Welcome to the North American Subaru Impreza Owners Club Tuesday September 22, 2020
Old 06-10-2016, 01:29 PM   #51
mrsaturn7085
Member#: 375462
2006 Impreza WRX STI
WR Blue
Originally Posted by Bugeye_Buddy View Post
Any way to remove the hardlines from the rear to the front? I just don't like having unnecessary stuff just chilling out.
Yeah, but it involves either removing the full fuel line assembly or cutting the EVAP line out, section by section. IMHO, I'd save this project for a time when you are replacing the fuel lines or dropping the tank.
mrsaturn7085 is offline   Reply With Quote
Old 08-08-2016, 12:40 PM   #52
Colonel Red Racing
Member#: 451342
2005 STI
I've just done this full delete on my 2005 race STI. I found this breather for the rear, it fits perfect and is very compact. 3/4", Rubber Top.
S&B Filters, 26-1519JR
I was worried my garage would smell of gas fumes after this but nothing. No fumes smell. At least no more than usual!
Great thread, thanks.
Colonel Red Racing is offline   Reply With Quote
Old 10-20-2016, 10:12 PM   #53
turbosport
Member#: 437481
2003 Impreza WRX
Very nice write up.
turbosport is offline   Reply With Quote
Old 01-08-2017, 08:31 PM   #54
joebush44
Member#: 163483
1998 07 swapped RSTi
Diamond Black Pearl
Did you do anything with the lines that are red in the photo below? I think some folks just connect them together? I believe the yellow line is the vapor feed from the charcoal canister up to the intake manifold. I think the blue line is the line you have labeled as "B" an needed venting (with a small breather filter). Seem correct?
joebush44 is offline   Reply With Quote
Old 01-08-2017, 11:16 PM   #55
kris142b
Member#: 450777
Sedona Red Pearl
Is this mod safe for those storing their car in a garage with a quartz heater if you leave the line to vent to atmosphere?
kris142b is offline   Reply With Quote
Old 01-11-2017, 12:13 AM   #56
leonbmx
Member#: 82864
2005 MPS Wagon HTA35
Domtuned Stage $$$$$
Good question, I keep reading something about T-ing lines together at the filler neck, perhaps that are these red lines?
leonbmx is offline   Reply With Quote
Old 01-11-2017, 02:25 AM   #57
mrsaturn7085
Member#: 375462
WR Blue
The red lines are the roll-over breather valves and are already tied together... the white 'T' is clearly shown in that photo. IIRC, the red lines travel up the filler neck to a valve that responds to a filler being inserted at the pump. The line that leaves this valve then enters the charcoal canister. With the canister removed, I stuck a Fram in-line filter on the line leaving the filler neck cut-off valve and hid it behind the plastic filler cover.
The yellow line is the EVAP line from the charcoal canister to the engine.
The blue is the large vent line to the charcoal canister. I stuck a filter on this one too - larger than the first one.
I envy the JDM setup... it's infinitely more simple than the crazy regulated fuel tanks that get worse and worse every year in the USA. There is literally one hose that travels to the filler neck, and one small hose you stick a filter on and you're done.
Old 02-07-2017, 09:05 AM   #58
cmiovino
Member#: 134005
2004 WRX Premium
Posting from another thread I commented on:
For anyone doing the delete, you can easily have the CELs for the evap system turned off by a tuner. Most won't charge, just be nice and ask. You can typically send them your current map and they'll make the changes in Accesstuner and resend to you. Just make sure they also force ready the evap monitor too (or all of them while they're at it).
Any yes, this will pass inspection, however, just like you're "not supposed to remove your cat" no one can really tell.
Serious question though, wouldn't most inspection stations be able to see the missing black box and tubing with a breather valve? It clearly looks like equipment is missing.
Old 02-07-2017, 09:41 AM   #59
cmiovino
Member#: 134005
2004 WRX Premium
I've had no issues venting mine via the line that runs to the turbo inlet. You only get a fuel smell when fueling, which you can smell outdoors. I would not recommend filling your car indoors via a gas can with this modification and a heater on.
Old 02-07-2017, 12:53 PM   #60
mrsaturn7085
Member#: 375462
WR Blue
You don't need a tuner if you have ATR - takes ~5-10 min to disable the DTCs and reflash the tune.
If you cannot force readiness, the disabled DTCs will ready the monitors after a drive cycle.
