Welcome to the North American Subaru Impreza Owners Club Thursday September 24, 2020
Old 02-21-2019, 10:36 AM   #326
Smurftastic
Member#: 243697
17.4 PSI ECUtuned 02
BLOD Cofounder|TopScoob31
Originally Posted by TDagen View Post
Nice work learning to tune it. It's fun!
Also nothing better than knowing what is really going on tune wise, if something is off you are way more likely to catch it or feel it. Do you have E85 in your area? That stuff seems to help keep motors alive longer. It burns cooler in the cylinder vs gasoline.
Get a good shot of your new "semi" meaty tire setup! From what I can tell (strange angles) it looks bad ass. Always nice to have some extra grip with the power.
Finally got a good pic today, post coilover adjustment.
https://i.imgur.com/vD1dWUa_d.jpg?maxwidth=640&shape=thumb&fidelity=medium
Smurftastic is offline   Reply With Quote
Old 02-21-2019, 12:40 PM   #327
Foo_Blyat
Member#: 93750
Murf, if you’re interested , I have GD rear tail light brackets that have been sand blasted and powder coated wrinkle black from my old time attack build. Comes with socket head screws. You can have them for free to help motivate uourself to do 04/05 rear bumper
https://i.imgur.com/jAnEBmY.jpg
Foo_Blyat is offline   Reply With Quote
Old 02-21-2019, 12:52 PM   #328
TDagen
Member#: 163648
V9 6mt R180 Brembos
Looks tough from the back! I know you said you would have rather went 255/40/17 but something about those tires makes it look fast to me. I think it's because it kind of looks like drag radials from the height. I like! What's the offset?
War veteran? Thank YOU for your service, Patriot.
Originally Posted by Foo_Blyat View Post
If you don't mind i would GREATLY appreciate it. I learn just as fast thru someone elses experiences as i do if i were in the driver seat myself so EVERY bit of reading i can do or any videos i can watch count me in. im like a sponge
Ok Foo, just be aware that I was learning and many times I was responding at work or while on the go so it's a rough read on my end here and there, hahahaha. I was reading through it a bit yesterday and wow I have come a long way tuning, or just in general
But I think it will be helpful for you to be able to download the different rom/map revisions that were made as we went and see which maps were changed to adjust boost or adjusting timing etc.. And also you can go through my logs and see which parameters you should log for what and learn what the parameters are that your logging.
For the record this motor (stock sti shortblock) lasted 22k miles/3 years of heavy heavy abuse, it was tuned by me right from the start. It had an 18g (360whp), then a 30r, then a borg 9179 (40r sized) twinscroll, then hta86 making 600+ whp. I attribute the stock block lasting so long (with all that power) to running E85 and after learning to tune it myself I was able to keep a much closer eye on the tune than your average suby owner. The car was run at around 360 whp in its mildest form and 600whp in its wildest. At the end the car began putting out a 007 smokescreen and after teardown it turned out to be a ring land.
http://www.romraider.com/forum/viewt...&view=previous
TDagen is offline   Reply With Quote
Old 02-21-2019, 01:26 PM   #329
Foo_Blyat
Member#: 93750
THIS IS PERFECT! I feel like im right there 10 years ago real time. I'm going to make my way thru the entire thread post by post.
I found a dell xps 15 9550 that isnt being used so i reformatted it and updated all the drivers. it has an i7 and 16 gb ram so as a dedicated tuning laptop i think its more than enough. just downloaded ecu flash and rom raider and went thru the setup procedure on the forums. Just need to wait for the cable to arrive
Old 02-22-2019, 10:58 PM   #330
Smurftastic
Member#: 243697
The offset is +25, a bit more aggressive than stock, but amazingly, at that offset, I am still rubbing the inside if my fenders on the front during turns. Time for spacers and a widebody fender setup perhaps
Old 02-22-2019, 11:00 PM   #331
Smurftastic
Member#: 243697
How do the 05 brackets differ from the 04 brackets? I literally took a.grinder and cut a half circle into my rear bumper and bumper beam to make 05s fit
Old 02-23-2019, 10:46 AM   #332
TDagen
Member#: 163648
V9 6mt R180 Brembos
I have a set of 05's I picked up for the bugeye, what's this about cutting the rear bumper beam? Lol!
Old 02-23-2019, 10:54 AM   #333
Smurftastic
Member#: 243697
When you take off the tails, if you want that half circle to sit more flush, just take out a Dremel and trim the bumper a bit. When you do, you will see some bumper beam you can (but don't have to) also trim. The only difference in terms of fitment is maybe one or two millimeters, and it's not mandatory, but I figure what the hell
Old 02-23-2019, 12:05 PM   #334
TDagen
Member#: 163648
V9 6mt R180 Brembos
That doesn't sound too bad if they will fit a little better. Cool.
