#76 |
Member#: 490123
![]() I almost pulled the trigger on doing this head unit upgrade on my '17 Forester XT but swapping out the amp is holding me back. I can't find one less than $500. Everything else I was able to find for a reasonable price except that.
#77 |
Member#: 505819
Vehicle:MY17 Subaru XV Crystal White Pearl |
![]() I did my MY19 Map (built august 2018) radio with ACP & AA with HK amp swap over this long weekend and have pretty much managed to do it but there are some issues.
I purchased the USB 2.1A module and cable from the original wreck and found that mine worked straight up but the USB port I THOUGHT the connecting cable went in (there are three USB ports in the back of the HU) and I swapped it to match those little lugs that differentiate each port. I now have it in the third one to the right looking at the rear of the HU, This may be assigned AUX. I had connectivity with a generic iPhone cable once I realised the little lugs vary on each of the three USB rear inputs. Id connect some extra 2.1A USB's to the inside of the Lift up arm rest too but not sure if this USB connecting cable is available in a longer length? Steering wheel control are a disappointment as they re mapped with all different positions mostly seek left right dominate volume, and now volume is the Index and Back button to the right of the button array on my model XV. Protivakid let me know if you ever decide to re write the code for that Smart box you mentioned. Or I decide on a complete WRX/STI steering wheel that matches the head unit MY. The same type of Steering wheel for the MY19 WRX STI https://jspecauto.com/en/accessories...heel-for-sale/ The MY17 XV/Crosstrek Steering wheel http://www.canadianautoreview.ca/rev...n-edition.html |
#78 | |
Member#: 265148
Vehicle:2016 WRX White |
![]() Quote:
It looks like your 2017 crosstrek steering wheel is indeed different. A pic of my 2013 wheel can be seen here: http://www.cars101.com/subaru/crosst...strek2013.html If you compare this to the WRX wheel the switch footprint is the same so the switches will swap between the two. Unfortunately, unless you can find switches from another model that fit and happen to map values correctly (would be a lot of trial and error unless the FSM lists values, I can check later) you may end up having to swap the whole steering wheel to a WRX wheel if you wanted the switches to behave. I just got used to what Vol +/- was and it hasn't been an issue. I'm not sure what the other two usb looking jacks on the back of the radio do, I just plugged the one usb cable into the keyed radio port it fit in. Making an extension cable wouldn't be hard though, it's only 5 wires, just cut an existing one and solder/splice in some new longer wires. |
#79 |
Member#: 505819
![]() Protivakid I see in your initial post that you rejigged the DAB+ (sirius XM) FAKRA connection directly into your HU (this is the same for me on my HU) but ask hopefully for clarification and is related to this ACP AA MY19 upgrade situation. My MY17 original set up never had DAB+ and the connection to the original HU is more or less a mute point the new MY19 Unit has the addition for Digital Radio over here in AU. I was looking on the WWW regards FAKRA connections and the Subaru connections. I ask this Question? the male FAKRA to Female FAKRA plugs seems a bit different for different Car Manufacturers?? I see the Subaru type are not the same as these type I have sourced. Anyone got some experience here? Im thinking one of these DAB+ Antennas and the joining shunt.But the male round design seems not a Subaru standard? I realize the images are a male gold Shunt and not the female version I would need to marry these two together. All I intend to do is snake the cable for the DAB+ up somewhere in the roof lining and call it a day after connecting with the correct FAKRA.
![]() ![]() Last edited by Joff; 05-25-2022 at 06:52 AM. |
#80 | |
Member#: 265148
![]() Quote:
https://forums.nasioc.com/forums/sho....php?t=2944986 |
#81 |
Member#: 505819
![]() it does I have now ordered what I need. I decided that Id like DAB+ although Im sure I will hardly use it but thought "What the Hell?" Im moving on now to Wireless CP dongles
#82 | |
Member#: 265148
![]() Quote:
https://www.siriusxm.com/trial-eligibility |
#83 |
Member#: 530230
![]() Does the StarLink microphone that's in the dome console still work after this?
#84 |
Member#: 265148
#85 |
Member#: 505819
![]() I'm still very keen to source some type of black box that will marry the MY19+ Factory HU Steering wheel controls to my current XV Steering wheel. The resistance factor on these toggle style Controls are (now that i understand more on them) needs much more than a physical switch design.I realise there are units out there for those Aftermarket set ups, maybe a tech savvy individual has played with this idea? Does AAH do these, maybe they can do one for Factory installs?? or are they made elsewhere?
New WRX STI SW without an AB is going to be around the $400AU price point. AB module another $500AU although the AB module from original wheel will fit although the bottom edge at the base is longer and may need to custom up that plastic wheel garnish piece. The WRX STI wheels are very attractive and also have that flat bottom design the XV does not. |
#86 | |
Member#: 265148
![]() Quote:
#87 |
Member#: 466464
Tri-State
Vehicle:2018 WRX Limited 6MT LBP |
![]() I have a 2018 WRX Limited, non-HK, non-NAV radio and I just want the AA/ACP function while staying OEM. Since I'm not trying to add Nav or HK, it looks like from the OP, I would only need:
Subaru 86471VA620 (PHONE) 19-20 WRX Head Unit 2019 USB Jack 86257SJ131 2019-2020 WRX XV Impreza Outback Forester Legacy Steering Wheel Controls 83154VA300 Wiring for the door switch (optional) The only question I have is will the StarLink functionality still work properly? I do have the SOS button in mine. |
#88 | |
Member#: 265148
![]() Quote:
#89 | |
Member#: 297373
South East
Vehicle:2018 STI Type RA Black |
![]() Quote:
#90 |
Member#: 530494
![]() I have a 2017 base STI with HK. Can someone please reconfirm on which parts I would need besides the USB 2.1 hub?
#91 |
Member#: 265148
#92 | |
Member#: 530494
![]() Quote:
Radio 86471VA610 / 86471VA710 / 86481VA730 (MAP) - 86471VA620 (PHONE) 19-20 WRX w/ Pigtails Amplifier 86221va050 19-20 WRX w/ Pigtails Wire 18Ga 20 Colors 1FT Which would one would I need to purchase which is compatible with my MY17 HK system? |
#93 | |
Member#: 265148
![]() Quote:
#94 |
Member#: 466464
Tri-State
#95 |
Member#: 466464
Tri-State
#96 |
Member#: 530990
![]() Thank you for sharing this information! I will be trying to do the swap myself.
