Welcome to the North American Subaru Impreza Owners Club Tuesday September 22, 2020
Old 04-27-2015, 10:57 PM   #26
musicmankeb
Member#: 411003
Originally Posted by rjp4419 View Post
Some of the EVAP codes dont show up with the accessport. Youll need and actual code scanner.
I have a cheap code scanner and clearer but that won't disable the codes it will just clear them. Can you give me a better description of what exactly you mean?
musicmankeb is offline   Reply With Quote
Old 04-28-2015, 12:18 PM   #27
rjp4419
Member#: 292796
2019 Civic Type R
You need to either have a protuner disable the codes or do it yourself.
rjp4419 is offline   Reply With Quote
Old 04-28-2015, 09:57 PM   #28
bue car
Member#: 176134
1995 Coupe, Sedan &
Wagon!
that looks to be the typical small one from the auto store, probably connected with hose connector? spectre makes them, really only one size from them.
http://www.spectreperformance.com/ca...lters-breather
bue car is offline   Reply With Quote
Old 04-30-2015, 05:19 PM   #29
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
i should probably just do this already.
Old 05-06-2015, 03:29 PM   #30
KitchenerWRX
Member#: 79934
02 WRX
MBP
Does anyone have a list of all the codes that need to be disabled? I saw it in another evap and charcoal canister delete thread but cannot find it now. I just deleted the whole lot and want to make sure all codes are disabled before I start the car for the first time.
Thanks
KitchenerWRX is offline   Reply With Quote
Old 09-17-2015, 10:38 PM   #31
SUBIEBOI91
Member#: 294433
2015 sti
white
will the monitor for the evap system go ready
can you pass inspection when removing the evap system ?
SUBIEBOI91 is offline   Reply With Quote
Old 09-17-2015, 10:39 PM   #32
cedwards92
Member#: 380787
2013 STI
I don't have inspection where I live
cedwards92 is offline   Reply With Quote
Old 12-31-2015, 11:14 AM   #33
gtasti
Member#: 152036
2004 Sti
If your car is pro tuned or not any tuner can ready everything to pass
gtasti is offline   Reply With Quote
Old 02-25-2016, 10:24 AM   #34
mefperformance
Member#: 434235
Default evap delete
I currently have a Cobb AP v3 and access tuner race. I can't get the evap monitor to show ready
mefperformance is offline   Reply With Quote
Old 02-25-2016, 10:49 AM   #35
mrsaturn7085
Member#: 375462
2006 Impreza WRX STI
WR Blue
Follow the FSM for the drive cycle. It will pass if you have disabled the proper DTC for this mod. Just passed emissions a few weeks ago by doing this.
mrsaturn7085 is offline   Reply With Quote
Old 02-25-2016, 11:36 AM   #36
mefperformance
Member#: 434235
So if the codes are disabled via access tuner the evap monitor will eventually show ready after normal driving cycles? Or do I have to follow the FMS drive cycle? Sorry im not familiar with the fms... Dumb question I know
Old 02-25-2016, 02:19 PM   #37
mrsaturn7085
Member#: 375462
WR Blue
Yes, the way the readiness monitors work is they are looking for impending codes during the drive cycle. If the DTC have been disabled entirely, they cannot show as 'impending' and the monitor will eventually show ready.
Read the FSM, follow the procedure. "Drive cycle" is a well-defined pattern of driving.
Driving 50-55 mph for 20-30 min on the freeway, followed by engine braking down an off-ramp to 10-15 mph usually does the trick for some of the lazier readiness monitors.
Old 02-25-2016, 05:55 PM   #38
mefperformance
Member#: 434235
Awesome thanks for your help. Ill revise my map tonight and disable the evap codes (i think there is 10) My plan is to temporarily disconnect the system, run the map and see what happens with the monitors just to be sure everything will work. I live in NH and wont get inspected if mess things up.
thanks again!
Old 02-26-2016, 09:51 AM   #39
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
I'm a little confused as to how A and B in the 1st photo of your engine bay could be "capped or vented, doesn't matter" if you're using one of them as a MAP source.
jblaine is offline   Reply With Quote
Old 02-26-2016, 11:34 AM   #40
mrsaturn7085
Member#: 375462
WR Blue
Because no factory setups use these as a MAP source...
Obviously the instructions are not aimed at someone who has re-purposed the ports already.
Old 02-26-2016, 11:49 AM   #41
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
My question being, how could you be using something as a MAP source that you've labelled as optional to cap off? If it's usable as a MAP source, then clearly it needs to be capped. I'm not trying to start crap, I'm curious what I am misunderstanding.
Old 02-26-2016, 12:55 PM   #42
mrsaturn7085
Member#: 375462
WR Blue
Ah gotcha! Yes, they need to be capped or re-purposed.
Old 04-17-2016, 07:34 AM   #43
gtasti
Member#: 152036
2004 Sti
That hose with the breather is 3/4" not 1/2"
Old 04-17-2016, 01:29 PM   #44
mrsaturn7085
Member#: 375462
WR Blue
There's some mismatch between trim levels and the port sizing - especially on the PCV system. Your best bet is always measuring your own hose barbs on your car before replacing any hoses.
Old 04-24-2016, 05:57 PM   #45
gtasti
Member#: 152036
2004 Sti
Any issues with filling the gas tank after removing all this stuff ?
Old 04-24-2016, 06:04 PM   #46
04ScoobyWtf
Member#: 287974
Nope my gas pump clicking off early stopped and it fills till its full and does not overflow
04ScoobyWtf is offline   Reply With Quote
Old 04-27-2016, 11:08 PM   #47
zachary93
Member#: 364895
2004 impreza wrx
red
so 42084G was broken on my car can I just cap everything to it or will it cause CELs? If so will it cause the car to go into limp mode?
zachary93 is offline   Reply With Quote
Old 06-10-2016, 12:42 PM   #48
Bugeye_Buddy
Member#: 448197
2002 Impreza WRX
Any way to remove the hardlines from the rear to the front? I just don't like having unnecessary stuff just chilling out.
Bugeye_Buddy is offline   Reply With Quote
Old 06-10-2016, 01:12 PM   #49
Hyper
Member#: 15822
1999 WRB GM6
2.34 LR destroker
use a dremel to cut it into smaller pieces and take it out part by part
I see no point though, if anything - it can serve as additional fuel line should you do crazy things in the future
Hyper is online now   Reply With Quote
Old 06-10-2016, 01:19 PM   #50
Bugeye_Buddy
Member#: 448197
2002 Impreza WRX
Fair enough. largest turbo I plan on running on this is my Turbonetics 60-1 so I hope I wont need to use it for more fuel lol. Thanks