Old 02-07-2017, 02:04 PM   #61
cmiovino
Member#: 134005
2004 WRX Premium
Funny you say that.
I actually thought the same thing, downloaded AccessTuner, loaded my map, made the easy changes, then resaved. Loaded it to the AP and....
When you go to reflash it, the tune is greyed out and not comparable. Apparently you need a serialized version of Accesstuner to do this with any Cobb maps for sure. Not sure how that applies to other tunes. I'm sure OpenSource is more friendly for this.
Old 02-25-2017, 04:29 PM   #62
Crescent1101
Member#: 463252
2005 Saab 9-2x Aero
So I have the Evap delete done under the hood. I'm gettting the P1420 code which is the solenoid. Would this affect my car at all?
Crescent1101 is offline   Reply With Quote
Old 02-25-2017, 08:36 PM   #63
bue car
Member#: 176134
1995 Coupe, Sedan &
Wagon!
Delete the code
bue car is offline   Reply With Quote
Old 03-30-2017, 09:58 AM   #64
Bo Bandy
Member#: 464271
2003 WRX Wagon
For anyone wishing to do this in the future, if you are not able to disable to codes right away and don't want any check engine lights...
In the engine bay keep the evap solenoid connected to the electrical harness but no hoses connected to it. For the rear charcoal cannister etc. Keep the electrical harnesses plugged in and connect the hoses to each other but not hardwired to the car so the evap system isn't actually operating but the car thinks it's still there.
If anyone needs pics I can go take some cause I'm not that great at explaining things...
Bo Bandy is offline   Reply With Quote
Old 04-07-2017, 03:43 PM   #65
dchambers94
Member#: 425596
2002 Wrx
Pics please
dchambers94 is offline   Reply With Quote
Old 05-03-2017, 01:01 PM   #66
Peleliusion
Member#: 466991
Subaru Stars
Originally Posted by prettyinpink View Post
Thank you for this write up! Really helped me out. I would just like to add to anyone who is wondering, the breather can be any 1/2 inch breather that you could pick up at a pep boys or autozone.
Thank you! The breather size was my next question lol!
Peleliusion is offline   Reply With Quote
Old 05-05-2017, 08:14 AM   #67
Peleliusion
Member#: 466991
Worked like a charm! Great write up!
Old 05-06-2017, 10:32 PM   #68
ajj686
Member#: 467015
thank you
ajj686 is offline   Reply With Quote
Old 05-11-2017, 08:45 AM   #69
Ghia Nut
Member#: 201302
2005 WRX Wagon
Very informative write up. Thank you. Nice to see a dead thread raised due to questions.
If you are open source you can delete the codes yourself, mine were super duper nicely labeled and were able to be turned off and were in a larger section around the p0457 area (turns out the previous owner disabled my system about completetly but left **** plugged in??? but did the most half ass job I ever seent :un amused:)
s'ok nah
thanks for the writeup though, components are on the shelf next to the hoard of stock parts.
Ghia Nut is offline   Reply With Quote
Old 09-04-2017, 08:49 PM   #70
bue car
Member#: 176134
1995 Coupe, Sedan &
Wagon!
Just dropped my tank, doing this this week. I will will post pics for others just in case
Old 10-12-2017, 11:34 AM   #71
Scoobydoobydude
Member#: 468311
2003 WRX wagon
World Rally Blue!
This is brilliant... awesome write up and detailed diagrams..... someone should make sure great posts like these never die.
Scoobydoobydude is offline   Reply With Quote
Old 04-30-2018, 12:39 PM   #72
Shmattzig
Member#: 463519
Is it just me or are the pics in the original post not showing up for anybody else either? I did this and Iím 99.9% sure I capped everything but my AFR is all over the place at idle and now Iím wondering if I missed something...
Shmattzig is offline   Reply With Quote
Old 04-30-2018, 03:20 PM   #73
mrsaturn7085
Member#: 375462
WR Blue
It's not just you - Photobucket decided to give everyone on the internet the middle finger about a year ago.
Old 05-06-2018, 10:48 PM   #74
bue car
Member#: 176134
1995 Coupe, Sedan &
Wagon!
Chrome has an add on to fix that
Old 05-14-2018, 06:23 PM   #75
racersky
Member#: 77817
2005 STI
Can I have pics as well please
racersky is offline   Reply With Quote
