Welcome to the North American Subaru Impreza Owners Club Tuesday September 22, 2020
Old 05-02-2019, 06:09 PM   #1926
Ednanog631
Member#: 483857
2018 Subaru STI
this is gold!
Ednanog631 is offline   Reply With Quote
Old 05-10-2019, 03:13 AM   #1927
J_ODIE
Member#: 484302
Interesting. Can anybody confirm the size on the front swaybar? Most references state 24mm but I have seen mention of 23. Also, maybe totally unrelated bit the oem front D bushings for the swaybar have a 23 on them. I would have measured but do not have a micrometer.
Edit: I just ordered one from Amazon. I'll measure and post back when I get it.
J_ODIE is offline   Reply With Quote
Old 05-12-2019, 08:46 PM   #1928
J_ODIE
Member#: 484302
Confirmed.Just measured a 2017 WRX Base with 17 inch wheels. 23.9mm.
Old 07-07-2019, 09:03 PM   #1929
likesTurtles23
Member#: 503929
Can someone tell me if the AccessPort logs Enhanced OBDII PIDs or is it just the generic PIDs that all vehicles use? And if they don't can someone recommend a device that does? Thanks.
likesTurtles23 is offline   Reply With Quote
Old 10-19-2019, 07:43 PM   #1930
Wraith
Member#: 30364
2005 Devilish STI
Angelic white
So on my 2005 STI there is a headlight leveler adjustment where I can control how high or low it goes. My buddy just bought a 2020 STI, is this still controllable? He doesn't have that rolling switch next to the gauge light dimmer.
Wraith is offline   Reply With Quote
Old 10-19-2019, 08:46 PM   #1931
Scorpius
Member#: 370806
2019 WRX/STI DGM
2016 WRX/STI ISM
There's an automatic headlight leveler.
Scorpius is offline   Reply With Quote
Old 10-20-2019, 12:21 AM   #1932
SpeedHoles
Member#: 339900
It's connected to the rear left lower control arm.
SpeedHoles is offline   Reply With Quote
Old 10-20-2019, 01:27 AM   #1933
my name is joe
Member#: 171412
It does not, high end readers will show you on some vehicles. I used a mactools/snapon and Marco readers on a bunch of cars. Subaru doesn't charge/make vehicles expensive enough to canbus and go that much into detail(yet). You'll get a generic code and go from there. For the most part it's going to be the usual suspects of whatever is going on.
my name is joe is offline   Reply With Quote
Old 10-20-2019, 01:29 AM   #1934
my name is joe
Member#: 171412
You could use an open ended wrench.
Old 03-06-2020, 05:56 AM   #1935
chive89
Member#: 508132
Good day, is there a repair/service kit for the Garrett MGT2259s turbo?
If yes, where can I get one?
chive89 is offline   Reply With Quote
Old 03-07-2020, 10:41 AM   #1936
ohxcsmith
Member#: 512344
Good stuff, thanks OP.
ohxcsmith is offline   Reply With Quote
Old 03-19-2020, 09:32 PM   #1937
speedracer48
Member#: 512738
2015 WRX
This is the first time I have used this forum. I have a 2015 Wrx with a K&N typhoon air intake and Nameless muffler deletes. The car came with an SPT/Sti exhaust. I am looking to tune the car to Stage 2 from COBB. Would I need a J-pipe or would the car be fine without the J-pipe?
speedracer48 is offline   Reply With Quote
Old 03-20-2020, 03:44 AM   #1938
wuuusaa
Member#: 92894
2015 Wrx
I answered your question in the exhaust thread.
wuuusaa is offline   Reply With Quote
Old 03-29-2020, 09:27 PM   #1939
Rydog 24
Member#: 512995
Good information. Thank you!
Rydog 24 is offline   Reply With Quote
Old 04-18-2020, 04:51 PM   #1940
MasterOSkillio
Member#: 274368
I am crossposting this here, because I have a post in the Brakes, Steering & Suspension section and it's been open a couple of days with at this point 115 views and no replies, since this is a 2015 wrx post I am hoping someone might know this, and it isn't against the rules.
I noticed the 5x114.3 bolt pattern on the 2015 wrx (non STI) stock, and I was looking to find out the following:
I have a 2014 wrx wagon and I was looking at the better wheel options for the 5x114.3 bolt pattern as well as having a lot of better brake upgrade options. To this end I had done some searching and googled around I found the following:
1. Rear STI bearings with the 5x114.3 pattern will press into the rear of my 2014 wrx. Simple, reasonably cheap, OEM, and easy.
2. The front is more complex, where either I use an STI knuckle and change to STi front suspension dampers and springs, and STi axles. A lot more work in there and expensive.
OR
pretty expensive LIC knuckle, if I can get someone to go in with me on a buy, because from I understand you have to get a minimum of 4.
What I have been looking for and not seen/found is any discussion on the 2015 wrx front knuckle and swapping that to a 2008-2014 wrx. The 2015 has the 5x114.3 bolt pattern already on it, from what I can tell it's different then the STI knuckle, they're not the same. From the pictures I have looked at of parts it looks like the 2014 and 2015 are similar and look like they would line up where they attach to the car, but I have not seen the parts up close has anyone tried to put that 2015 knuckle on a 2014? Are reasons not to?
It seems like if this was a fit it would open up a pretty cheap way to get 5x114.3 wheel options and easy STI brake options on a low budget.
MasterOSkillio is offline   Reply With Quote
Old 04-18-2020, 08:20 PM   #1941
NewboftheSube
Member#: 492609
2019 WRX
Gray
Very helpful thread! Thank you
NewboftheSube is offline   Reply With Quote
Old 07-01-2020, 09:44 AM   #1942
CV888
Member#: 469394
2015 Subaru WRX STI
CWP
have been inactive for a long time but still want to thank OP for compiling this thread. awesome, cheers!
CV888 is offline   Reply With Quote
