Welcome to the North American Subaru Impreza Owners Club Sunday September 20, 2020
Old 06-05-2020, 07:23 PM   #126
archer1.8
Member#: 148335
2018 STi Type RA#454
Installed the Group N Transmission Mount and Group N Crossmember Bushings today. Install was very easy. No more noticeable NVH from the drivetrain since the Group N Shifter and Group N Bushing added so much already. The the only time I notice a difference is the 1st to 2nd shift being a lot nicer feeling. Overall the drivetrain mods are done except for maybe a carbon driveshaft in the future.
archer1.8 is offline   Reply With Quote
Old 06-05-2020, 07:28 PM   #127
archer1.8
Member#: 148335
Jeep CJ7 Build Continues....Interior Almost Done
Old 06-25-2020, 03:05 PM   #128
archer1.8
Member#: 148335
Not alot of updates on the RA as of late. A few track days coming up in July. I also got word my S209 Intercooler Sprayer Harness finally shipped! Looking forward to seeing if that installs
Been working my ass off trying to finish this Jeep project up before the summer is over.
Old 07-03-2020, 09:09 PM   #129
archer1.8
Member#: 148335
Here we go!
FINALLY received my S209 Intercooler Sprayer harness. This thing was a pain to source. I tried to buy this off of 10 different dealer sites back in March only to have them call me and cancel my order. They require proof of purchase of an S209 and a valid Vin#. Dealers told me they had to personally call Subaru Japan to place the order as these are made to order. Other dealers said that this wouldn't fit a "regular" STi as the car is different.
Well, I was able to get a harness through a dealer in Ohio. Super awesome to work with and their parts girl definitely did some leg work to find out what had to be done. Between that and Covid delays the harness arrived today.
Here is the harness all laid out. The left side is the front and the right are the plugs for the reservoir in the trunk. I separated the harness to make it easier to work with.
I removed the Air bag in preparation to remove the steering wheel to install the S209 paddles that are on their way. I also verified that the RA roll connector was pinned for the CVT/Intercooler Paddles which they are.
I removed the lower steering column cover to locate the plug on the back of the roll connector that the S209 Harness Tee's into.
Here is the harness installed and tucked away. The white plug at the lower left is the plug you remove. you install the S209 harness into that spot and then install the plug that you removed into the other side of the S209 harness. Tuck everything up and out of the way and reinstall the covers.
Route the harness over to the lower kick panel to prepare to route it towards the back. Note the plug in the center of this picture. This is the only plug the RA does not have. The S209 has a unique gauge cluster with a low IC Sprayer light that has a 1 wire that connect to this plug.
Old 07-03-2020, 09:09 PM   #130
archer1.8
Member#: 148335
Next remove the B Pillar cover and locate this plug that is stuffed into the pillar. This is the power for the rear door. The S209 harness will Tee into this plug to pick up power.
Here is the S209 harness Tee'd into the RA Harness. Route the Harness up the B pillar, connect, and then push everything back into the Pillar.
Here is the end of the front section. The rear Section of the S209 Harness plugs into this plug and is routed towards the trunk
The S209 Paddles should be here next week hopefully. Once I install them and the new steering wheel surround I can verify that everything works like it should. The 209 Service manual shows you how to use a multimeter to test the circuit. Once i verify it works I will be ordering the reservoir and the plumbing
Old 07-10-2020, 01:27 PM   #131
archer1.8
Member#: 148335
First AutoX of the season yesterday, and first AutoX ever at Pocono Raceway for me. I have only ever run slower more technical courses with the RA and have always had great results. Well, my skills were definitely lacking in the high speed stuff and need to work on that. Amazing venue for sure.
Car was absolutely amazing. With all the S209 mods this car handles so neutral and easy to drive. I did however strip a wheel stud and the lug nut wouldnt come off. Had to drive 100 miles home on the RE71R's in the rain. Talk about sketchy.
Old 07-10-2020, 01:38 PM   #132
archer1.8
Member#: 148335
Received the S209 Intercooler Spray Switches/Paddles today as well as the steering wheel back that accepts the switches. I find it funny that they just add stickers to the transmission CVT paddles lol.
Old 07-10-2020, 02:27 PM   #133
wrx_roggie
Member#: 53206
2018 Type RA
big props on the transformation! especially the IC sprayer. thats very cool.
Quick question on your track wheels. Are they 18" Enkei Raijin? What width and offset?
I'd like to run these in a 18x8 size with Michelin Alpin PA4 tires for the winter. They give a nice S209 light look to the RA.
wrx_roggie is offline   Reply With Quote
Old 07-10-2020, 02:43 PM   #134
archer1.8
Member#: 148335
They are 18x8.5 and I use Enkei Hub Centeic Rings. They are very nice wheels and pretty light.
Old 07-11-2020, 12:04 PM   #135
archer1.8
Member#: 148335
The parts pile is beginning to build up, and that is never a bad problem to have!
I have to replace 2 wheel studs on the front left of the car before anything else happens. The car is parked with my race wheels stuck on the car as the lug nuts on 2 studs galled and wont come off. Should be a fun job
Ordered the 30th Anniversary STi badge. I know the RA-R was built to commemorate STi's 30th Anniversary and the RA for the NBR record. Still not sure if I want to add it to the RA or not.
