Welcome to the North American Subaru Impreza Owners Club Thursday September 24, 2020
Old 02-27-2017, 01:07 AM   #1
JeffrWRX
Member#: 48589
2016 WRX 6mt CWP
@thejeffruhl 387hp/350tq
Default JeffrWRX's 2016 WRX "Here we go again"
To spare you all a long boring story I will cut to the chase. In Jan 2016 I purchased this 2016 WRX, new from Galpin Subaru in Valencia, making it my 9th Subaru since 2003. I would tell you all this IS the one I will keep, but I know no one would believe me. So with that said, here is my 9th Subaru and my plan to make my ultimate WRX.
PS- Many of my older cars have similar threads if you search my username.
CURRENT SETUP:
Updated as of 7/16/2020:
B642DFEC-401D-4E35-90AA-07995725660B (1) by Jeff Ruhl, on Flickr
Power:
Tuned by Ron Watson//Phatbotti
387whp/350wtq on E60
Alignment:
F:-2.5deg Camber, 0 Toe, +8.1deg Caster
R:-1.9deg Camber, 0 Toe
Ride Height:
Front: 25 1/8 to Fender
Rear: 25 1.4 to Fender
Handling/Stopping/Chassis Parts
Rays Gramlights 57DR 18x9.5+38 Gun Blue II
Rays Gramlights Red Center Caps
Firehawk INDY 265/35/18
KICS Leggdura Racing Dangan Shell Type Lug Nut and Lock Set
Racecomp Engineering Tarmac 3's (KW Clubsports 3-way) Custom valved- Spring Rates 500\500
HyperCo Helpers
Racecomp Engineering Front Street Plates
Whiteline LCA
Whiteline 24mm RSB with Braces
Kartboy Rear Endlinks
Whiteline Roll Center Kit
ATE TYP200 Brake Fluid
STI GROUP N Transmission Mount
Whiteline Crossmember Bushings
Project Mu B-Force Pads- F/R
Stoptech SS Lines- F/R
DBA T2 Street Slotted Rotors- F/R
2016 STi Brembos- F/R
Perrin Master Cylinder Brace
Perrin Shifter Bushing Kit *Not installed
DriveshaftShop Carbon Fiber Driveshaft
Beatrush Rear Member Support
Kartboy Wedgelock Kit
Engine
Turbo XS FMIC
Turbo XS Catted J-Pipe
Cobb Flex Fuel Kit
AEM DryFlow Air Filter
Greddy SP Supreme Catback
DeatschWerks DW300c Fuel Pump w/ Install Kit
Grimmspeed Jpipe Studs/Gasket
Grimmspeed EBCS
iBR Full TGV Delete
IAG Performance EGR Block Off Kit
Cobb Accessport V3
Motul XCess 5w40
Subaru OEM Filter
Fumoto Valve
Cobb Radiator Shroud
Perrin Brake Reservoir Cover
Optima Red Top 35
Grimmspeed Lightweight Battery Tiedown
HKS Fine Tune VBelt
Interior/Exterior
JPM Coachworks Alcantara Cluster Surround *Not installed
JPM Coachworks Alcantara Dash Hood *Not installed
JPM Coachworks Alcantara Flat Dash Trim *Not installed
Subaru JDM Aero Splash Guards
Subaru OEM STi Front Lip
Verus Hoodscoop block off
Killer B Motorsports Black Shiftknob
WC Lathe Werks Black Delrin eBrake Button
JDM STi Door Sills- SUBARU
Subaru JDM DIT Direct Injection Turbo Emblem *Not installed
2018 STi OEM Steering Wheel
STi OEM Black Steering Wheel Trim
Lighting
SMY/IPF JDM Fog Lights
Subaru OEM Foglight kit (Bezels, Harness, Trim, Button)
2017 WRX Base Headlights- Donor set
Lightwerkz Quick Retro Kit
Morimoto Mini D2S 5.0 BiXenon
Hylux 2A88 ballasts
XB 4500k D2S HID bulbs
Morimoto harnesss and RetroRubber
Diode Dynamics LED switchback C-Lights
Diode Dynamics C-Light DRL harness
Diode Dynamics LED Kit for Interior/Exterior
Subaru OEM Footwell Lighting- RED
Subaru OEM Mirror Turn Signal Kit- Crystal White Pearl
Parts Uninstalled:
GTWORX Bilstein Trophy Cup Coilovers
Overland Designs- Alcantara STi Center Trim - Part # 92136FG100VH
Overland Designs- Alcantara Diamond Stitched Subaru Extended Arm Rest
Overland Designs- Alcantara STi Shifter Console - Part # 92169VA000
Overland Designs- Alcantara Diamond Stitched STi Shift Boot
