Welcome to the North American Subaru Impreza Owners Club Tuesday February 7, 2023
Old 12-05-2022, 04:48 PM   #1
JR Belk
Member#: 520375
Default 07 impreza power steering problem
I had to move my power steering pump for another repair. Now the power steering doesn't seem to work at all. The fluid is full of bubbles, which I expected due to removing the return line. I did not expect it to kill the power steering though. There is the typical high pressure "whine" when the wheels are turned fully locked to the right, but that's it. No other noise from the power steering. I think it could be excess air still in the system, but I'm reluctant to jump to conclusions and replace the pump for no reason if it's not the problem.
JR Belk is offline   Reply With Quote
Old 12-06-2022, 06:38 AM   #2
arse_sidewards
Member#: 532328
Probably air filled fluid in the rack. Jack the car up and turn the wheels from lock to lock a bunch of times with the system running in order to cycle the fluid through the rack a bunch of times and see if that solves it.
arse_sidewards is offline   Reply With Quote