I remembered my 2005 Legacy GT turbo had a power steering cooler from the factory, however it was a 1 year only thing. This same cooler was a 1 year only on the 2004 Legacy H6 Outback. People have told me this was the JDM STi GR Spec C power steering cooler when the Group N unit was not used. Not 100% sure about that. I looked into the Group N cooler, however it is not as "OEM" fitment as I want for this build.
Old 07-14-2020, 07:46 PM   #136
archer1.8
Member#: 148335
Installed the Spec C/Legacy GT power steering cooler today. Pretty straight forward install. I just spliced into the OEM return line instead of sourcing the OEM rubber sections. Considered the Group N Unit however, on the VA Chassi it isn't as plug and play as on the GD/GR and wanted a clean install.
Old 07-14-2020, 07:52 PM   #137
archer1.8
Member#: 148335
Installed the JDM STi Piano Black HVAC buttons today as well. Super easy install. The pictures don't do them justice.
Old 07-16-2020, 12:10 PM   #138
SatinWhitePearl
Member#: 170780
2018 Type RA #350
2019 Honda Civic Type R
Damn, that's sick!!! I like that.
SatinWhitePearl is offline   Reply With Quote
Old 07-16-2020, 01:22 PM   #139
wrx_roggie
Member#: 53206
2018 Type RA
Sorry if youíve mentioned this, but what are you doing for a spare tire on your road trips? Just chancing it with the kit? Or did you pick up a spare?
Iím thinking of doing the latter for any out of town drives.
Old 07-16-2020, 08:29 PM   #140
archer1.8
Member#: 148335
200 mile AAA towing lol 😆
I only take the RA on 1 long roadtrip a year so i dont sweat it. All my other driving is to track days where i carry my race wheels. Its my second car so i just wing it lol.
Old 07-20-2020, 11:15 AM   #141
archer1.8
Member#: 148335
After countless AutoX and Track days the OEM wheel studs were starting to show some wear. Probably should have added some lube of some kind with the constant swapping of tires. I couldn't get my RE71R's off of the front left hub without fear of breaking the studs and not getting home. Drove 100 miles home in a downpour on those tires. Not the best.
Here is the aftermath of getting the lugnuts off.
5 New Studs!! Success
Then found this in my Street [email protected]#K....
Old 07-20-2020, 12:08 PM   #142
Kostamojen
Member#: 2272
1999 OBS Camo Wagon
1993 FWD Base Impreza
That nail should be fix-able.
Sucks about the studs... I'm amazed my BRZ was the only Subaru I've had issues with the studs with. Sounds like its time for ARP studs.
Old 07-20-2020, 12:55 PM   #143
archer1.8
Member#: 148335
Yea the nail is an easy plug.
ARP studs, 2 piece Rotors, and JDM STi Stainless Brake Lines are the winter project
Over the winter
Old 07-20-2020, 07:58 PM   #144
wrx_roggie
Member#: 53206
2018 Type RA
Wow those are jacked up. So just from the frequent on and off of the lugs the threads weaken and flatten or shear off?
Old 07-20-2020, 08:21 PM   #145
murrdogg24
Member#: 50586
2020 STI
Crystal White Pearl
Thats crazy I've never seen lugs get that jacked up...are you sure your lug nuts are the correct thread pitch...? lol
murrdogg24 is online now   Reply With Quote
Old 07-20-2020, 10:49 PM   #146
archer1.8
Member#: 148335
They are OEM haha. The lug nut and stud galled at the track when i was installing tthe wheels. I could either risk backing the lug nut off and breaking the stud, or tighten them up and take care of them at home. Added just a dap of anti sieze to all the new studs this go around. Even still installing my wheels tonight with my 1/4 impact drill just slowly installing the lug nut metal shavings came off.
Old 07-21-2020, 02:26 AM   #147
murrdogg24
Member#: 50586
2020 STI
Crystal White Pearl
Yeah I never use impact on lugs I always tighten by hand and use a torque wrench, less room for error but is more of a PITA.
Old 07-22-2020, 10:22 AM   #148
archer1.8
Member#: 148335
Received an S209 Intercooler Sprayer Tank from an S209 owner for me to verify electrically that everything works on the Intercooler Sprayer swap.
Everything works exactly as it should! Going to be ordering the rest of the parts today to hopefully finish this swap soon.
Old 07-24-2020, 07:59 PM   #149
archer1.8
Member#: 148335
Installed the S209 Paddles into the RA steering wheel today. Everything was plug and play.
As S209 parts are VERY hard to get through the dealer you can get what you need if you order CVT WRX paddles. The rear steering wheel cover is also a WRX part.
Removed the steering wheel and used a piece of tape to keep the clock spring in place. Also, dont forget to mark the steering column and the wheel.
Everything laid out ready for assembly.
Everything reinstalled and aligned
Old 07-24-2020, 08:02 PM   #150
archer1.8
Member#: 148335
Ended up buying the IC Sprayer Tank from the S209 owner that has made this swap possible.
Bracket mounts from bottom through the drain holes.
Wired up and installed
