Welcome to the North American Subaru Impreza Owners Club Sunday July 5, 2020
Old 07-22-2001, 04:13 PM   #1
IMPREZAmike
Member#: 169
98 black OBS
move bi*ch get out da way
Default s-afc 'blue wire mod' on 98 OBS...i think i messed up...help!
OK, so i have searched low and high for any info on the 'blue wire mod' so i can get a crude O2 reading from my s-afc to help with tuning my 98 OBS. I tapped the blue wire from the s-afc into wire #23 on the ECU, hoping to get the O2 reading. Everything on the s-afc is working, but im not sure which setting checks this reading and what an acceptable reading should be (i think i heard from .85 to 1.0 is good?) Please send me in the right direction so i can get this thing up and running 100%! thanks!
IMPREZAmike is offline   Reply With Quote
Old 07-22-2001, 07:16 PM   #2
wac
Member#: 689
2005 Outback 2.5 XT
Champagne Gold Opal
You have to go to the etc. screen, then the Sensor chk screen. It will be the In-2 reading.
As for what voltage you should expect, most people are still in the dark about this, as it seems no one has found the detailed datasheet for the stock O2 sensors that relate AFR to output voltage.
I only use this reading as a sanity check to make sure that it's at least 7.0V in open-loop mode, and use an EGT to tune for safe temps. Since stoichiometric AFR's result in high EGT's that may harm the engine under heavy loads, you want to tune so that your EGT's are as close to 1400-1450F as possible, while still staying on the rich side of AFR.
Some people tune only by AFR, while others tune only by EGT. To be absolutely sure you're on the safe track, you should use both.
Good luck,
-WaC
Wayne
wac is offline   Reply With Quote
Old 07-23-2001, 11:53 AM   #3
IMPREZAmike
Member#: 169
98 black OBS
ok..the In-2 valus flucuates from between .1 to .8 at very lite throttle, and a constant .86/.87 at moderate to full throttle. does theis sound right? where do i go from here without buting another gague right now? thanks!
Old 07-23-2001, 05:13 PM   #4
Dirty Underwear Gang
Guest
Member#:
Post Voltages
I've helped tune a turbocharged honda using a PMS (Programmable Management System). It plugs in between the stock ecu and the harness and is programmed via a handheld controller. It uses all the factory sensors. Anyway. Those O2 voltage #'s are identical to the O2 voltage #'s displayed by the PMS. The car was tuned so that the O2 voltage stayed between .86 and .89 at wot/full boost. That winds up to be about 13.5~12.8 AFR if memory serves. Just thought ya might like to know.
I think I messed up bad Mecanic07 Transmission (AT/MT) & Driveline 2 03-26-2007 06:32 PM
I think I messed up bad Mecanic07 Brakes, Steering & Suspension 4 03-26-2007 01:25 AM
Ok I think I messed up somewhere Rockgod Legacy Forum 24 01-30-2007 11:50 PM
i think i messed up w/ this girl RR Off-Topic 74 05-03-2005 06:10 PM
I think something's messed up now! Black-X Electrical & Lighting 2 02-01-2003 10:01 PM
