Welcome to the North American Subaru Impreza Owners Club Saturday July 11, 2020
Old 03-29-2006, 03:49 PM   #1
TheMainFrame
Member#: 104251
2002 Impreza WRX
Pearl Silver Metallic
Default Clicking Noise While Turning
Hello,
I seem to have a clicking noise when I make Right turns with throttle. It seems to only click when im taking a preety decent right hand turn and I give it gas in the corner.I can kinda feel it threw the gas pedel, Any ideas on what this may be?
I origanaly thought "CV joint" cause I had to replace one of those on my last car and it cliked when I turned. However, I remeber it clicking even when i turned without using the throttle.
On a side note what are some highly recommended Suspension upgrades for a 2002 WRX sedan? Am I far off for thinging...
Not including wheels
First .. F+R sway bars w/ endlinks
Second... Brake upgrades
Thirds.. some kind of coilover or somthing
Natrually you can tell I havent really started my Suspension research but thats really not the purpose of this thread
TheMainFrame is offline   Reply With Quote
Old 03-29-2006, 08:02 PM   #2
TheMainFrame
Member#: 104251
2002 Impreza WRX
Bump, even tho im preety sure its the CV joint
Old 04-28-2006, 07:27 PM   #3
TheMainFrame
Member#: 104251
2002 Impreza WRX
Well i took it to the shop and the mecahnic told me that the boot was not torn and its holding grease perfectly fine so they did not replace the Axel.
Is it possible the joint could be damaged without a torn boot?
What clicking noise could i be hearing on a hard right turn that sounds almost identicle to a cv joint?
Old 04-28-2006, 07:32 PM   #4
supermarkus
Member#: 6971
2008 WRX STi
SSM
I once had a loose brake line clicking against my strut during tight turns. I mistook it as a CV problem but when I secured the line, the clicking went away. Also, if your endlink is loose it can cause a clicking noise.
supermarkus is offline   Reply With Quote
Old 04-28-2006, 07:54 PM   #5
wrxzboost
Member#: 86322
when i installed my coilovers i didn't secure my brake lines too good and it was more of a "slapping" noise then anything. I just had my cv boots replaced last week, but they didn't make noise. The only way it could be your cv joint is if there is grease around the inside of your wheel or around the boots because it got torn, but if they are not torn, then its not your cv joints. Take your wheel off and look around and "feel" for grease and such. There have been a lot of people who go years without replacing them without damaging bearings, i guess it all depends.
wrxzboost is offline   Reply With Quote
Loud clicking/clunking noise while turning.. Any ideas? k2snow Legacy Forum 26 04-23-2020 06:49 PM
Tech assistance needed.. Legacy clicking/clunk noise while turning.. ?? k2snow North West Impreza Club Forum -- NWIC 4 01-05-2010 02:30 AM
clicking noise while driving need feedback! scoobyshahin Transmission (AT/MT) & Driveline 0 03-29-2009 05:44 PM
Clicking noise while doing sharp turns Gmd Brakes, Steering & Suspension 6 08-11-2007 09:51 AM
Medium braking, intermittent clicking (NOT while turning!) petregeus Brakes, Steering & Suspension 2 07-24-2004 05:40 PM
