Welcome to the North American Subaru Impreza Owners Club Tuesday August 9, 2022
Old 12-01-2020, 11:47 AM   #1
PotatoFlakeSTi
Member#: 273267
2011 STi / 98 LSTi
Default 2011 Blurple STi Garrett G30-900 .83AR
IAG block seems to have failed - Outfront V4 Ultra going in
EDIT: Nope, looks like the head lifted even with ARP 625+, at a lower power than when the ARP 2000's lifted.
Event: Final Tune Coming Next Week! -
Weather: -
Ambient Temp: -F
Elevation: 5869 feet above sea level
Tuner: Nick at MoFab in Parker, Colorado
Dyno Info: Dynojet
Car: 2011 STI
Transmission: Stock 6 speed
Gear: 4th
Target Boost: 34.0psi
Target AFR: Unknown
Fuel: Pump E85, recorded at 83% Ethanol
Peak HP at RPM: 672.14whp 694.54whp @ ~6300 rpm
Peak Torque at RPM: 613.06wtq 629.98wtq @ ~5200rpm
Baseline hp/tq for a stock on same dyno: ~260whp/280wtq
Graph shows before and after GSC S2 Cams and bowl porting on head... Brushless fuel pump seems maxed at oem 13.8v Voltage upped to 14.8 Radium Dual Pump hanger & 2 Walbro 450's in now.
Engine/Power Modifications:
MoFab Super Low Rotated Kit (V-band up/down)
Garrett G30-900.61AR .83AR Coming+ Turbo Blanket
Tial 38mm Wastegate
IAG Stage 2.5 Block
GSC Beehive Valvespring + Ti retainers
GSC S2 Camshafts.
ARP 625+ Headstuds
Mild Bowl Porting on head
Inconel Exhaust Valves
ETS 3.5" FMIC
Delicious Tuning Flex Fuel Mk. II
Delicious Tuning Stumble fix
TGV Deletes
Secondary Airpump Delete
KillerB Holy Header (V-Band)
iWire Speed Density
Cobb 3 port EBCS
Tomei Expreme Ti Cat back
IAG AOS
GetADomTune Cyl4 Cooling
KillerB Oilpan + Pickup + Windage Tray
Radium Fuel Rails + FPR + Fuel Lines
DW Brushless Fuel Pump (Hardwired) Radium Dual Pump Hanger & 2 Walbro 450's
DW1500CC ID 1700X Injectors
COBB Accessport V3
Driveline Modifications:
Perrin Pitch Stop
Competition Clutch Organic Twin Disc XClutch Sprung Ceramic Twin Disc
STi GroupN Motor/Trans Mounts IAG Comp. Engine Mounts & Torque Solutions Solid Trans Mount
TiC Shifter Bushing Kit
Suspension Modifications:
Cygnus/Fortune Auto 500 Coilovers
2015+ STi Steering Rack
Power Steering Cooler
Whiteline Swaybars
Whiteline Bumpsteer kit
Perrin 20mm Wheel Spacers
Wheels/Tires:
Sparco 2015+ STi BBS
Vredestein 235/45/17 Hankook Ventus RS4 245/45/18
Last edited by PotatoFlakeSTi; 05-02-2022 at 05:33 PM. Reason: Adding the list of mods
PotatoFlakeSTi is offline   Reply With Quote
Old 12-01-2020, 02:26 PM   #2
K3rm1tth3fr0g
Member#: 508105
Link flex tuned 02
WRX EJ205 20G-XTR JDM 6MT
I bet this car is wacko when you get into full boost which seems to come on nice and quick. Lovely build.
K3rm1tth3fr0g is offline   Reply With Quote
Old 12-01-2020, 02:43 PM   #3
Dave D.
Member#: 130990
06 Red Ltd.Wagon
Dom 1.5xtr JJ tuned
I have an IAG Stage 2 block with a Dom 1.5 and a flex fuel build. Recently my heads flat wore out, and when I had the new heads I thought "what the heck" and installed some Kelford 199-b's along with stronger springs and valves.
