Welcome to the North American Subaru Impreza Owners Club Sunday August 7, 2022
Old 09-21-2003, 03:59 PM   #1
4 banger
Member#: 37651
Default what is the max boost the sti can hold
just got my blitz boost controller and I wanted to know what is the max boost the stock turbo can hold with no problem.
4 banger is offline   Reply With Quote
Old 09-21-2003, 04:42 PM   #2
GLwagon
Member#: 16696
2002 WRX Sedan Stg2
2013 OBW roll'n at 30+mpg
Hmmmmm... new 2.5l in untested new form...
two words.
GLwagon is offline   Reply With Quote
Old 09-21-2003, 05:02 PM   #3
SubEd
Member#: 717
two words.
I was thinking "Ka" and "Boom".
SubEd is offline   Reply With Quote
Old 09-22-2003, 08:54 AM   #4
SlvrRS
Member#: 39462
04 STi
Type R Spec Broken Wallet
Try 25 psi.........
You should be fine.
Ka BOOM!!!!!!
SlvrRS is offline   Reply With Quote
Old 09-22-2003, 02:02 PM   #5
VVVV
Member#: 37205
2004 STI
Actually, it sounds like the stock turbo has trouble holding stock boost, so turning it up with a MBC probably won't get much anyway.
VVVV is offline   Reply With Quote
Old 09-22-2003, 04:14 PM   #6
rlavalle
Member#: 18384
2004 STi: 580 AWHP
Java Black Pearl
I set mine to 16psi and it creeps to 18psi+ on long straights at the track.
It settles back down to 15psi or so as revs increase towards redline.
I should do some DeltaDash logging.
Russ
rlavalle is offline   Reply With Quote
Old 09-22-2003, 06:01 PM   #7
renichms
Member#: 38550
2004 Impreza WRX STi
WR Blue
I read somewhere that the stock turbo is about maxed out, though the rest of the engine will hold. To be honest, with how fast it spools, I wouldn't be surprised that it can only push a little bit more.
RN
renichms is offline   Reply With Quote
Old 09-22-2003, 11:44 PM   #8
tolnep
Member#: 18602
2005 Moller Skycar
glow in dark purple
two words.
Those critters are delicous and one makes a meal. Deep-fried, boiled or baked.... tastee..
STI can hold 100psi for bout .1 second. More if less pressure, less if more pressure.....
tolnep is offline   Reply With Quote
What is the max Hp the stock WRX internals have been known to hold? Homemade WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 76 10-30-2019 02:47 PM
What is the max boost for the VF48? Tuned200 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 14 02-17-2009 04:59 PM
what is the max boost on a vf39? Arts Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 16 04-03-2007 05:18 AM
what is the max boost for the sti 4 banger Tri-State Area Forum 1 09-23-2003 07:24 PM
What is the MAX boost for a VF30 fatray Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 07-16-2003 02:21 PM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
Powered by Searchlight © 2022 Axivo Inc.
