old 12-14-2009, 01:29 PM   #16
Chromer
Member#: 20325
08 Yamaha WR250R
07 Suzuki DL650
Because it doesn't matter if you don't have electric heat or central air... And should go down as square feet goes up (less surface area per volume).
10 kWh/day at $0.17/kWh. Oil hot water, wood heat with oil backup. House uses ~300 gallons of oil a year and 5 cords of firewood...
Chromer is offline   Reply With Quote
Old 12-14-2009, 01:43 PM   #17
ZMANNH25rs
Member#: 9401
. Truth is a
pathless land...
I file this stuff under the "Things I Don't Pay Attention To" folder...
ZMANNH25rs is offline   Reply With Quote
Old 12-14-2009, 01:56 PM   #18
VuickB6
Member#: 193568
September - 1360kwh - $79.37
October - 1109kwh - $65.55
November - 1069kwh - $62.20
I pay just under 6 cents/kwh and have pretty much a 1kwh per sqft ratio.
1050 sqft, built in the early 80's. New energy efficient vinyl framed windows throughout, newer A/C unit, new electric water heat, and recently had the blown in fiberglass insulation removed and replaced with cellulose insulation. Everything in the house in electric btw...
VuickB6 is offline   Reply With Quote
Old 12-14-2009, 01:59 PM   #19
Matt K
Member#: 45204
16 you don't
respond to danger
i filed it there until that first ~$200 electric bill showed up...
Old 12-14-2009, 01:59 PM   #20
timmah
Member#: 54203
2011 WRX
billing period 10/14/09 to 12/12/09
527 kWh
Delivery Service: 55.90.
Supply Service: 31.74
45 therms of gas:
Delivery Service: 36.88
Supply Service: 31.56
See what i was talking about in the other thread? christ, the delivery is more than the ******* usage!
and this is a ~1200sq/ft townhome, 3 people living here. gas heat, and hot water.
timmah is offline   Reply With Quote
Old 12-14-2009, 02:10 PM   #21
Akirasoft
Member#: 2973
2018 Camaro ZL1 1LE
Red
hmm, im not actually sure on teh usage. I know I pull a near constant 15A in my home office alone since I frequently pop the breaker with the current setup, i need to relocate some of the machines to another circuit. the rest of the house probably not that much since we have gas everything.
I think our bills are usually about 140-150/mo with up to 225 or so in the summer running the AC.
Akirasoft is offline   Reply With Quote
Old 12-14-2009, 02:32 PM   #22
Sideshowbob
Member#: 50304
97 TJ Wheeler
12' TSX Wagon
~2,500 Sq Foot home in Upstate NY, near Albany. Nice upgraded furnace (gas heat), old school hot water heater (gas), rarely use A/C. Two people living in the house.
June- 465 kwh
July- 468 kwh
Aug- 706 kwh
Sept- 582 kwh
Oct- 591 kwh
Those numbers are likely a little skewed as we have been renovating which means lots of lights on and other **** running all day.
We seem to peak at about 200 therms in the winter coldest months, down to 11 in the summer. Most winter months are around 175 therms.
Sideshowbob is offline   Reply With Quote
Old 12-14-2009, 02:48 PM   #23
Jack
Add Lightness
Member#: 13699
not my president
(From General)
My checkbook only shows $$
Middle of the summer....we have central air....2800 sq ft. $350. About $200 is electricity and the rest is graft and corruption taxes, best I can tell.
Old 12-14-2009, 03:02 PM   #24
GodWhomIsMike
Member#: 102287
2019 GMC Canyon
From November 15th to December 8th
1269 kWh
Billed for: $127.
GodWhomIsMike is offline   Reply With Quote
Old 12-14-2009, 03:26 PM   #25
Thaddy
Member#: 128109
2011 E82 135i
Alpine White
1269 kWh
Billed for: $127.
You're near Scranton, right? It looks like prices peaked out around $57/MWh on the 8th
Thaddy is offline   Reply With Quote
people in one bedroom apartments, how much electricity do you use? captaind Texas Impreza Club Forum -- TXIC 19 07-31-2008 09:25 AM
How much money do you think you would have to save for the gumball? STiTuner Off-Topic 14 02-10-2004 01:12 PM
PWR Radiator. How much Coolant do you use? mav1c Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 10-22-2003 01:28 PM
How much gas do you use? BlazingRS Normally Aspirated with bolt-on Forced Induction Powertrain 24 03-29-2003 09:41 PM
How much HP do you get from 1 PSI of boost? Scoob Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 21 07-31-2001 12:18 PM
