Welcome to the North American Subaru Impreza Owners Club Tuesday September 22, 2020
Old 12-28-2018, 05:57 AM   #101
bue car
Member#: 176134
1995 Coupe, Sedan &
Wagon!
You can also set the readiness monitors to always good.
bue car is offline   Reply With Quote
Old 12-28-2018, 02:26 PM   #102
Shik
Member#: 132
2006 GT , '05 WRX
'15 WRX 6spd CWP, '02 WRX
Originally Posted by STEVEMS3 View Post
had a quick question im in the process of replacing my fuel tank and subframe ect..
Fun job! I just did that on my son's '02 Impreza this past weekend. I planned on deleting the evap/canister but by the time I was done, i just wanted to get the car out of the garage so I put everything back to normal for now. All of the hoses basically end up right where they need to be so no worries on putting things back to stock. I'll delete the stuff when I get some free time.
Good luck!
Shik is online now   Reply With Quote
Old 01-02-2019, 04:09 PM   #103
FuelCutOff
Member#: 40499
2004 FXT
Default Need clarification please
Need some help if anyone can spare the time to reply.
I have an 04 forester xt. I've gutted everything as in this DIY, but what I see in front me me is slightly different as far as I can tell. I need help with B in the image.
From the image:
A = leave open per DIY since it goes to fuel filter overflow
B = ??? -> can't tell what this is for or where it leads; can I leave this open?
C = add filter per DIY since it's for gas tank breather
D = cut down and leave open since it goes under the hood
E = T-fitting attached to C which I'll remove when putting filter on
FuelCutOff is offline   Reply With Quote
Old 01-09-2019, 12:37 PM   #104
Stiguy04
Member#: 54400
2004 STi
Originally Posted by Bo Bandy View Post
For anyone wishing to do this in the future, if you are not able to disable to codes right away and don't want any check engine lights...
In the engine bay keep the evap solenoid connected to the electrical harness but no hoses connected to it. For the rear charcoal cannister etc. Keep the electrical harnesses plugged in and connect the hoses to each other but not hardwired to the car so the evap system isn't actually operating but the car thinks it's still there.
If anyone needs pics I can go take some cause I'm not that great at explaining things...
Does anybody have any clarity on this method? Specifically the last part about connecting the hoses to each other but not hardwired to the car. I couldn't fill my tank without it clicking off every couple of seconds unless I let the fuel trickle in. Takes like 10+ min to fill up. I ended up removing the fuel vent hose from charcoal canister to get by, but still getting a CEL P1443. The canister looks good, nothing loose or any debris coming out. I can blow thru the valve so I know air can pass through. I left everything up front on the manifold connected. Maybe the purge valve is bad and it doesn't matter what I do it'll still throw the code...
Stiguy04 is offline   Reply With Quote
Old 05-30-2019, 07:56 PM   #105
zcivic
Member#: 199691
04 Forester XT
I really wish I took a picture of how I routed mine. I had to replace my fuel tank and filler neck while I was at it I decided to remove the EVAP stuff. I didn't leave any lines open but I can't get the car to take gas. Does anyone have a suggestion on what maybe my issue. I have tried disconnecting the valve on the back of the filler neck. I left one line totally off and it still wont take gas and it seems like it should still venting the tank.
Thanks,
Randy
zcivic is offline   Reply With Quote
Old 06-02-2019, 06:54 PM   #106
bue car
Member#: 176134
1995 Coupe, Sedan &
Wagon!
It needs to vent and you capped it all off. So it's not filling. This is why there is a complaint of fuel smell in the garage, spilling when fuel up too much, etc after the removal. She need s to breath / displace the air with fuel while filling. No where for the air to go except back up the neck causing the pump to shut off with the pressure.
Old 06-09-2019, 01:42 PM   #107
AnthonyF24
Member#: 482700
2013 STi Hatch
Has anyone done this to an 08+? I have a 13 and started to look for a spot to mount my tank and came across all this in the in the back, mines a hatchback.
AnthonyF24 is offline   Reply With Quote
Old 06-10-2019, 06:58 AM   #108
zcivic
Member#: 199691
04 Forester XT
Is that not a vent where you place the 3/4 filter? well mine was a 3/4. Comes off the white plastic one in the middle.
Old 07-26-2019, 06:15 PM   #109
zcivic
Member#: 199691
04 Forester XT
Default How To: Evap + Charcoal Canister removal
I hate to bring this back up, just tired of spending 20 minutes for a partial fill up. Is this vent the one that's suppose to displace air/vapor and allow my tank to fill up.
Old 07-30-2019, 02:47 AM   #110
bue car
Member#: 176134
1995 Coupe, Sedan &
Wagon!
I believe so...
Still have not run my own set up haha
sad
Old 08-10-2019, 10:09 AM   #111
Luxkeiwoker
Member#: 469111
2006 Impreza WRX STI
Guys I need some advice here. I'm having my 2006 Hawkeye STI on the hoist in this very moment, trying to remove the EVAP canister, since it was throwing codes and pissing fuel. I tried to follow the guide in the first post, but the piping at the canister looks somewhat different
What shall I do with the hardline (marked in red)? It's ending up in the framerail and probably routing somewhere either to the filler neck or the tank.