Overland Designs- Alcantara Diamond Stitched Brake Boot
Subaru STi Center Cupholder - Part # 66155AG100jc
Subaru STi Cup Holder Insert / Divider - Part # 66155AG010
Subaru STi Cup Holder Mat - Part # 92177AG170
Subaru STi Cup Holder Mat - Part # 92177AG180
Subaru STi Cup Holder Mat - Part # 92177AG190
Subaru STi Console Box - Part # 92174FG120
Subaru Tapping screw (x3) - Part # 904500031
CUSCO type-RS 1.5way rear LSD
CUSCO 80w140 LSD oil
WedsSport TC105n 18x9.5 +35
Michelin Pilot Super Sport 255/35/18
Work CR Kiwami 18x9.5+ 38 in WMB
Work Red Center Caps
Rays Duranut Lugnuts
Bridgestone RE760 265/35/18
Tein FLEX A Coilovers
Bilstein B6 Dampers
Swift Spec-R Springs
Cusco LCA
Whiteline ComC Top Hats
2006 Brembos rebuilt and powdercoated by @detectivecoatings
KNS V2 Brackets
Project Mu NS400
Stoptech SS Lines
Stoptech Rotors
Motul RBF600
AP RACING ESSEX Competition Braking System
AP Racing CP8350 Calipers
AP Racing CP3908 Racing discs with floating anodized aluminum hats
Spiegler Stainless Steel Brake Lines
Ferodo DS2500 Brake Pads
ETS Catback with Mufflers and Burnt Tips *NO Resonator
HKS Legamax Catback
MAPerformance Stage 1 Tune
Recaro Child Seat
Killer B Motorsports White Shiftknob
Grimmspeed DP to Catback Adapter
Perrin Short Shift Adapter
Subaru Matte Black AC Knobs
GCS Climate Control Trim Bezels V2- Red
Previous Setup:
2016 WRX- 02/26/17 by Jeff Ruhl, on Flickr
JeffrWRX is offline   Reply With Quote
Old 02-27-2017, 01:07 AM   #2
JeffrWRX
Member#: 48589
2016 WRX 6mt CWP
Old 02-27-2017, 01:15 AM   #3
JeffrWRX
Member#: 48589
2016 WRX 6mt CWP
Randoms
Untitled by Jeff Ruhl, on Flickr
Old 02-27-2017, 07:34 AM   #4
icedcoco
Member#: 259021
2014 WRX Premium
This is going to be fun. I followed your 2013 WRX journal. Looks great, as expected. Which Recaro child seat do you have? I have the performance ride for my 3 year old, but yours looks like it's the next step up.
icedcoco is offline   Reply With Quote
Old 02-27-2017, 01:42 PM   #5
SDMotorworks
Member#: 453792
Great looking car, love the color of those Brembos. Looks amazing with the wheels and the white.
SDMotorworks is offline   Reply With Quote
Old 02-27-2017, 07:44 PM   #6
JeffrWRX
Member#: 48589
2016 WRX 6mt CWP
Thanks! It's a RECARO performance sport.
Thanks!
Old 02-28-2017, 08:57 AM   #7
icedcoco
Member#: 259021
2014 WRX Premium
Ah! The performance sport. Hmm...might be time to upgrade her and let my little one use the performance ride. Thanks for the reply!
Old 02-28-2017, 09:02 AM   #8
96accord
Member#: 145105
2015 Honda Accord
Subscribed.
It's alright (I had to)
96accord is offline   Reply With Quote
Old 02-28-2017, 12:08 PM   #9
TURBOTOD
Member#: 97130
2004 WRB WIDE STI
COBB/TIC/CUSCO/DSS/TSSFAB
You know... Every time I see this setup in person it always leaves me impressed. I can't tell you how many times I've seen a car on this forum end up with a laundry list of "JDM" items that doesn't flow AT ALL on the car. No vision. No theme. No sense of flow.
Your car (and the ones that came before this VA platform) always impress. Thank you for sharing Bro!
Peace
-TurboTod
TURBOTOD is offline   Reply With Quote
Old 02-28-2017, 04:55 PM   #10
JeffrWRX
Member#: 48589
2016 WRX 6mt CWP
Originally Posted by 96accord View Post
Subscribed.
Peace
-TurboTod
Thanks Bro, means alot coming from you. You have always been a great resource
Old 03-01-2017, 11:11 AM   #11
96accord
Member#: 145105
2015 Honda Accord
I love the Subaru OEM STi Front Lip. I have it on my '15 WRX.
