Welcome to the North American Subaru Impreza Owners Club Tuesday September 22, 2020
Old 09-10-2019, 07:37 PM   #351
mjtct
Member#: 455505
Also blurry whether Chrome or Internet Explorer
mjtct is offline   Reply With Quote
Old 09-11-2019, 10:21 AM   #352
mjtct
Member#: 455505
Photobucket compression
Old 03-16-2020, 11:59 AM   #353
bugeyerex02
Member#: 195967
WR Blue
Does anyone have an install walkthrough like this with unblurry pics? Damn you photobucket.
bugeyerex02 is offline   Reply With Quote
Old 03-16-2020, 06:46 PM   #354
ascendr
Member#: 462136
02 Bugeye
I happen to have had the images stored locally on my PC. I recreated OPs original post as a pdf. Doesn't look like I can host a file on here so I uploaded to DocDroid https://docdro.id/Za8f4fG
ascendr is offline   Reply With Quote
Old 03-16-2020, 08:17 PM   #355
bugeyerex02
Member#: 195967
WR Blue
Thank you!!!
Old 04-04-2020, 11:54 PM   #356
mrmikeyp
Member#: 296634
about to finish this tomorrow. Got the injectors out already, need to source some o-rings
any good tips for getting the bottom insulators to seat? easier to put the injector into the engine first, push the seal down, then get the rail to seat? or seat the injector on the rail then push down into the engine?
Or just any best practice on the installation. I was having a boost leak through that seal, so i'm concerned i do it right.
mrmikeyp is offline   Reply With Quote
Old 04-05-2020, 12:32 AM   #357
cdska
Member#: 458809
2005 wrx wagon
how did you know you had a boost leak through the seal?
make sure you get oem or EXACTLY the same dimensions for the o-rings or you'll get a leak.
I have personally had the best luck putting the injectors in the engine and push the rail over. use a rubber safe lubricant and be gentle.
cdska is online now   Reply With Quote
Old 04-05-2020, 12:47 AM   #358
mrmikeyp
Member#: 296634
boost leak test. https://turboboostleaktesters.com/ho...test-a-subaru/
After taking care of all the leaks around the TMIC and turbo inlet pipe, noticed i was getting an audible hiss from around where the injectors were. Soapy water confirmed it.
JDM v7 STi TMIC Install on 02-03 ThePunisherGT Newbies & FAQs 13 02-09-2016 02:04 PM
how to install oem front lip on 02-03 wrx theo79 Interior & Exterior Modification 2 01-23-2008 01:33 PM
injectors install on a 2005 wrx spyda23 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 05-31-2007 10:47 AM
Pink replica strut bar 02-03 wrx fluxcapacitor Private 'For Sale' Classifieds 8 05-08-2006 02:10 PM
04 wrx springs on 02/03 wrx struts/tophats spdracr00 Brakes, Steering & Suspension 2 03-03-2006 12:53 PM