Old 02-27-2020, 01:41 PM   #335
Smurftastic
Member#: 243697
I've been AFK for a loooong time... nearly a year. But finally time for an update....
I pieced together this kit over the last year or so, and it's nearly ready for paint or vinyl... not sure which direction to go yet.
Old 03-21-2020, 09:29 AM   #336
Smurftastic
Member#: 243697
Wanted to suede to match the 2012 STi gray/black/red suede seats, so decided on this -- finishing up now
Old 03-23-2020, 05:00 PM   #337
KeithS05RS2.5
Member#: 306422
2005 Impreza 2.5RS
Dark Blue
Very nice!
KeithS05RS2.5 is offline   Reply With Quote
Old 03-25-2020, 09:55 AM   #338
Smurftastic
Member#: 243697
Got all of the door panels back on, and working on some additional upholstery work and sound deadening on the interior... teaser pic for now.. more when this is all said and done!
Old 03-25-2020, 10:41 AM   #339
KeithS05RS2.5
Member#: 306422
2005 Impreza 2.5RS
Dark Blue
I like it. Wanna see a pic with the seats in frame too. I would see if there is a suede shift boot available too but that's just my 2 cents.
Old 03-25-2020, 12:50 PM   #340
Smurftastic
Member#: 243697
I'm having some trouble with the door handle clip fitment on the passenger side door... something to do with the suede foam backing being so thick. So for now, here's an example. I don't think I could pull off these door cards if I didn't have 2010+ seats.
Here's one of the back.. I did suede black flocking on the rear C pillar covers but I am thinking about redoing in black perforated suede.
Old 03-29-2020, 03:41 PM   #341
Smurftastic
Member#: 243697
Soon.
Old 04-08-2020, 05:44 PM   #342
KeithS05RS2.5
Member#: 306422
2005 Impreza 2.5RS
Dark Blue
Drool ...
Old 04-12-2020, 09:17 AM   #343
Smurftastic
Member#: 243697
Now 90% done with the interior project, some more steering wheel goodness coming in the near future
Not 100% happy with the carbon fiber vinyl, may look into laying real carbon fiber.
Old 04-12-2020, 10:34 AM   #344
moby4dick
Member#: 51901
'04 WRX
Hi Smurf,
I just meandered onto your thread...funny that you've done the door panels in red. I see you also decided to do the armrests in the pictures with them installed. That's been on my mind and I'm looking to get a door card to experiment with to give it a trial run. A place called RPG in California sells a number of CF parts, interior and exterior, and has the top portion of the door card in CF. I'm considering doing that plus Alcantara red for the door.
Anyway, looks great!
moby4dick is offline   Reply With Quote
Old 04-14-2020, 09:15 AM   #345
Smurftastic
Member#: 243697
In my opinion people in the Subaru community generally undervalue red suede interiors
In other news, I finished vinyl wrapping the widebody panels last night which was honestly, kind of a bitch. But, I finally learned a perfect edge sealing method.
Time to get ready on the rest of the car
Old 04-23-2020, 10:00 AM   #346
Smurftastic
Member#: 243697
Updated photo now that the initial steering wheel job is complete. Chose the AutoInteriorTechnic stitch on cover... generally happy but may actually take the steering wheel off to get fitment perfect. Right now it's just good enough.
Pretty happy with the steering wheel job in general, in terms of overall cost. Worn out 2007 steering wheel with rebadged Saabaru airbag cover. It may seem strange, but piecing together this way saved a significant amount of money over just buying a 2005-2007 STi setup.
Old 04-28-2020, 10:20 AM   #347
Smurftastic
Member#: 243697
Far beyond the point of no return at this point.
Old 05-03-2020, 07:49 AM   #348
KeithS05RS2.5
Member#: 306422
2005 Impreza 2.5RS
Dark Blue
The end result will be worth it!!
Old 05-04-2020, 09:30 AM   #349
Smurftastic
Member#: 243697
The project continues, slowly. Trying to take the time necessary to have a decent end product.
Old 05-04-2020, 08:15 PM   #350
Lephayden
Member#: 514448
That thing look awesome
Lephayden is offline   Reply With Quote
It's about damn time I got a dog! Nick Off-Topic 144 10-28-2019 06:50 PM
It's about damned time someone made a musical I would actually go see. UberWilhelm Off-Topic 6 07-02-2010 11:28 PM
MY20G Bugeye Build Thread white02_WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 02-04-2010 08:02 PM
It's about damn time....Remy is getting a new car.. Remy E. LeBeau Off-Topic 43 04-02-2004 03:27 PM
It's about damn time i did it... Hassassin Proven Power Bragging 35 11-19-2003 01:32 PM
