Welcome to the North American Subaru Impreza Owners Club Thursday August 18, 2022
Old 05-04-2001, 09:54 AM   #1
Jerry C
Member#: 6182
2004 STI,TALON TSI,B
SILVER, PEWTER
Post Anyone know the weight of the stock WRX wheel.
My Sub. parts guy dosent know and is to busy to find out.
Also how critical is the offset. I have two big wheel shops telling me that +45mm is NOT a problem for the WRX. This is on a 16x7" or a 17x7",(American Racing Alloy," Painted Carrera #49") Outer is painted in a gunmetal gray with polished alloy center, would look good on a silver car with gray accents. The wheel weighs 19lbs.
Bearing load probs??
Thanks for all the comments on my last post!!
Jerry C
Jerry C is offline   Reply With Quote
Old 05-04-2001, 10:13 AM   #2
gtguy
Member#: 2184
2005 Legacy GT wagon
Platinum Silver Metallic
Post
The stock WRX wheel is something around 15.5-16 lbs, and offset does indeed matter. Our Scoobies have big offset +55, so generally anything below +48 is considered a no-no for your wheel bearings. You might have to roll the fender as well, if you plus-size.
Kevin
gtguy is offline   Reply With Quote
Old 05-04-2001, 10:17 AM   #3
deepbeep
Member#: 1392
Post
Stock RS offset for MY00 was ET53, not ET55... just about a hair's difference!
deepbeep is offline   Reply With Quote
Old 05-04-2001, 10:26 AM   #4
vividracing
Member#: 6270
Only At
www.vividracing.com
Post
Call any dealer, tire shop IE discount or tire rack and between a 42 and 53 is good, 45 recommended. As long as you have 17inch with 215 40 series tires a 42 or 45 offset will doing nothing bad for your car except make it look tight and ride better becasue of the widen fender flares and wider tire. All offset means is how far the rim is sticking out. Big offset it is pulled in closer like OEM, small offset the rim is pushed out more. Its not a big deal like people think. Call around. www.vividwireless.com
vividracing is offline   Reply With Quote
Old 05-04-2001, 11:00 AM   #5
ConeMasher
Member#: 2135
Post
vivid, running those mega low offsets means say goodbye to your wheel bearings due to increased bearing load, and enjoy your messed up steering response and way-altered-scrub radius.
On a 7" rim, unless you want to roll the dice, I'd echo the earlier advice and stick with ET48 or above.
-- ConeMasher
ConeMasher is offline   Reply With Quote
Old 05-04-2001, 11:13 AM   #6
bsquare
Member#: 1911
2000 Impreza 2.5RS
Silverthorn Metallic
Post
vivid,
You definitely have no idea what you are talking about on this. The wrong offset can change the suspension geometry (this is particularly bad in front since you steer with those wheels), and can cause the tires to come into contact with the fenders (a very common problem with the wrong offset and wider than stock tires).
Car makers don't pick offsets randomly or to prevent your car from looking "tight". They select the offset to properly integrate with the rest of the suspension and the chassis.
Ben
bsquare is offline   Reply With Quote
Old 05-04-2001, 11:13 AM   #7
bsquare
Member#: 1911
2000 Impreza 2.5RS
Post
IE has gone mad!
[This message has been edited by bsquare (edited May 04, 2001).]
What is the Weight of a STOCK - OEM 16" Wheel ??? george3 Tire & Wheel 4 01-15-2008 09:54 AM
anyone know the weight of a stock wrx 16" rim and tire combo??? jinxproof99 Tire & Wheel 5 08-16-2003 08:27 AM
What is the weight of the stock tires on the 2002 WRX? Snake Eyes Vancouver Impreza Club Forum -- VIC 8 03-11-2002 01:51 AM
What is the weight of the 2002 OBS stock wheels? driver Brakes, Steering & Suspension 0 06-15-2001 04:52 PM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
Powered by Searchlight © 2022 Axivo Inc.
