![]() Tire & Wheel Forum sponsored by The Tire Rack |
#1 |
Member#: 37524
Vehicle:2002 WRX Platinum Silver Metallic |
![]() I just had my new wheels and tired mounted and balanced yesterday. I roll on the highway this morning and at 60 mph it starts to shimmy and shake like crazy. What could be the problem?
I haven't checked tire pressures since I put them on, but what do you think the culprit is? Bad wheel balancing or uneven tire pressures or needs alignment? Im lost.
#2 |
Member#: 19019
Tri-State
Vehicle:2008 Mini Cooper S BRG |
![]() Could be any of the three. Most likly bad balancing though go right bsck to the tire garage and have them check.
What size and model tire, may help. |
#3 | |
Member#: 37524
![]() Quote:
225/45/17 sumitomo htr+ all season |
#4 |
Member#: 19019
Tri-State
![]() I'm not familar with those tires but if they were asymetrical or directional and were installed wrong this could also be the cause.
#5 |
Tire Rack Moderator
Member#: 1215
Vehicle:800 -428-8355 ext. 4362 |
![]() what wheels and are they hub-centric and not bent ????
#6 | |
Member#: 37524
![]() Quote:
wheels are brand new from subydude. im not sure if they are hub-centric or not. |
#7 | |
Tire Rack Moderator
Member#: 1215
![]() Quote:
you can also use this link to our vibrastion diagnosis flow chart |
#8 |
Member#: 37524
![]() would lug nuts not fitting cause this issue?
#9 |
Member#: 37524
![]() Luke,
would this tech service bulletin have anything to do with the balancing of the tires? http://www.sumitomotire.com/technicalBulletin.pdf |
#10 | |
Member#: 19019
Tri-State
![]() Quote:
#11 | |
Tire Rack Moderator
Member#: 1215
![]() Quote:
does bad wear pattern in tire = steering wheel shake? | jsin93816 | Brakes, Steering & Suspension | 2 | 02-28-2010 07:13 PM |
New Tires=Steering wheel shaking < 62 MPH??? | Rally Punx | Texas Impreza Club Forum -- TXIC | 19 | 06-05-2007 10:52 AM |
Steering Wheel Shaking at 70-75mph | Rozos | Brakes, Steering & Suspension | 6 | 10-09-2001 03:09 PM |
Got rims now steering wheel shakes | WRXThis | Brakes, Steering & Suspension | 11 | 05-21-2001 06:22 AM |
('93-'01) steering wheel shaking | Ragstylz | Impreza Forum | 13 | 05-16-2001 12:30 AM |