Any ideas?
(Btw codes will be disables with a tactrix)
Luxkeiwoker is offline   Reply With Quote
Old 08-10-2019, 06:43 PM   #112
bue car
Member#: 176134
1995 Coupe, Sedan &
Wagon!
It's the vent. It literally goes up about 25mm and that's it. It's an open pipe into the frame rail.
Old 08-11-2019, 01:30 PM   #113
Luxkeiwoker
Member#: 469111
Thanks, after some tinkering I got the whole assembly out and you're right - it is just a plastic coupler going into the framerail which can be simply pulled out.
Old 08-11-2019, 02:23 PM   #114
bue car
Member#: 176134
1995 Coupe, Sedan &
Wagon!
Glad you got it!
Old 08-16-2019, 09:00 AM   #115
Luxkeiwoker
Member#: 469111
Guys I need some advice on the CELs to be disabled. I've disabled so far
  • (P0442) EVAP LEAK DETECTED (SMALL)
  • (P0447) EVAP VENT CONTROL CIRCUIT OPEN
  • (P0448) EVAP VENT CONTROL CIRCUIT SHORTED
  • (P0451) EVAP PRESSURE SENSOR RANGE/PERF
  • (P0452) EVAP PRESSURE SENSOR LOW INPUT
  • (P0453) EVAP PRESSURE SENSOR HIGH INPUT
  • (P0456) EVAP LEAK DETECTED (VERY SMALL)
  • (P0457) EVAP LEAK DETECTED (FUEL CAP)
  • (P0458) EVAP PURGE VALVE CIRCUIT LOW
  • (P0459) EVAP PURGE VALVE CIRCUIT HIGH
  • (P1400) FUEL TANK PRESSURE SOL. LOW
  • (P1420) FUEL TANK PRESSURE SOL. HIGH INPUT
For some reason, P1400 keeps coming back, everytime I start the car.
How is that even possible, after disabling the code?!
The only thing I left enabled is
(P1443) VENT CONTROL SOLENOID FUNCTION PROBLEM
Old 09-11-2019, 11:00 PM   #116
2subies4me
Member#: 506274
I've read through this thread and watched this video:
I have a 2005 Impreza (not wrx!) with the H4SO engine. It has a small evap leak code. I'm thinking of just capping the system off but I don't have this Cobb thing/software, or know how to 'tune' the ECM to remove codes. I have a regular ODB code reader and resetter.
It's not the gas cap. I checked that and reset the code twice and it comes back after ~50 miles of driving. I can't pass inspection (no emissions, but they do require the CEL light to be off and the sensors to be Ready).
Since I can't mask the code off, I need to fool the computer into thinking the solenoids are still there. I've seen a few references to sticking a 50 ohm resistor in the connector to emulate the solenoid. Does anyone have more specific directions (which connectors, where are they located)?
If I do just that and leave the EVAP cannister and lines in place, will the code likely go away?
2subies4me is offline   Reply With Quote
Old 09-24-2019, 01:33 AM   #117
DatBigDude
Member#: 390974
Does anyone happen to have the images for this write up saved anywhere by any chance? Tinypic is no longer active so they will need to be hosted on another server. Any help is appreciated.
DatBigDude is offline   Reply With Quote
Old 09-24-2019, 04:35 PM   #118
subaru_gc8
Member#: 29292
2004 WRX wagon
never mind
subaru_gc8 is online now   Reply With Quote
Old 09-28-2019, 10:58 PM   #119
kmook
Member#: 146168
2017 Impreza
Wink
Ha I came to look up some audio stuff for my '17 impreza, and low and behold this thread is still active
I looked through my stuff and I still have all the original pics. So I uploaded them somewhere new and relinked them for anyone that wants them.
kmook is offline   Reply With Quote
Old 09-29-2019, 12:08 AM   #120
bue car
Member#: 176134
1995 Coupe, Sedan &
Wagon!
What a stud lol
Old 03-22-2020, 07:34 PM   #121
WontonNoodle
Member#: 478520
2005 WRX
Platinum silver metallic
I just removed every thing in the engine bay, all hoses and solenoid. can I leave all the stuff in the rear? And get the codes deleted by a tuner or will my car not fill up properly if I donít delete the evap canister and hoses on the rear.?
WontonNoodle is offline   Reply With Quote
Old 03-22-2020, 08:13 PM   #122
subaru_gc8
Member#: 29292
2004 WRX wagon
should be fine, but you might have probelms filling up as if you fill up too much it might come out of the cansiter
Old 04-05-2020, 11:30 PM   #123
FrogRacing
Member#: 346697
Made a video of the process, hopefully showing what people are usually confused about in the engine bay with the lines running under the intake manifold. The original post was super useful to get this done:
FrogRacing is offline   Reply With Quote
Old 04-06-2020, 12:40 AM   #124
bue car
Member#: 176134
1995 Coupe, Sedan &
Wagon!
Very nice!
Rally too! bonus points
Old 04-29-2020, 08:56 PM   #125
ScoobyJD
Member#: 185910
2007 FSXT
I still don't understand why we can't just block off the breather line. Old gas tanks never had this breather line.
ScoobyJD is offline   Reply With Quote
