Welcome to the North American Subaru Impreza Owners Club Saturday July 4, 2020
Old 05-21-2020, 12:19 PM   #1
grdprx
Member#: 514954
1999 Impreza OBS
Green
Default EJ22 MAP engine into MAF Impreza
I have a 1999 Impreza OBS, engine has a rod knock. I got a replacement EJ22 phase 2 engine that upon closer inspection is MAP based, my car is a MAF setup. Can I swap the intake manifolds to rectify this? Are there any sensors on the block related to MAP/MAF?
grdprx is offline   Reply With Quote
Old 05-21-2020, 01:01 PM   #2
Muffin15
Member#: 326958
2006 Impreza WRX
San Remo Red
Yes, you will want to retain the sensor setup that is original to your ECU and swapping the intake should be just fine. I have heard of some needing to have the cam or crank pulley's swapped over so the ECU gets the correct signal but am not sure what motors require that
Muffin15 is offline   Reply With Quote
Old 05-21-2020, 03:33 PM   #3
grdprx
Member#: 514954
1999 Impreza OBS
Green
Sweet, thank you for the reply!
Old 05-22-2020, 11:38 PM   #4
Leonardo
Cowabunga!
Super Moderator
Member#: 185
1999 Impreza wagon
Dark Gray Metalic
Ok, I have done this swap on my OBS.
Use the long block. Bring over your Cam and crank timing belt gears and swap over your whole intake, sensors and all.
I got the point I can swap these out in less than a day.
EDIT: my 1999 OBS is MAP (EJ222) Is yours an EJ223? It's all the same as I wrote above but just wondering the difference.
Leonardo is offline   Reply With Quote
Old 05-24-2020, 10:41 PM   #5
grdprx
Member#: 514954
1999 Impreza OBS
Green
Thank you! I wouldnít have thought to have changed out the timing cams from old EJ22 to the new EJ22. Yes, mine is engine code EJ223
Old 05-27-2020, 08:09 PM   #6
Leonardo
Cowabunga!
Super Moderator
Member#: 185
1999 Impreza wagon
Dark Gray Metalic
You are welcome!
Change cam timing gear and should be fine. Let me know when you get it running.