Old 03-02-2017, 12:24 PM   #12
JeffrWRX
Member#: 48589
2016 WRX 6mt CWP
Planning on getting the OEM sideskirts soon
Old 03-02-2017, 12:38 PM   #13
csacharuk
Member#: 460652
2017 WRX Premium
Love the wheels! I wonder how a set of matte bronze would look on my '17 WRB. Hmmmm
csacharuk is offline   Reply With Quote
Old 03-02-2017, 06:10 PM   #14
TAJR02WRX
Member#: 260936
2008 08' XT_SPORTS
World Rally Blue
i gotta say i was a bit sad when you got rid of the bugeye wagon since it was such a well done/clean example of how a bugeye should be, however i totally love how this new 16' looks. great great choice in wheels.
TAJR02WRX is offline   Reply With Quote
Old 03-05-2017, 08:34 PM   #15
JeffrWRX
Member#: 48589
2016 WRX 6mt CWP
Do it
Thanks! I do honestly miss my wagon too, should have kept as a 'beater' Yours is still lookin amazing.
Old 03-06-2017, 09:50 AM   #16
hulagirlnc
Member#: 464076
Love the lip
hulagirlnc is offline   Reply With Quote
Old 03-27-2017, 01:35 AM   #17
JeffrWRX
Member#: 48589
2016 WRX 6mt CWP
Originally Posted by hulagirlnc View Post
Love the lip
Thanks man.
No pictures to update this thread with but I think I am going to upgrade to the GTWORX Bilstein Trophy Cup Coilovers with RCE Camber plates. Hope to make the switch soon.
Old 03-27-2017, 02:14 PM   #18
TURBOTOD
Member#: 97130
2004 WRB WIDE STI
^ Yaaaaaaaaas!!! That or RCE set with MSI Motorsports Top Mounts!
Peace
-TurboTod
Old 03-27-2017, 03:03 PM   #19
teknikaL-
Member#: 460091
2018 WRX
CWP
Awesome build and great choice of color! I'm looking into buying the same soon, but wanted to know how your experience at Galpin was as far as pricing went? Pm me if you dont want to respond on this awesome thread :P
teknikaL- is offline   Reply With Quote
Old 03-27-2017, 03:41 PM   #20
JeffrWRX
Member#: 48589
2016 WRX 6mt CWP
Peace
-TurboTod
Yup... It is actually still a toss up
1. GTWORX Bilstein Trophy Cup with RCE Plates, OEM Rear
2. Ohlins Road and Track
3. RCE Tarmac 2 with RCE Plates front, OEM Rear
I am leaning towards the Bilstein since I dont want to deal with adjusting etc and they are inverted monoflex with 400/400 rates out of the box, and just 1799$
The crazy thing is I can find the Ohlins for 2150 on sale from time to time... tough decision.
Thanks!
Galpin was amazing. Seriously. Ask for Mary and tell her Jeff with the White WRX sent you. Everything was done over the phone and when I arrived the car was ready to go out front like a superstar. Very quick and painless with zero drama.
I was going to pay the car off in the first month but since I found out Mary would get a bonus for a buyer having a loan after 90 days I decided to wait the 90 days just because she was that awesome. I paid it off right after the 90
At the time, White was more sought after and other dealers were charging more for them. After going through 13 dealers I found Galpn and paid roughly 26.2k with the STi SS Kit, Homelink, and Extended Armrest.
Hope that helps.
Old 03-28-2017, 01:16 AM   #21
teknikaL-
Member#: 460091
2018 WRX
CWP
Thank you for the detailed reply Jeff. I will definitely be contacting them for a quote when 2018 orders open up. Once again, beautiful car, you have great taste. Next up, sound system?
Old 03-29-2017, 12:07 AM   #22
jerryscherry
Member#: 381213
2015 WRX - BASE -CWP
Crystal White Pearl
very nice. simple and clean, and well-executed. Always had a soft spot for that work metal buff
jerryscherry is offline   Reply With Quote
Old 03-29-2017, 12:47 PM   #23
miked1978
Member#: 460679
2017 WRX
CBS
I need that Alcantara in my life. Where did you get the gauge surround?
miked1978 is offline   Reply With Quote
Old 05-26-2017, 01:53 PM   #24
JeffrWRX
Member#: 48589
2016 WRX 6mt CWP
JPM Coachworks
Some updates... sold the ETS, Works, and Teins. Posting the Brembo kit for sale next week. I did have Swifts installed on my OEM dampers and I have to say they are amazing. Firm yet the ride is so much better and the drop is perfect. I also feel that the car handles much better as well.
I will have some updates with other new parts soon.
Old 05-28-2017, 08:06 PM   #25
JeffrWRX
Member#: 48589
2016 WRX 6mt CWP
Need better pictures but here is the car now:
