#1 |
Member#: 104832
Vehicle:05 STi CGM |
![]() I'm putting a JDM V7 2002 STi engine in a Factory Five 818R kit car. The engine is cable throttle, AVCS, no TGV factory intake.
I pruned what was probably a 2002 WRX chassis harness to fit the 818. The JDM engine came with engine harness only and a B1 code ECU from a 2005 immobilized STi. (I figured this out when it wouldn't start thanks to iWire!) I bought a JDM V7 ECU on ebay, code V8. I have had to re-pin the WRX ecu connectors for the main relay, fuel control, and intake air temp sensor, and add pins and wires for the AVCS rear cam sensors and solenoids. I have printed out several wiring diagrams. The JDM harness closely matches one for a 2005 STi, and doesn't match the others. I can read OBD codes but not monitor functions. I have one O2 sensor code P0037, probably because I don't have a rear O2 sensor. It starts right up on all cylinders and has a low surging idle, barely running. It will not rev but dies with throttle. I have hundreds of hours into just the wiring. I tried to connect a Tactrix cable but my computer isn't doing it. I have had great success on other projects with Megasquirt. I'm wondering if I should go that way or keep trying with the Subaru ECU. I may have missed an important ECU pin. The ebay ECU may be bad or tuned for a different car. I checked for vacuum leaks. Fuel pressure is good. All cylinders fire smoothly. I'd appreciate any suggestions!
#2 |
Member#: 104832
![]() I unplugged the MAF and it runs. Now I need to figure out what that means.
#3 |
Member#: 104832
![]() Solved. I installed the MAF sensor backwards. Turned the intake pipe around and it runs like a champ!
#4 |
Member#: 530559
RMIC
Vehicle:2002 WRX Wagon WRB |
