Welcome to the North American Subaru Impreza Owners Club Tuesday September 22, 2020
Old 12-05-2014, 12:17 AM   #51
Torafugu
Member#: 407629
Very useful method.
Post 2
Torafugu is offline   Reply With Quote
Old 02-06-2015, 02:37 AM   #52
tuka16
Member#: 412807
Awesome
tuka16 is offline   Reply With Quote
Old 04-10-2015, 12:23 PM   #53
honda610
Member#: 418304
Great video and really helpful!
honda610 is offline   Reply With Quote
Old 04-24-2015, 07:55 PM   #54
sharpy0125
Member#: 419569
this helped alot!
sharpy0125 is offline   Reply With Quote
Old 07-12-2015, 07:43 PM   #55
setchie
Member#: 368264
sweet, great idea!
setchie is offline   Reply With Quote
Old 08-06-2015, 10:58 PM   #56
Awd_addict
Member#: 383303
2014 Wrx 5dr
Just did this. Finding a large nut for the Allen head to rest in the threaded area worked well. Plus the heat from welding helped free it up I'm sure.
Awd_addict is offline   Reply With Quote
Old 08-26-2015, 10:43 PM   #57
Subaru2950
Member#: 428857
1991 Legacy ss
I air hammer my all need was a new bold.
Subaru2950 is offline   Reply With Quote
Old 09-22-2015, 09:36 PM   #58
Bpat1218
Member#: 354430
Black 4EAT Wagon
I always have a buddy help and, before I strip it out, use an impact and allen socket and have a large pipe wrench on the base of the socket to apply constant pressure. Then the impact wrench can easily hammer it off. This is pretty cool if you strip it out though
Bpat1218 is offline   Reply With Quote
Old 11-01-2015, 08:09 PM   #59
yungwang
Member#: 423333
bump.
yungwang is offline   Reply With Quote
Old 11-01-2015, 08:43 PM   #60
Njoe
Member#: 430939
wow the amount of stress i didn't have to go through, work smarter not harder..
Njoe is offline   Reply With Quote
Old 02-06-2016, 04:20 AM   #61
Imad_h
Member#: 439445
2004 Subaru Wrx
Default Done
I did it too..
thank you
Imad_h is offline   Reply With Quote
Old 02-06-2016, 04:21 AM   #62
Imad_h
Member#: 439445
2004 Subaru Wrx
Default !!
It works
Old 02-06-2016, 04:22 AM   #63
Imad_h
Member#: 439445
2004 Subaru Wrx
Amazing club !!
Old 02-21-2016, 09:10 PM   #64
Gary Butler
Member#: 440964
1996 JDM WRX
Thanks!
Gary Butler is offline   Reply With Quote
Old 02-24-2016, 09:48 PM   #65
Dave_wrx
Member#: 441222
Originally Posted by outfrontmotorsports View Post
***********We have seen a lot of posts regarding the removal of stuck cam bolts and methods of how to hold the cam gear in the futile attemps to remove these bolts with success. We have heard of horror stories of drilling, special bits and long times to do it, we have personally seen the results of dealerships using cut-off wheels/air chisels and the damage left behind on the gears that the dealer reinstalls.
the video was not edited, the motor we have is a ej205, three of the four cam bolts came loose with an impact gun, the forth one did not. this method for us is so fast that it's not worth the time to clamp the timing belt together, nor to use the cam tool. On really tight ones with the tool, we have chipped the gears. we have also seen broken head castings due to using a wedge/prybar on the cam lobes.
Often the cam bolt get really tight due to heat cycles, with the welding we do, the rapid heat applied to a stripped bolt makes them come off like butter, not damaging the cam gear at all. If you are local to us, we would perform this operation for $20 per bolt
<iframe width="425" height="349" src="http://www.youtube.com/embed/WjZ0XtLYtzc" frameborder="0" allowfullscreen></iframe>
http://youtu.be/WjZ0XtLYtzc
Thanks man that really helped me out!!!
Dave_wrx is offline   Reply With Quote
Old 03-03-2016, 12:17 PM   #66
Punapple
Member#: 421229
Great post. This happens much too often.