With the stock cams it would just touch 355whp/370wtq (this is on a Mainline dyno where a new STI reads 200whp/tq) and then drop right off. What a difference with the cams: the car gets to 370/370 now and just holds all the way to the 7400rpm limit. I'm still getting used to shifting near redline, whereas before there was really no point in revving it past 6600rpm.
Additionally, it's making this increased powerband with a significant boost taper up top. The factory cams needed 24 psi boost the entire way, where the Kelfords start at 24 psi but only need 20psi up top. Way more efficient when the revs are up. You want 7800rpm? No problem!
Of course this is just an example; many would prefer a different brand of camshaft, but so far I'm happy with mine.
Dave D. is offline   Reply With Quote
Old 12-01-2020, 09:02 PM   #4
CEEBEE
Member#: 420458
07 WRX STI
Urban Grey
Amazing the turbo can make power to almost 7000rpm with such a small rear housing! Shows an efficient turbine wheel design! Be interesting to see the results if you put cams in it
CEEBEE is offline   Reply With Quote
Old 12-01-2020, 10:19 PM   #5
PotatoFlakeSTi
Member#: 273267
2011 STi / 98 LSTi
Their new V-Band exhaust housings seem to flow really well!
I ran the Dom 1.5XTR with this Flex Fuel set-up before the shaft exploded! Definitely a fun turbo, but I knew I wanted more.
Going back and forth between the S1's at .266 and S2's .272... But there's a whole lot more to it than that, most of which is beyond my understanding... I'll ask my tuner about Kelfords as well.
Old 12-14-2020, 05:04 PM   #6
bigAle06
Member#: 170306
Looks awesome man, excited to get mine done here soon. I have a similar setup with GSC S2s (272)s and a G30-900 w/.83ar. Should be getting dyno tuned here in January and can have some results for you as you make your decision.
-Alex
bigAle06 is offline   Reply With Quote
Old 12-18-2020, 12:38 AM   #7
K3rm1tth3fr0g
Member#: 508105
Link flex tuned 02
This kinda me want to consider a G series over an EFR..... Hmm.....
Old 12-19-2020, 01:13 PM   #8
scoobyfast
Member#: 338128
2013 WRX
SBP
Very nice, terrific power for a street car. Gotta love the power e85 has to offer.
Either set of cams will be a nice upgrade over stock, just have to decide how much you're willing to accept moving the curve to the right. More cam, more (potential) power, more lag.
Looks like you were at Bandimere, any time slips?
scoobyfast is offline   Reply With Quote
Old 12-23-2020, 10:38 AM   #9
Chief_WRX
Member#: 369934
2018 STI Limited
Heritage Blue
That dyno chart looks unreal. Incredible power.
Chief_WRX is offline   Reply With Quote
Old 12-25-2020, 02:32 PM   #10
PotatoFlakeSTi
Member#: 273267
2011 STi / 98 LSTi
My last drag runs were with the Blouch Dominator 1.5XTR making closer to 450whp, not the Garrett G30-900 - the best I mustered was an 11.8 at 9000ft Density Altitude (hot and somewhat humid day at 5800ft).
60ft was around 1.68, on Goodyear Eagle F1 Assymetric 2 tires with about 35k miles on them.
Edit: 124mph
Old 01-05-2021, 12:03 PM   #11
pigboat_2
Member#: 247823
2007 STi limited
I'd like to see a dyno graph from Cryotune.
pigboat_2 is offline   Reply With Quote
Old 01-06-2021, 11:53 AM   #12
PotatoFlakeSTi
Member#: 273267
2011 STi / 98 LSTi
I imagine we'd be looking at a smidge under 550whp corrected on a 'typical' Mustang dyno... likely sub 500whp uncorrected (ie. ACTUAL power at this altitude).
Old 01-06-2021, 11:57 AM   #13
Waddlz
Member#: 395275
2012 STi
wow thats a tiny hotside for our altitude.
