Welcome to the North American Subaru Impreza Owners Club Tuesday September 22, 2020
Old 09-09-2019, 12:29 AM   #1
Poden
Member#: 487220
2002 Wrx with a 207
Default Ej 207 Swap Is tuned wonít rev past 6500 rpm please HELP!
So I recently finished an ej 207 out of an old bugeye into a new one, I transferred everything from ecu to intercooler for the tune the car had. The car runs and drives great but when I go WOT it will only rev to 6500 and backfire with a cloud of black smoke, this leads me to believe that Iím running rich. While I had the engine out I rebuilt the turbo, could this be the reason why Iím backfiring at 6500? Do I need to look into getting a new tune, I already tested coils and plugs and theyíre fine. I changed the Idle control valve as well because it went bad. My build is a v7 207 with ID 1000ís, Perrin front mount, generic tdo5 turbo, spark plugs one step colder, tgv deletes, Walbro 255, Megan downpipe and straighpipe exhaust, I had the engine tuned last August at awd tuning.
Poden is offline   Reply With Quote
Old 09-09-2019, 12:48 AM   #2
subaru_gc8
Member#: 29292
2004 WRX wagon
talk to the one that tuned it.. why the step colder plugs and the big injectors? it would be helpful if you did a wot pull log so we can see whats going on, but Im going to take a big guess that its your o2 sensor or the maf
Old 09-09-2019, 12:58 AM   #3
Poden
Member#: 487220
2002 Wrx with a 207
My tuner recommended going one step colder and the engine came with the bigger injectors when I originally bought it, and what program can I use to get a pull log ?
Old 09-09-2019, 01:07 AM   #4
subaru_gc8
Member#: 29292
2004 WRX wagon
romraider will do it but you need a tactrix cable. did it ever run correctly?
Old 09-09-2019, 08:49 AM   #5
Fozymandias
Member#: 504375
Is your speedo working correctly?
Fozymandias is offline   Reply With Quote
Old 09-10-2019, 03:10 AM   #6
D-Rodman
Member#: 110078
05 Saabaru JDM STi
Black Ver 7 VF48 6sp RA
Are there any parts that are different from the way the donor was setup ? Exhaust, intake, etc ?
D-Rodman is offline   Reply With Quote
Old 09-10-2019, 10:05 AM   #7
86Dreams
Member#: 385256
V7 S204
'19 Giulia Q4
did you check fuel pressure?
86Dreams is offline   Reply With Quote
