02-24-2011, 12:00 PM | #1 |
Member#: 77302
MWSOC
Vehicle:damn well better bail me out of this **** |
Engine/ECU Harness Pin Removal
My friend is finishing up a V7 swap into his 2002 WRX.
Can anyone provide tips on how to remove pins from the factory ECU/Engine harness without damaging them (breaking the locking tab)? Thanks in advance. |
02-24-2011, 12:05 PM | #2 |
Member#: 197764
NESIC
Vehicle:2002 Nissan Frontier buh bye WRX :( |
http://forums.nasioc.com/forums/show....php?t=1867935
Apparently a lot of people run into this problem. search search search search search search search (obligatory ) |
02-24-2011, 12:32 PM | #3 | |
Member#: 77302
MWSOC
I did search - got ton's of BS. I guess I wasn't using the right terms. I was using 'remove pins factory harness' and 'remove pins ecu' and 'swap remove pins'. Unfortunately, the thread says to jam some **** into the plug and pray that you don't destroy anything. I was more curious where the locking tab(s) are so that I dont just jam something in there and chew it up. |
02-24-2011, 12:42 PM | #4 |
Member#: 197764
NESIC
^^ Yea, it seems to be one of those things that needs repair more often than not when pulling these wires. I half hate Subaru for all their impossible to take apart things, the numbers of which never cease to amaze me the more I work on my car
here's another http://forums.nasioc.com/forums/showthread.php?t=490422 Seems to be the consensus that the Snap On tool for this is the way to go, but this thread has some details on where the lock is on each pin partway down that page. |
02-24-2011, 12:30 PM | #5 |
Member#: 156086
If you're looking to remove the female terminals that are in the connector that connects to the ECM, good luck. Those terminals are tiny. You can get them out, but usually not without destroying them, and they are NOT included in the Subaru terminal repair kit.
02-24-2011, 05:58 PM | #6 |
Member#: 104878
TXIC
Vehicle:02 wrxbastardchild aw, MPS 2.34 breaking in |
I use a snap-on depinning set and the "T" sewing pins from walmart. It works great, I depinned my entire engine harness to rewire and tuck it.
08-13-2013, 02:48 PM | #7 |
Member#: 290547
here is a subaru .pdf that has pics of the part numbers for the terminals, as well as the depinning tools.
http://techinfo.subaru.com/proxy/607...4760668812.pdf |
08-13-2013, 02:55 PM | #8 | |
Member#: 287534
Similar Threads | ||||
2004 STI Engine/ECU/Harness | rjburner | Engine/Power/Exhaust | 39 | 04-18-2010 11:51 PM |
WTB:: 02-03 wrx engine/ecu harness | sof220 | Private 'Wanted' Classifieds | 0 | 01-14-2010 06:02 PM |
Feeler TN 05 STi engine, ecu, harness | 2006whitesti | Engine/Power/Exhaust | 29 | 08-20-2008 10:05 AM |
ECU pins and engine harness pins??? | MK19_ | Electrical & Lighting | 3 | 04-21-2005 07:10 PM |
WTB: WRX engine, ECU, Harness.... | ImprezaDude | Private 'Wanted' Classifieds | 4 | 12-07-2004 06:04 PM |