Waddlz is offline   Reply With Quote
Old 01-06-2021, 12:07 PM   #14
PotatoFlakeSTi
Member#: 273267
2011 STi / 98 LSTi
We'll see how she flows at higher RPM with Cams... Might move to a .82AR but that'll really depend on how the curve looks.
Not building for Drag Racing in particular, so as long as it's still 'usable' power past 7000 (say 400wtq'ish) I'll be happy
Old 01-06-2021, 12:15 PM   #15
Waddlz
Member#: 395275
2012 STi
Yeah that dyno graph looks really nice for street driving as well. I think I'd prefer the 1.01 with this size turbo, but you'd likely lose some spool.
Old 01-06-2021, 06:17 PM   #16
pigboat_2
Member#: 247823
2007 STi limited
Yeah but I have yet to see a car that makes X at Mofab, run over to Cryotune and make Y. His dyno won't match what you'd see at say SRM or 5250 Performance.
I should have done it myself but I decided to change up my setup before making my way over to Mofab.
Old 01-07-2021, 05:27 PM   #17
Waddlz
Member#: 395275
2012 STi
5250s dyno hurts lol.
I got dyno tuned at Edge Autosport and its a dynomite dyno(which Alan says stock Sti's usualy baseline around 200 whp on these), and my car put down 461 whp 461 wtq at 29 psi on an EFR 7163. Curious what lulz mine would put down on a dynojet.
Old 01-07-2021, 06:15 PM   #18
PotatoFlakeSTi
Member#: 273267
2011 STi / 98 LSTi
Right, well... if you want to pay for a baseline at Cryotune I'm game.
Old 01-07-2021, 06:30 PM   #19
Dave D.
Member#: 130990
06 Red Ltd.Wagon
Dom 1.5xtr JJ tuned
Easy 5's.
Old 01-07-2021, 11:33 PM   #20
silversurfer05
Member#: 366241
2009 09 wrx delivery
Dgm
Id go .82 in a heartbeat. You wont lose much spool as you think, 250-500 rpms at most. And you'd make more power up top and hold it longer. Still looks insane boss, enjoy it!
silversurfer05 is offline   Reply With Quote
Old 01-09-2021, 12:10 AM   #21
pigboat_2
Member#: 247823
2007 STi limited
Cryotune's dyno hurts! 5250 keeps adjusting their calibration so it hasn't been consistent for me, but it's been over 4 years since I've had a car on their dyno and it was new to Mike at the time.
Nah, come do a baseline when I wrap up my new mods/retune and we'll compare! Should be March/April timeframe.
Old 01-12-2021, 12:37 PM   #22
Waddlz
Member#: 395275
2012 STi
[quote=pigboat_2;46495020]Cryotune's dyno hurts! 5250 keeps adjusting their calibration so it hasn't been consistent for me, but it's been over 4 years since I've had a car on their dyno and it was new to Mike at the time.
Yeah my old 60lb a min turbo put down 270/280 at 21 psi on 5250's dyno
I was like oof, time to sell haha
Old 01-13-2021, 10:08 AM   #23
pigboat_2
Member#: 247823
2007 STi limited
Was that on pump gas? If that's ethanol, then yikes...that hurts!
The green (61 lb/min) on my friend's STi at 20-21 psi on E85 at Cryotune made 365, but will take down pretty much anything that makes up to 430. Same w/my car, love it when people say their 30r makes 550 and they don't understand why they can't keep up haha. Numbers are all relative.
Old 01-14-2021, 03:53 PM   #24
Waddlz
Member#: 395275
2012 STi
Agreed
Yes, it was pump gas 91
Old 01-17-2021, 01:33 PM   #25
unlimitedshrimps
Member#: 472984
What a gorgeous build... haven't seen that front bumper. Is it custom? Over the shelf?
Incredible work
unlimitedshrimps is offline   Reply With Quote
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
Powered by Searchlight © 2022 Axivo Inc.
