#1 |
Member#: 519840
Vehicle:2018 WRX Silver |
![]() Base model WRX (2018)
I'll get right to the point: Mods: Stage 2 Tune for Speed Density COBB AOS, CAI & Turbo back Exhaust Oil Used: 5w-30 full synthetic On cold start after sitting and while idling at stoplights or a long wait a stop sign I will get blue smoke out of the exhaust. I have no oil leaks and I am noticing some oil consumption. Could people please provide some areas that I should check to see if I can rectify this issue? Thank you!
Last edited by MosesDisciple; 06-29-2022 at 10:08 AM. Reason: Further clarification |
#2 |
Member#: 448185
Vehicle:2016 WRX DGM |
![]() https://www.perrin.com/index.php?p=s...ump-restrictor
That product is designed for your problem. Cheap, easy fix unless there is something actually wrong. |
#3 | |
Member#: 519840
![]() Thank you!
#4 |
Member#: 419593
Vehicle:2019 EA888 Gen3 crew |
![]() If you are losing oil then it is very likely a bad turbo seal.
#5 |
Member#: 519840
#6 |
Member#: 455661
![]() That Perrin part fixed the same issue completely on my 2016.
#7 |
Member#: 519840
#8 |
Member#: 519840
![]() Update: I still get the blue smoke sometimes. I recently used Royal Purple 5w-30 and the first 1000 miles I believe I noticed significantly less blue smoke after idle especially. Now above 2000/2500 miles I'm noticing it a little bit more and there is a slight bit of black film on the rear bumper. Nothing major, but I can notice it if I don't wash the car for a bit.