Punapple is offline   Reply With Quote
Old 04-17-2016, 08:47 PM   #67
SuBiE_LoVeR2209
Member#: 444978
I actually stripped out a cam bolt a whole back. That sucked lol this is definitely gonna help me in the future.
SuBiE_LoVeR2209 is offline   Reply With Quote
Old 08-16-2016, 10:16 AM   #68
1MOFOSTI
Member#: 375748
04 STi
Anyone ever tried using the Dewalt 20v MAX High Impact Wrench?
https://www.youtube.com/watch?v=bmFiFgAtUpM
1MOFOSTI is offline   Reply With Quote
Old 08-16-2016, 10:25 AM   #69
huezo_e
Member#: 408009
With 700 ft-lbs of max torque on and 1200 ft-lbs of max breakaway torque, so far I have not seen a bolt this thing can't crack.
Very impressed I need to get one!
huezo_e is offline   Reply With Quote
Old 11-19-2016, 05:16 PM   #70
intheNICKoftime
Member#: 458436
great advice!
intheNICKoftime is offline   Reply With Quote
Old 02-16-2017, 05:19 PM   #71
907bugeyesubie
Member#: 463105
2002 Impreza WRX
black
Thanks for the helpful vid!
907bugeyesubie is offline   Reply With Quote
Old 03-05-2017, 02:48 AM   #72
Master467
Member#: 459849
2002 Legacy GT
89N (titanium pearl)
On the one I just did, I put the 10mm allen wrench on it hit it with a hammer to seat it nice and firm, and put a cheater bar on that, turned it... The wrench turned! However, the bolt did not. Then we were left with a stripped bolt, an old rusty 11/16ths craftsman wrench I found in the back of a WRX I had recently parted out, and a welder. So being 2 idiots we naturally welded the box end of the wrench to the bolt! However, we forgot to cut the open end off before welding it, and our cheater bar would not fit around the open end. So, we busted out the good o'll sawzall of late 90's vintage and hacked the open end off of it while it was still on the motor. Holding the open end without gloves on as your buddy sawzalls through otherwise unsupported metal an inch from your hand was probably not the safest thing I've ever done, but it worked out. Open end off, cheater bar on, belt on the cam gears and wrapped around to anchor on the conveniently located coolant pipe, and it came off no problem. Lucky we had a donor motor or two to steal an extra cam bolt off of.
I actually returned that craftsman wrench to an Ace Hardware and got a new one, bolt still welded on to it and all.
Welding a bolt on to it is nice and all, but a good old cheater bar will put more torque to the affixed implement then the best air tools. And it just feels better too. I have a 3/8ths air wrench and a 1/2 air impact and only the air wrench ever really gets used. It IS fun to impact off lugnuts though.
Enough torque to round off even grade 8's! It's a cool tool but by no means will it save you in this situation.
That said, I may want one.
Master467 is offline   Reply With Quote
Old 03-08-2017, 02:16 PM   #73
Bgarf88
Member#: 464193
Default Test post
Sorry for the bother... need three replies to post a thread 😒
Bgarf88 is offline   Reply With Quote
Old 07-09-2017, 01:39 PM   #74
pillagemyvillage
Member#: 468715
Legit reply trying to post on forum
pillagemyvillage is offline   Reply With Quote
Old 03-02-2018, 11:14 PM   #75
Olliett2
Member#: 482828
This'll be helpful considering I'll probably have to rebuild my engine..
Olliett2 is offline   Reply With Quote
Stripped cam gear bolts scoobywagon06 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 26 03-23-2018 06:17 PM
How do you fix a stripped seat bolt? Jncominco2 Rocky Mountains Impreza Club Forum -- RMIC 11 02-19-2009 08:32 PM
stripped cam sprocket bolt limestoner Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 06-02-2006 08:55 AM
Stripped banjo bolt hole in brake caliper? Fix it!!! thrdeye Brakes, Steering & Suspension 0 10-14-2005 03:10 PM
Anyone ever have a Intake Cam bolt snap off while driving???? fastlane Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 05-16-2005 05:18 PM
